When should I change my Coolant?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kolby, Dec 15, 2020.
  1. Dec 15, 2020 at 6:03 PM
    Kolby
    Kolby [OP] Active Member
    Kolby
    2015 v6 Tacoma 4WD Sport
    I have a 2015 v6 taco with 56k. I'm curious when I should change the coolant, I did buy it used and it sat on a lot for 6-9 months. The dealer says I never needed to change it (I was shocked too) and my mechanic said he didn't have the tools to properly do the drain and fill. I was told in order to do it correctly it would have to be pumped in from the bottom as there is no fill port. Is that accurate?
  2. Dec 15, 2020 at 6:10 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Not sure what the manual/service schedule says (it's out in my truck). But I believe it's 100K miles. That's when I had my cooling system flushed/fluid changed.
    Plain Jane Taco likes this.
  3. Dec 15, 2020 at 6:11 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I have a '15 and I've done 2 DAFs on it in the last couple of years. There is nothing difficult or special about the Taco's cooling system. No special tools required
    Save your money and skip the OE SLLC and pick up some Valvoline Zerex pink.
  4. Dec 15, 2020 at 6:12 PM
    Bman562
    Bman562 Well-Known Member
    SoCal, CA
    2005 Radiant Red Tacoma Sport DCSB
    '12+ Facelift, TRD Baja Bilsteins, SCS Ray10's, K02's...
  5. Dec 15, 2020 at 6:17 PM
    Plain Jane Taco
    USA
    Sounds like they were talking about the transmission
    verynearlypure likes this.
  6. Dec 15, 2020 at 6:17 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    You need to find a new mechanic.
    The radiator and the engine block have drains. The "fill" is the radiator cap.
    Coolant change for my '06, 2nd Gen, similar to the '15, has an interval of 100,000 miles.
    I just did mine at 108,000 with a series of radiator drain and fills. The drains on the block would not open. I'm not sure if a "flush" is required.
  7. Dec 15, 2020 at 6:18 PM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    Dang it. I came in expecting at least one person to say something about how " Tacoma coolant must be changed under waxing moon, but never on a Thursday.
    verynearlypure and po35042 like this.
  8. Dec 15, 2020 at 6:21 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    I changed mine at 5 years, Toyota's recommended interval is 5 years or 100k for first change then 5 years or 50k after that I believe. It only holds around 2 gallons, there's 2 block drains, a radiator drain, and a drain on the overflow bottle. The drivers side block drain is kinda hard to find but you should be able to see it through the fender, no special tools required to refill although a spillproof funnel makes it easier.
  9. Dec 15, 2020 at 6:31 PM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Do you have do do anything special when refilling ?
    I’ve simply poured in coolant on my many motorcycles, but head you have to make sure there are no air bubbles in the Tacoma’s ?
  10. Dec 15, 2020 at 6:36 PM
    Tacoma1997White4x4
    Tacoma1997White4x4 America First
    West Covina, California
    1997 white 4x4 auto 4cylinder Singlecab, 2001 auto rwd 2.4l single cab flatbed
    Km3’s 31’s,Lift,Sliders,rear ARB air locker,on board air, armor, hi shell
    You need to find a real mechanic. I change all fluids except the tranny. Unless they have the records I’m changing it. The tranny I leave it if it looks good (I wouldnt have bought it in the first place if its black and metal shavings in it), let it run for probbly a year or 15k miles so you dont feel the damage if incase you do change it of having to rebuild cus of slippage.
  11. Dec 15, 2020 at 7:02 PM
    ixnay
    ixnay Well-Known Member
    Mark
    Portland, Oregon
    Warning, I'm no mechanic.
    As you pour in coolant, squeeze the radiator hose to burp it. Pour some coolant into the overflow tank. Start engine. Let engine run to get to temp. Turn on the heater and run the fan for a couple minutes if you want to verify how warm engine is. Stop engine. Let engine cool. Remove radiator cap. If coolant is right below cap, you're good. Fill reserve tank to recommended line if you hadn't previously. If reserve tank is dry, add some coolant to radiator and reserve tank as needed.
  12. Dec 15, 2020 at 7:08 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    I had no trouble with trapped air in mine. If your concerned about it being full measure what you drained out and put the same amount back in and you should be good providing it was full when you started.
  13. Dec 15, 2020 at 8:32 PM
    Kolby
    Kolby
    Thank you everyone for your input.
    I got a reply from the dealer saying the transmission is a " world standard transmission which Toyota service info states this fluid does not need to be changed or serviced for the life of the vehicle"
    I feel that is a load of crap... am i wrong?
  14. Dec 15, 2020 at 8:36 PM
    Plain Jane Taco
    USA
    I've done 3 DAFs on my rig. Plenty of info around here on how to do it.
  15. Dec 15, 2020 at 8:38 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It seems most all manufacturers have gone to "Lifetime" transmission fluids so they can claim they have low maintenance costs. They will last the lifetime of the transmission, but the transmission will almost certainly last much longer if you change it frequently enough.
    MPI_Jack and TireFire like this.
  16. Dec 15, 2020 at 8:40 PM
    WATaco
    WATaco Well-Known Member
    Ed
    Seattle-ish, WA
    '14 Tacoma ORD
    Leer, AllPro sliders, Prinsu, OME, JBA UCA
    I'm confused as the title says coolant, but then we talk about transmissions. However, my thoughts are that it's all about how you use your truck and your budget. I've replaced coolant annually but not fully flushed, and as I don't tow much I've only done my transmission fluid once (I'm about 75K miles). I do wheel it, and carry extra weight for camping, so thought it's worth it.
    I'm too old to believe the "forget it it will last forever" especially for a vehicle that'll do 300K easy. Put some thought into how you use it, and consider it insurance?
    SR-71A likes this.
  17. Dec 15, 2020 at 9:08 PM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    Life of the vehicle is when it's failed. There's a how-to on here somewhere. Read it over a couple of times and go to it.
  18. Dec 15, 2020 at 9:09 PM
    Tacoma1997White4x4
    its a load of bull:poking:
    TireFire and Dm93 like this.
  19. Dec 15, 2020 at 9:19 PM
    Kolby
    Kolby
    Wow, yeah thats my bad. I had transmission in mind for my question and for whatever reason put coolant. the craziness of corona is getting to me....
  20. Dec 15, 2020 at 9:26 PM
    WATaco
    Ed
    Seattle-ish, WA
    '14 Tacoma ORD
    no worries, corona on your end, monkey shoulder on mine. regardless...if you are towing a lot or carrying heavy loads you may want to consider replacing trans/diff fluid outside of what the manual says. Opinions here will vary based on risk acceptance. Personally I live in a mountain-y region so I tend to focus on stuff like brakes. The ability to stop when pointed downhill is - to me - kind of important. Regardless, every May my truck goes in for inspection by a "pro" which I'm not. If he says it's time to change, I take his word for it as he knows what I plan to do in the summer months.
