When I shift to manual, it always starts in 4th gear. Is this normal.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Luvnhate16tacoma, Jan 8, 2019.
  1. Jan 8, 2019 at 4:40 PM
    Luvnhate16tacoma
    Luvnhate16tacoma [OP] Active Member
    Duane
    16 off-road
    4" suspension lift. Step bars 285 BFG AT tires. Tinted windows
    Even at a stop, when I switch to manual shifting it begins in 4th gear. Is everyone else's like this?
    HSmith_11 likes this.
  2. Jan 8, 2019 at 4:42 PM
    tguil
    tguil Well-Known Member
    Nebraska
    2018 Double Cab TRD Sport 4X4 AT
    Yep........
    eurowner, Linewalker and synaps3 like this.
  3. Jan 8, 2019 at 4:44 PM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    I dont think so, I see a Lemon Law in your future
  4. Jan 8, 2019 at 4:44 PM
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    Even my mom’s highlander and dad’s tundra are like this. It’s not actually manual. Instead, from what I understand, it lets you control the maximum gear the transmission will shift into.
    For example, when 4 is selected, it will only shift through gears 1,2,3, and 4. Km guessing it starts in 4 since it’s a pretty middle-ground gear that isn’t overdrive.
    407guy and The hammer like this.
  5. Jan 8, 2019 at 4:55 PM
    Luvnhate16tacoma
    Duane
    16 off-road
    Well, I can shift all the way up to 6
  6. Jan 8, 2019 at 4:58 PM
    HSmith_11
    Hunter
    Madison, Va
    It’s probably because people usually shift into the “manual” mode while towing, so the computer starts you at 4 rather the 5/6 which isn’t used as often when towing.
  7. Jan 8, 2019 at 5:01 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    Mine starts in 1st unless I’m not paying attention, then goes in reverse. It’s fun at stoplights, for the car behind me.
  8. Jan 8, 2019 at 5:06 PM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I thought it was called sport mode? I actually shift to s5 daily with ect on. If I know it’s a short trip under 55ish I keep it at s4. And the only time I’d consider s6 is if I’m cruising hw speed but want to keep it gas friendly. Not often
    I like the drive like this
    Mopar Mussel likes this.
  9. Jan 8, 2019 at 5:08 PM
    Tacoma3rdGen
    Tacoma3rdGen Well-Known Member
    New Mexico
    2018 Tacoma Limited
    The only way to “switch” to manual is if you already have a manual transmission. I assume you mean engage the S mode on the automatic transmission... which is nothing more than a gear limiter, based on which gear selection you have made (aka, S4). The AT will start in 1st from a dead stop, and shift up to 4th in this case, wherein the transmission will stay until a lower gear is required.
    JNG, StayinStock and daddy_o like this.
  10. Jan 8, 2019 at 5:15 PM
    Tacoma3rdGen
    New Mexico
    2018 Tacoma Limited
    I’m not sure what S6 will do for you as the S mode is an upper gear limiter, not a gear lock. S5 would stop the AT from shifting back and forth between 5th and 6th gears by limiting the transmission to no higher than 5th...
  11. Jan 8, 2019 at 5:34 PM
    baldbeardedtaco
    FL
    o_O Exactly the point right? Based on driving situations that I mentioned above personally
    Ex. if I’m on the highway at 75-80ish being in s6 will allow me to be in 6th gear, right. So gas mileage should be better in s6 than s5 at the same 75-80ish.
  12. Jan 8, 2019 at 5:38 PM
    Luvnhate16tacoma
    Duane
    16 off-road
    What I'm saying is that when I'm at a complete stop and go to s mode it begins in 4. Why not 1?
  13. Jan 8, 2019 at 5:39 PM
    HSmith_11
    Hunter
    Madison, Va
    Because 4 is not the actually gear it’s in. It just sets the max gear allowed...
  14. Jan 8, 2019 at 5:41 PM
    Luvnhate16tacoma
    Duane
    16 off-road
    Actually it is, if I can shift down. And I can shift up to 6 if I choose. Sounds like nobody has an answer
  15. Jan 8, 2019 at 5:41 PM
    Tacoma3rdGen
    New Mexico
    2018 Tacoma Limited
    BUT, the transmission won’t stay in 6 (the S mode is NOT a gear lock)... AT will still down shift when the ECU/TCU so requires, therefore when climbing (even a small hill like an overpass), this transmission will still downshift just like if it were in D... so, S6 serves no real purpose as a limit on the already selected highest gear available.
  16. Jan 8, 2019 at 5:43 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    It does not show what gear you are in, it just shows the max gear it is set for, and 4 is the default.
    HSmith_11 and FitzTaco84 like this.
  17. Jan 8, 2019 at 5:44 PM
    Markc1024
    Markc1024 Well-Known Member
    The answers are there, you might just need to sleep on this one a bit. Moving to S5 or S6 just changes the upper limit. Granted, if you're in S4, and traveling at 40mph and shift to S5, it's going to shift to that. Do the same thing at 15 mph and it will shift to the next appropriate gear when the time is right - up to the limit you set.
    daddy_o and Tacoma3rdGen like this.
  18. Jan 8, 2019 at 5:47 PM
    Luvnhate16tacoma
    Duane
    16 off-road
    When in s mode my truck will stay in the gear displayed on the dash. When I switch to s at a stop and take off I can manually shift to a lower gear and it will stay on that gear regardless of rpm.
  19. Jan 8, 2019 at 5:48 PM
    407guy
    407guy Well-Known Member
    407 area code
    2018 TRD OR 4x4 DCSB Cement
    It is starting in 1. It will only upshift to 4 if you're in S4.
    Tacoma3rdGen and daddy_o like this.
  20. Jan 8, 2019 at 5:49 PM
    daddy_o
    Bossier City, La
    The display does not show what gear you are in, it just shows what max gear is set. The dash will show S4 but your truck will be in 1st at a stop.
    Stocklocker, Tacoma3rdGen and 407guy like this.
