When is it too late to supercharge?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 1tacoplease, Feb 12, 2015.
  1. Feb 12, 2015 at 12:24 PM
    1tacoplease
    1tacoplease [OP] I like my truck!
    Temecula
    2008 BSP 4x4 6 speed
    265/70/17 BFG RT's, FJ 17" rims with 1.25" spidertraxx Debadged, HID's, URD short shifter, Bilstein 5100's in the front, TSB and 1" block rear, URD TCAI with maf calibrator, JBL long tubes, DT Y pipe, Gibson exhaust, Walbro 255 fuel pump, Pioneer stereo, Bak flip G2 tonneau, TRD skid plate, MB Quarts all around with dynomat, Viper Alarm with motion sensor
    I have a 2008 with about 65k and could probably afford to supercharge it in about 6 months. I'm thinking my miles will be between 80-100k. I want the supercharger, don't need it but really want it. What are your thoughts?
  2. Feb 12, 2015 at 12:41 PM
    1tacoplease
    Temecula
    Are you happy with it? What type of lackluster performance are you talking about? I spent a lot of time getting mods that would benefit from a supercharger.
  3. Feb 12, 2015 at 1:02 PM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    I dont think you can put a timeframe on it. I'm sure theres motors out there with 100k on it that are in better shape than some with 60k.
    If you're really worried, I suppose you could always do a compression check to give you a better idea of engine health.
  4. Feb 12, 2015 at 1:03 PM
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    Sign up for Super Charger anonymous and go through their 12 point system. Take the money you save and put it into a good retirement plan. :D
  5. Feb 12, 2015 at 1:03 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    There's first gens over 200k with superchargers
  6. Feb 12, 2015 at 1:04 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    Drag times? What were the times? More importantly, what were the trap speeds?
  7. Feb 12, 2015 at 1:07 PM
    tacovinny
    tacovinny Well-Known Member
    Vince
    Bay area
    08 4x4 v6
    Ive been told they break in better with the motor but you should be fine for like 150k? they dont have much boost but you can always change that. I plan on boosting around 100k but im gonna rebuild for the long haul.
  8. Feb 12, 2015 at 1:09 PM
    boostedka
    boostedka Well-Known Member
    James
    NM
    2013 DCSB 6MT, 2004 4runner
    I installed on one my 3.4 1st gen at 80K w/ zero problems. Main issue with higher mileage motors and forced induction is injectors partially clogging over time from build up. Gadget at URD typically recommends a BG or Snap On full fuel system cleaning before installing a S/C on a higher mileage motor to avoid this issue.
  9. Feb 12, 2015 at 1:21 PM
    Chris(NJ)
    08 Indigo 4x4 DC OR
    So all that weight was between stock and the sc install? I know they say every 100lbs adds 1/10th of a second. More if its rotational weight, which the tires may have done.
    Either way, i would've still expected it to be slightly faster as well :(
  10. Feb 12, 2015 at 5:18 PM
    1tacoplease
    Temecula
    I was expecting some considerable gains especially since it's around a $6000 upgrade. My truck feels pretty fast right now, I have no complaints but I have always wanted a vehicle with forced induction.
  11. Feb 12, 2015 at 5:27 PM
    SabMotocross
    SabMotocross Well-Known Member
    Bobby
    Santa Fe, Texas
    2014 Tacoma PreRunner SR5 DCSB V6 TRD S/C
    TRD BAJA Suspension...Rims and tires, blackout badging, TRD oil filler cap, front skid plate, N-Fab step bars, GrillCraft custom upper and lower grills. K&N air filter, TRD Supercharger.
    I had the S/C installed with about 560 miles on the odometer. There shouldn't be any comparison between a stock, normally aspirated Tacoma and a properly-installed, supercharged Tacoma....the "before and after" scenario is quite impressive, even at a paltry 6 lbs of boost.
  12. Feb 12, 2015 at 5:35 PM
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    I put my s/c on at 1700 miles, so I can't really comment on the mileage question. I can tell you there is a huge difference according to the butt-dyno. Is it as fast as my STI was? No. But it goes better, hauls better, and sounds better. I recently replaced the stock dunlops with 6 ply bfgs. I did notice a slight difference in acceleration, as these tires are heavier. Just figure if each tire weighs 1 pound more than the one it replaces, it's the equivalent of throwing 24 pounds in the bed. So adding weight, changing things, regardless of opinion will vary results.
  13. Feb 12, 2015 at 6:00 PM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    Wow something ain't right there on your truck. :(
    I got the SC on mine a few months ago. It's quite a bit faster. I haven't done any 'racing/testing' but come on, a 28% increase in HP has to decrease the times.
  14. Feb 13, 2015 at 12:21 PM
    1tacoplease
    Temecula
    To everyone who added a supercharger later, do you think it was worth the high price?
  15. Feb 13, 2015 at 12:32 PM
    woodygg
    woodygg Well-Known Member
    So Cal
    04 DC Tacoma 4x4
    lol... exactly. not worth it for what it cost and the additional maintenance, wear, etc.
  16. Feb 13, 2015 at 12:42 PM
    Raincity
    Raincity Half man, half amazing.
    Lowermainland, B.C.
    '13 Mica Spruce DC.
    '12 DC TRD-RIP
    That's your decision, is 50ish/HP worth the 5K price tag? What is the extra HP needed for? If it isn't really needed and your itching to do a mod, put the money somewhere else.
    I would have one already if I could afford it. ;)
  17. Feb 13, 2015 at 12:43 PM
    specialized7
    specialized7 Well-Known Member
    ,Saskatoon, Canada
    05 v6 4x4
    i just supercharged my first gen with 240 000 miles on it!!! haha seems to be running fine ....for now
  18. Feb 13, 2015 at 1:33 PM
    1tacoplease
    Temecula
    I don't need the extra power but I want it. Right now, my truck is definitely not slow. I have done numerous mods and the truck feels great but I have always been modding all my vehicles but have never got to tinker with forced induction. So, that's where I stand. Have been modding since I was sixteen and have always been wanting F/I but never got it.
  19. Feb 13, 2015 at 2:15 PM
    Raincity
    Lowermainland, B.C.
    '13 Mica Spruce DC.
    '12 DC TRD-RIP
    I'm in the same boat, been modding cars for a long time before I bought the Tacoma. The one thing I noticed when I went turbo on my car, everything needed upgrading. More power needs better brakes, extra wear on the transmission and drive shafts, more fuel, etc, etc...you just eventually upgrade items as they wear out or break. It was fun but so very expensive. :eek:
  20. Feb 13, 2015 at 2:17 PM
    SabMotocross
    Bobby
    Santa Fe, Texas
    Go for it man.
    Lots of folks want it, but can't justify the 4K+ for it. It's all about analytics.
    While $4000 for the hottest suspension upgrade is usually garnered with applause, getting blown for about the same price is ghastly to some. An S/C rebuild usually comes around the 100 to 120K odometer reading. It's all about how you drive, and isn't that usually important on an engine whether it's blown or not?
    Simply checking the coolant level and the drive belt are usually all that's required for general maintenance on the TRD Supercharger. I think at about 10K is the time to verify the S/C lubricant is at it's proper level or you can simply refresh the lubricant as Delco makes the best S/C lubricant which can be found at any reputable auto parts store. I'd humbly suggest going to the Gates supercharger belt once the factory belt starts to show some wear.
    There is a thread here that provides plenty of information for those that simply want something more. :burnrubber:
