When is enough maintenance to warrant keeping your Taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by vettehigh, May 28, 2019.
  1. May 28, 2019 at 5:55 AM
    vettehigh
    vettehigh [OP] Tacoma Tank
    Jon
    Upstate, NY
    Just like anything with life you have to take care of what you have, but when is enough...enough? I bought my 95.5 for $5800 (205k), but as I look at the massive list of services that I did and the timing kit (that will be done next week)...I'm in his Taco for over $12K+
    Here is my list so far and it's long:
    OEM SWAY BAR LINKS 48820-35021 (L/R) *11/2017
    OEM BUSHINGS 90948-01002(4), RETAINERS 90948-02069(4), NUTS (4) *11/2017
    POWER STEERING FLUID FLUSHED (DEX/MERC) *11/2017
    BRAKE FLUID FLUSHED (TOYOTA DOT 3) *03/2019
    OIL CHANGED (ROYAL PURPLE 5W30 + ROYAL PURPLE OIL FILTER) *03/2019
    OIL DRAIN PLUG 90341-12012 + GASKET 90430-12031 *11/2017
    DENSO RADIATOR (DENSO 2213138) OEM #16410-0C042 *11/2017
    OEM RADIATOR CAP 16401-0C010 *11/2017
    OEM RADIATOR UPPER & LOWER HOSES 16571-62070 / 16572-07040 *11/2017
    OEM RADIATOR CLAMPS (4) 90467-37005 *11/2017
    OEM RESERVOIR HOSES (#1 AND #2) 16472-0C010 / 16472-0C021 *11/2017
    OEM RESERVOIR HOSE #2 CLIPS (2) 90069-19014 *11/2017
    OEM HOSE RESERVE TANK 16472-0C030 *11/2017
    OEM RESERVE CAP ASSEMBLY 16405-0C010 *11/2017
    OEM WATER INLET GASKET 16325-62010 (? LAST 5#’s 0T030) *11/2017
    OEM WATER OUTLET GASKET 16341-62040 *11/2017
    OEM NGK NICKEL SPARK PLUGS (BKR5EKB-11) (6) *11/2017
    NGK 4412 (TE66) SPARK PLUG WIRE SET *11/2017
    OEM PCV VALVE 12204-62010 *11/2017
    OEM PCV HOSE 12261-62041 *11/2017
    OEM PCV GROMMET 90480-18001 *11/2017
    LLOYD (F/R) MATS NORTHRIDGE RUBBER FLOOR MATS – CUSTOM CUT *11/2017
    OEM INNER FENDER CLIPS 90467-10173 *11/2017
    KROWN UNDERCOATING
    NEW INTERSTATE MEGA-TRON PLUS MTP-24F BATTERY *12/2017
    OEM SHIFTER BUSHINGS (2) 33501G *12/2017
    BILSTEIN 4600 REAR SHOCKS (RIGHT 24-184977 / LEFT 24-184960) (BOLTS/WASHERS) *01/2018
    OEM SHOCK BOLTS/WASHERS (91619-G1220 BOLT W/WASHER (4) 90948-03020 WASHER (4) 90948-03011 (4)
    PHILIPS H6054LL LONGER LIFE HEADLAMPS (2) *01/2018
    OEM VALVE COVER GASKETS (2) 11213-62020 *01/2018
    OEM SPARK PLUG GROMMETS (6) 11193-70010 *01/2018
    OEM VALVE COVER BOLT SEALS (16) 90210-05007 *01/2018
    OEM CAMSHAFT PLUGS (2) 11188-62010 *01/2018
    TOYOTA FIPG (1) 00295-00103 *01/2018
    OEM ALUMINUM HALF MOONS (4) 11183-62010 *01/2018
    OEM PLENUM GASKETS (2) 17176-62040 *01/2018
    OEM TOYOTA FRONT BRAKE DISCS (2) 43512-04020 *01/2018
    ADVICS AD0799 FRONT BRAKE PADS (FRONT SET) *01/2018
    TRANSFER CASE FLUID CHANGED (AMSOIL SEVERE GEAR 75W-90) AT 206K *01/2018
    FRONT/REAR DIFF FLUID CHANGED (AMSOIL SEVERE GEAR 75W-90) AT 206k *01/2018
    OEM TRANSMISSION FILTER & CASTROL TRANSMAX IMV ATF FLUID (6 QT’s) AT 206K *02/2018
