?? Wheelers steelies alternatives ??
Discussion in '2nd Gen. Tacomas (2005-2015)' started by frusteri4, Mar 14, 2016.
  1. Mar 14, 2016 at 5:56 PM
    frusteri4
    frusteri4 [OP] Well-Known Member
    Reno
    off road ACLB
    Pelfrey Front, CVT tiny, OME heavy,
    I'm hopping to open the discussion, if it hasn't been already, about a suitable cheap, steel, off road rim, that clears control arms for guys running a mid travel setup. The word I'm hearing is that wheelers stopped selling their steel wheels because of issues they were having with the manufacturer. Is it possible to go straight to the manufacturer? are there any alternatives out there that would be suitable off road? and be able to: clear the brake caliper, give 4.5" backspacing, and as a bonus still be able to run TPMS
  2. Mar 14, 2016 at 6:22 PM
    M192
    M192 Well-Known Member
    Dan
    Cambria county PA
    06 Tacoma trd sport, 88 4runner
    Alot
    Procomp series 87T Make sure they are the 87T not the 87. The 87T is supposed to be for toyotas.
    tacoma16 and patbegley like this.
  3. Mar 14, 2016 at 6:24 PM
    frusteri4
    Reno
    off road ACLB
    do they make those in a 4.5" backspace that you are aware of?
  4. Mar 14, 2016 at 6:30 PM
    M192
    Dan
    Cambria county PA
    Alot
    Ewww my bad I forgot about that. Ehhhh not that I'm aware of.
  5. Mar 14, 2016 at 6:46 PM
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    I'd go that route but I hear steelies are quite heavy. Perhaps I am wrong.
  6. Mar 14, 2016 at 6:51 PM
    M192
    Dan
    Cambria county PA
    Alot
    Yes they are. Mine are 33-37# a piece then add a 66# tire ouch. Hope I never get a flat.
    patbegley[QUOTED] likes this.
  7. Mar 14, 2016 at 7:03 PM
    frusteri4
    Reno
    off road ACLB
    you don't have any rubbing issues with your mid travel setup? where did you get the 87Ts?
  8. Mar 14, 2016 at 7:25 PM
    M192
    Dan
    Cambria county PA
    Alot
    I'm not actually running a mid travel setup. Just a ome 3" lift. My bad didn't see that when I read your op. But no I have lots of room between the JBA uca's and the tires. But they are 16" rims so I have like 1/4" between the rim and caliper.
    tacoma16 likes this.
  9. Mar 14, 2016 at 9:47 PM
    frusteri4
    Reno
    off road ACLB
    Im having a hard time finding the 87Ts anywhere, where did you get yours?
  10. Sep 10, 2016 at 8:07 PM
    M192
    Dan
    Cambria county PA
    Alot
    Whoops just saw this. Did you ever find them? I think I had got them from 4wd.com or 4wheelparts.com I can't really remember. But I think I had paid like 75$ a wheel.
  11. Sep 10, 2016 at 8:20 PM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
  12. Sep 10, 2016 at 8:33 PM
    M192
    Dan
    Cambria county PA
    Alot
    Yeah. Not too bad. But like I said I went from like 50# wheel/tire combo to like 100# wheel/tire combo. The finish is great. It is only rusting where I have rock rash. I fix that with spray paint.
  13. Sep 11, 2016 at 8:01 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Awesome thanks for the input.
  14. Sep 21, 2016 at 8:26 AM
    frusteri4
    Reno
    off road ACLB
    I ended up getting them at 4wheelparts. They gave me a courtesy call and said that they wouldn't fit. And if I had them pre-mounted and balanced then I wouldn't be able to return the tires if they didnt fit my truck. Low and behold, the 87t fit my 2015 off road just fine.
