Wheels and Tires or Suspension first?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Fedup13, Jun 30, 2021.
  1. Jun 30, 2021 at 11:50 AM
    Fedup13
    Fedup13 [OP] Well-Known Member
    San Diego
    2021 OR DCSB 4x4
    Got new 2021 Off-road 4x4 and wanted everyone’s opinion on what should be first, wheels and tires or suspension?
    Thanks for input:
  2. Jun 30, 2021 at 12:15 PM
    bornxbackwards
    bornxbackwards Well-Known Member
    Bruno
    Sherbrooke, QC
    2021 MGM Tacoma SR5 4x4 DCLB
    Debadged, black sumos, brake controller.
    You should first drive it. If you don't like it, upgrade in the right direction.
    Or come back complaining about MPG or lack of performance.
  3. Jun 30, 2021 at 12:59 PM
    MountainManGuy
    MountainManGuy Well-Known Member
    Colorado
    2019 Toyota Tacoma TRD Off-Road DCSB
    It depends on what size wheels and tires you want. After a certain size you're going to have to lift it before you can fit the tires on. I did mine all at the same time.
  4. Jun 30, 2021 at 1:05 PM
    714reyesj
    714reyesj Well-Known Member
    Danny
    Orange County, CA
    2017 TRD Off-Road 4x4
    Suspension first that way you can go with 33" tires with very minimal rub issues. Otherwise you're going to go with a tire size that is only a little bit bigger because you did tires first and regret that you didn't do suspension first and got the tire size you wanted from the beginning.
    (Might be talking to myself)
    Taco_Coma likes this.
  5. Jun 30, 2021 at 1:09 PM
    dagobert
    dagobert Well-Known Member
    Breathe.
    Then follow bornxbackwards advice. Modding is fun but also a rabbit hole that can spiral very deep very quick.
  6. Jun 30, 2021 at 2:29 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    If the tire doesn't fit stock, will it really fit lifted or will it just not rub until you actually use the suspension?
  7. Jun 30, 2021 at 2:34 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    this.....
    honda50r likes this.
  8. Jun 30, 2021 at 2:37 PM
    Darksport
    Darksport Well-Known Member
    Jake
    NE Ohio (Cleveland)
    2017 Black Tacoma TRD Sport 4x4
    33” BFG Ko2s,16” Method NV wheels, CMC, King 2.5 Remote Reservoir, Baja Kits UCAs
    Save up and do it all at once. Wheels and tires, coil overs and shocks, upper control arms, cab mount chop and be done with it. You’ll thank yourself later.
  9. Jun 30, 2021 at 2:43 PM
    9th
    9th Not a Civil Engineer
    Smitty
    Tropic of Cancer
    2017 Unicorn Silver Sky
    lubricated fuel door hinge
    Welcome aboard. My truck came ready to rock, right out of the box.. :cheers:
    Mastiffsrule likes this.
  10. Jun 30, 2021 at 3:21 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    It would help answer your question if you described your goals and constraints.
  11. Jun 30, 2021 at 11:08 PM
    Fedup13
    San Diego
    2021 OR DCSB 4x4
    Not going to do 285’s, I think I’ll go one size larger than stock. Lift I don’t want to do more than 2 inch.
  12. Jun 30, 2021 at 11:09 PM
    Fedup13
    San Diego
    2021 OR DCSB 4x4
    Only want a 2 inch lift and was only gonna get one size up from stock on tires.
  13. Jun 30, 2021 at 11:12 PM
    Fedup13
    San Diego
    2021 OR DCSB 4x4
    Daily driver, weekend warrior was thinking a 2 inch lift and one size up from stock tires. I don’t want anything drastic as I have no need for it. I like the look of 285’s but from what I’ve read the cons out weigh the pros.
  14. Jun 30, 2021 at 11:15 PM
    Fedup13
    San Diego
    2021 OR DCSB 4x4
    I suppose i could do it all at once but from what I see as far as wait times on wheels and suspension parts I figured I’d have to do one at a time while waiting for one or the other.
    Darksport[QUOTED] likes this.
  15. Jun 30, 2021 at 11:18 PM
    mangosmoothie
    mangosmoothie Well-Known Member
    Casey
    Northern AZ
    '22 Pro
    265 75 16 tires have gotten me far more places than a lift would have
    Fedup13[OP] likes this.
  16. Jul 1, 2021 at 9:52 AM
    Fedup13
    San Diego
    2021 OR DCSB 4x4
    Thx for info
  17. Jul 1, 2021 at 10:21 AM
    el Gringo
    el Gringo Well-Known Member
    Brian
    2018 Tacoma TRD Pro
    Tires and wheels have served me well to start, i only want to replace suspension when stuff starts to wear out