    TRANSMISSION PAN WAS METICULOUSLY CLEANED BEFORE REINSTALL *02/2018 – OEM DRAIN PLUG/WASHER
    OEM OUTER TIE RODS (L/R) 45047-39175 / 45046-39295 – NUT HEX (2) 90170-20003 *02/2018
    OEM LOWER BALL JOINTS (L/R) 43340-39585, 43330-39815 / OEM BOLT FLANGE 90080-10066 (8) *02/2018
    WHEEL ALIGNMENT *05/2018
    SCORPION BED LINER *04/2018
    ANZO 211180 G2 SERIES TAIL LIGHTS (L/R) *04/2018
    OEM EXTERIOR WEATHERSTRIP SET FRONT (68160-04020 X1 68210-04020 X1) *02/2019
    OEM BRAKE SHOES 04495-35230 *03/2019
    OEM DRUMS 42431-35210 (2) *03/2019
    OEM WHEEL CYLINDERS 47550-35190 (2) *03/2019
    CARLSON H2348 HARDWARE *03/2019
    OIL PAN - TOYOTA 12101-62070 *05/2019
    OIL PICK-UP - TOYOTA 15104-62040 *05/2019
    OEM OIL PAN CUSTOM PAINTED (SAND, EPOXY, PANT) *05/2019
    ALL NEW OEM BOLTS/NUTS/GASKETS FOR OIL PAN INSTALL *05/2019
    TIMING BELT KIT BELOW: WILL BE COMPLETED 06/2019 – (212K)
    *TIMING BELT – TOYOTA 13568-YZZ03
    *TIMING BELT LABEL – TOYOTA 13564-10010
    *IDLER#1 KOYO - 13505-62070
    *IDLER#2 NSK - 13503-62040
    *FRONT CAM SEALS (2) – TOYOTA 90311-38051
    *FRONT CRANK SEAL – TOYOTA 90311-40022
    *WATER PUMP - OEM AISIN 16100-69398-83
    *WATER PUMP GASKET - OEM AISIN 16271-62011
    *HYDRAULIC TENSIONER ASSY – TOYOTA 13540-62021
    *THERMOSTAT – TOYOTA 90916-03075
    *THERMOSTAT GASKET – TOYOTA 16325-62010
    *POWER STEERING BELT – TOYOTA 90080-91126-83
    *A/C BELT – TOYOTA 99364-20870-78
    *ALTERNATOR BELT – TOYOTA 90080-91090-83
    *CRANKSHAFT PULLEY BOLT – TOYOTA 90105-16031
    *TOYOTA STRAIGHT RED COOLANT + DISTILLED WATER
  2. May 28, 2019 at 5:59 AM
    Extra Hard Taco
    Extra Hard Taco Survivor of the winter of misery and death.
    R.J.
    Clown World
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
    look at the brightside...It should be good for another 200k after all of that.
  3. May 28, 2019 at 6:01 AM
    Clearwater Bill
    Billy
    Largo Florida
    It's too late to make that call now.
    The good news is you should be able to drive another 100-150k with mostly fluids, brakes and tires.
    BarnBoy and 12TRDTacoma like this.
  4. May 28, 2019 at 6:05 AM
    vettehigh
    Jon
    Upstate, NY
    I myself over the years average anywhere from 5k-10k miles per year
    GQ7227 likes this.
  5. May 28, 2019 at 6:07 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    is the $12k just for all the maintenance or does that include the purchase price?
  6. May 28, 2019 at 6:09 AM
    CouchlessPotato
    CouchlessPotato Handcuffed to steering wheels still won firefights
    Zach
    You don't buy a truck for its fucking fenders!
    2.5" lift w/35's
    You should be good for quite a while with all that done. Your frame will probably break in half before it needs most of that stuff again
    Jojee117, 12TRDTacoma and Hamer95USA like this.
