When do you upgrade your control arms?
Discussion in '1st Gen. Tacomas (1995-2004)' started by skycamper, Oct 18, 2021.
  1. Oct 18, 2021 at 10:25 AM
    skycamper
    skycamper [OP] Well-Known Member
    Abraham
    2001 Tacoma 4x4 2.7L Ext Cab
    3" Lift w/ 5100's and EMU 882 springs , General Leaf Spring and AAL in rear with 5100. Diff drop, carrier drop, 3 degee axle shims. Trail Gear Tube Bumper. Tundra brake mod.
    Ive been on a kick lately of dumping money into my old tacoma! 2001 2.7L 4x4. Did the 5100's on the highest setting, going to do a diff drop , progressive add a leaf on new General Spring HD's in the back with 5100's. I notice alot of folks upgrade their control arms. How high a lift are new control arms needed for? Can see myself going more than 31" tires.
    Thanks!!
  2. Oct 18, 2021 at 10:28 AM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    You probably already need Them with 5100s on the highest setting.
    There’s no magic lift number, the whole point of UCAs is to get your alignment numbers back in spec. As you lift more you loose caster. If your alignment numbers are good then don’t worry about it. If your caster is low and the truck feels like it’s wandering on the road you probably could use UCAs.
    OmahTako and memario1214 like this.
  3. Oct 18, 2021 at 10:29 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    We generally recommend that folks look into upgrading control arms at any lift amount that is 2"+ over stock. This allows for the ability to dial in those alignment specs. Some folks get away with stock UCAs around 2.5", but you're running up against the limits of the arms, and not getting ideal alignment numbers.
  4. Oct 18, 2021 at 11:08 AM
    plurpimpin
    PDX
    I drove for a year on stock UCAs on about 2-2.5" lift and while tolerable it wasn't very fun. Truck liked to wander all over the road with no caster.
  5. Oct 18, 2021 at 11:14 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You need them once you can get proper alignment.
    Since you lifted your vehicle already, it's safe to assume your truck aligned well; you need to get an alignment immediately after getting a lift so you don't to killing your tires prematurely.
  6. Oct 18, 2021 at 11:55 AM
    skycamper
    Abraham
    Coincidentally I went and got an alignment, I think it was pulling left a bit but the steering wheel seemed very straight. I dont notice wandering. Here is the report, I have no idea how to read it!
  7. Oct 18, 2021 at 3:02 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    I change my control arms When they get to the point they are so rusted after the 3rd time of welding them time for new.
  8. Oct 18, 2021 at 3:13 PM
    AmherstAndy
    AmherstAndy Well-Known Member
    Andy
    Masshole
    2003 2.7L 5 speed, 4x4 J shift, Xtracab
    How do the bushings look by the time that happens?
  9. Oct 18, 2021 at 3:30 PM
    Bivouac
    They bushings have been replaced every time the Control arms were removed as well as the upper ball joints
    I keep cam bolt hardware most often they need cut off.
  10. Oct 19, 2021 at 10:19 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Which control arms? uppers or lowers?
    Uppers: No need to "upgrade" unles a) you just want to spend $500-800, or you are having issues getting your truck aligned after lifting it more than 2 or so inches.
    Lowers: No need unless you're doing long travel (NOT mid/extended travel) or your LCAs are bent, rusty or otherwise damaged.
    If you need bushings, just get bushings. Most shops try to sell you whole new arms because they are quicker to install, and YOU pay the increased cost in parts.
    waterlogged77 and skycamper[OP] like this.
  11. Oct 19, 2021 at 10:26 AM
    skycamper
    Abraham
    No idea what I need if anything, there are my alignment specs in the photo after I put my front shocks at the highest setting which is a 2.5" lift. Unfortunately I cant read how well the truck got aligned since I dont know anything about alignment. The shop didnt say they had any problems though. Can someone interpret? I thought if it cant be aligned properly then new upper control arms are needed due to the lift.
    I dont think Im the type to crawl over large boulders if thats what you mean. This truck is going to just see some trails that might get a little hairy..
  12. Oct 19, 2021 at 10:42 AM
    jbrandt
    Justin
    Green = good. The Actual" column is what the result of the alignment was. It's odd they didn't say anything since the front left is still out of spec. Take it back and have them correct it.
    Don't but into the crap where you need "more castor" or whatever with a lift. All you need is the stock alignment specs. The new UCAs allow more castor adjustment, but that's only to counteract the lifted geometry. The end result should still be the factory numbers.
    If they can't get it aligned back into factory specs, that's a sign you may need new upper control arms. Generally speaking 2.5" of lift is right at the edge where people start needing UCAs.
    waterlogged77 likes this.
  13. Oct 19, 2021 at 10:44 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    I would hate it if I had to drive my truck with those specs. Caster is very low.
    Stock you would have at least 2° of positive caster but because of the lift you've added, that is no longer attainable. Also, I would not be surprised if the upper tip of your spindle or the inner part of the UCA isn't hitting the coil spring at full droop.
    Aftermarket UCAs will help this issue. Most brands offer a way to add in +2° of caster right into their design.
  14. Oct 19, 2021 at 12:31 PM
    skycamper
    Abraham
    Ok two things, what is cross caster?
    What is full droop? Just from the name Im assuming its when my wheel drops to the lowest point it can? Even though Ive had this truck 16 years im only now getting into this off roading stuff.
  15. Oct 19, 2021 at 1:19 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes. Full droop happens when the shock is fully extended. You can check this by jacking the front wheels up off the ground.
  16. Oct 20, 2021 at 10:21 PM
    skycamper
    Abraham