  7. May 28, 2019 at 6:12 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    Looks like you are nearing the end of a mid-life refresh project. The good news is it has been spread over 18 months.
    I've been successful at buying mid to late 90s Japanese cars with usually over 150,000 miles and then performing a mid-life refresh within the first six months. Then after that, we have a fairly trouble free vehicle to drive for 5 to 10 years. Since I perform most of my own work (except front end alignments), it makes economic sense to me.
    The saving comes in low insurance rates, taxes, and money not lost on depreciation that comes with purchasing new vehicle.
  8. May 28, 2019 at 6:21 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Well youll definetely get more out of it, if that was ever the question. You couldve saved some by going non-oem on some things, but atleast you dont have to question the quality of any of the ones that you did install.
    GQ7227 likes this.
  9. May 28, 2019 at 6:23 AM
    Extra Hard Taco
    R.J.
    Clown World
    I'm sure someone on TW would be more than willing to take it off your hands.
    12TRDTacoma, JakesTacoTRD and GQ7227 like this.
  10. May 28, 2019 at 6:30 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    If you paid someone to do that stuff, then absolutely is it gonna be crazy expensive to own. Most of that stuff can be done by yourself and owning used cars its always a good idea to at a least attempt to do or learn to do stuff otherwise cost of ownership goes way up.
    But being done once, most of that stuff won't need anything for another 15 years... But ouch I feel for ya man.
    GQ7227 likes this.
  11. May 28, 2019 at 6:31 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    one of the potential 'big' repairs might be the head gaskets, engine rebuild/swap out (no idea what the cost of that from a pro mechanic might be)
    not even sure at what mileage (with proper preventive care) this may occur ... 300k 400k 500k?
    Hamer95USA likes this.
  12. May 28, 2019 at 6:32 AM
    vettehigh
    Jon
    Upstate, NY
    Purchase price and services
    DavesTaco68 and GQ7227[QUOTED] like this.
  13. May 28, 2019 at 6:34 AM
    cruiserguy
    Elijah
    SEKS
    And the good news is that folks generally don't pay to have those services done unless of course they can afford them. I'm guessing you can afford it just fine, based on your detailed notes I make that assumption, so it's just the sticker shock of seeing the total. I get ya
    vettehigh[QUOTED][OP] likes this.
  14. May 28, 2019 at 6:36 AM
    vettehigh
    Jon
    Upstate, NY
    I'm able to get all OEM parts at dealer cost (my good friend is a dealer), sometimes 10% lower too on certain sites. I have saved a ton that way
  15. May 28, 2019 at 6:37 AM
    cruiserguy
    Elijah
    SEKS
    Just staying on top of your maintenance should make you very happy in the long run
    GQ7227 and vettehigh[QUOTED][OP] like this.
  16. May 28, 2019 at 6:40 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    are you trying to decide to get something 'newer' perhaps less miles onit?
  17. May 28, 2019 at 6:41 AM
    cruiserguy
    Elijah
    SEKS
    I doubt it. If he sunk that money into it over last year for maintenance, I'd bet he's keeping it
  18. May 28, 2019 at 6:41 AM
    vettehigh
    Jon
    Upstate, NY
    Nope, not after all this. I only pay $475 per year for full coverage to. All papers are documented along with pictures if anything should happen
  19. May 28, 2019 at 6:42 AM
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285 KO2s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch.
    You have spent 12g and your truck does everything a 35g to 42g truck does, that buys a lot of pizza and beer and road trips.
  20. May 28, 2019 at 6:46 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    The trick when you have a project is to not count the $$$. You just do it at your own pace and you don't count. If you do count, you get discouraged and eventually give up. Working/investing on a project truck/car (or whatever it is) with the aim of selling it afterwards is not a good idea, as you'll never get what you invested in it. You're better keeping it at that point
    I can understand you, though. People are telling me I'm crazy and should have bought a more recent truck instead, like a 2nd gen with less work to do. But I do not regret my truck at all. I really enjoyed working on it (and I still do). That's what matters. Really proud to drive it around too. I'm just pissed they keep saying I am a fool. Why? That's what I wanted
