Wheeler’s SuperBump bump stops....reviews?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PFD FIRE, Sep 29, 2018.
  1. May 20, 2020 at 3:46 PM
    HokieHT07
    HokieHT07 Well-Known Member
    08 DCSB TRD Off Road
    What's better? Wheelers or durobump?
  2. May 20, 2020 at 4:58 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Yes.
    I really like the duro bumps up front. I still have the Wheeler's on the rear. The quality in material seems to be higher with the duros. You can't really go wrong either way; Wheeler's have been around forever and the duros were new. I purchased them at a price cut when they first came out. I didn't go with the duros in the rear because I would have had to purchase new ubolts, mounts and the bumps. I was selling a house and purchasing a new house at the time and I was being mindful of spending money. So the rear was left as is.
  3. May 20, 2020 at 5:26 PM
    matt2491
    matt2491 Well-Known Member
    Massachusetts
    2015 TRD Off-Road Supercharged
    Just bought a set of DuroBumps. I quite like the design and build quality, especially the fronts.
    Torspd likes this.
  4. May 26, 2020 at 3:40 PM
    jdiola
    jdiola Well-Known Member
    jay
    Echo park los angeles
    13 tacoma dcsb off road
    Ovtune, anytime locker mod, pelfrey hybrid bumper, pelfrey rock sliders baja designs s8 and sqaudron pros, group 31 interstate battery with TW memeber coupe trd battery strap, osram 100/90 watt headlight bulbs, hkb voltage booster, meso 3 pod 3rd brake light, archive hammer hangers at the helm motorcycle holder/bed stiffiner prinsu rack gfc superlite rotopax 2.5 gas 2 water sua deaver hd springs with icon hydro bumps 12” fox 2.5 dcs w/ accutune on archive shock relocation ext icon cdc front coil overs jdfab 2.25 lt w/currie axles fox 2.5 front bumps jdfab double shear uca jdfab spindle gusset bypass shock hoop with icon s2 falken wildpeak 265/75-17 carhart seat covers
    same. duros up front super bumps out back. very noticeable when you hit the stock stops now its hard to tell when i hit them
  5. Oct 20, 2020 at 8:00 PM
    JoBroTACO
    JoBroTACO Jobrotaco IG
    Joey
    Yuma AZ
    2013 TACO 4x4 4 cyl 5spd
    All pro Bumper and Armor SPC Control Arms King stock OEM RR X 4 Ironman 4X4 leafs Superbumps front #1500 sumosprings rear Sway bar delete Larger than average balls Lower than average intelligence
    20201019_123737.jpg 20201019_123741.jpg 20201019_123935.jpg 20201019_130816.jpg 20201019_131205.jpg 20201019_133842.jpg
    I have had wheeler super bumps for 7 years. I recently added 3/8 spacers to stop upper wheel well rubbing front and changed out my rear bumps to sumosprings #1500lbs and flex great they are much better in my opinion. Pro tips: cut a 8mm Allen key down to size and use a 8mm socket driver for easy removal and installation.
  6. Oct 20, 2020 at 8:05 PM
    JoBroTACO
    Joey
    Yuma AZ
    Sumosprings
    HokieHT07[QUOTED] likes this.
  7. Oct 20, 2020 at 8:08 PM
    RobP62
    RobP62 NVR20LD
    Rob
    Street, Md.
    TTC Member #0125
    Both Dr. Funkers in one place at the same time is bad JuJu. :spy:
    JoBroTACO likes this.
  8. Oct 22, 2020 at 6:00 PM
    Glockster22
    Glockster22 Well-Known Member
    2005 tacoma
    Ironman lift
    I have them front and rear. They have changed my offroading dramatically. Much smoother and forgiving than stock.
  9. Oct 22, 2020 at 6:17 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Running Wheelers front and rear. Fronts were moved from my previous truck and have almost 8 years on them, still in good shape.
    Speed bumps at the mall are more cushy now!
  10. Oct 10, 2021 at 5:04 AM
    ohcaltexscar
    ohcaltexscar Out of Huckleberry Licorice…
    Chas
    El Paso, Texas
    2005 DCLB SR5 Prerunner
    IM4x4 2.5" NitroGas - Coopers
    How are the Durobumps doing?
    geekhouse23[QUOTED] likes this.
  11. Oct 10, 2021 at 6:17 AM
    geekhouse23
    No issues at all
  12. Jun 16, 2022 at 8:12 AM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    I run a set of 4 Wheelers Superbumps on my heavy 100 series cruiser. An amazing benefit is to keep control when jumping and bouncing from popping a wheelie when climbing a hill. The two on each side engage at the same time. I'm not sure I could do without them. I don't live in an area with road salt.
  13. Aug 24, 2022 at 7:38 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, home built rack with CVT Mt. Shasta, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    Bumping this because I’m looking for some info that seems to be pretty undocumented. I have a set or rear Superbumps I haven’t mounted and I’m trying to find out approximately how much these compress, as in what the approximate height of the bump stop is when fully compressed.
    I know there are several factors such as weight, how fast the impact, etc.
    I’m running 1/2 ton leafs and still run heavy enough it gets uncomfortable at times with some slight sway to the point I think evasive driving might have bad results.
    My springs aren’t flat, about an inch of arch left, but my hope was I could have these close to engaging to add some stability in turns.
    Second concern is having the bumps compress fully when rear leafs are fully compressed and keep the spring from going just slightly over negative arch.
    This ensures when I dump everything at camp and go out to hit trails the bumps will compress on bounces off obstacles and keep from bottoming out my shocks which will bottom out when the leaves are negative arched an inch or so.
    Obviously this is also to spare the leafs, though they have over 300k miles and may need replacing at some point, but also help keep the next set from getting overflexed
  14. Jan 14, 2023 at 7:39 AM
    Kyle_
    Kyle_ A guy and his expensive hobby
    Kyle
    SoCal (805)
    2021 TRD OFF-ROAD 4X4 DCSB
    @tacoma.kyle on IG
    Will the wheelers superbumps limit any travel for a stock 2021 tacoma?
  15. Jan 14, 2023 at 7:45 AM
    #35
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Wheelers compress a ton, so they should limit or change bump travel. You can get spacers for them to limit the up travel.
  16. Jan 14, 2023 at 7:47 AM
    #36
    Kyle_
    Kyle
    SoCal (805)
    @tacoma.kyle on IG
    Ah. I’m hoping with my stock suspension, that they would not limit my uptravel since they say it may on their site.
    so I am looking at
    https://durobumps.com/product/3rd-gen-toyota-tacoma-front-bump-stops/
    But the price is rough
  17. Jan 14, 2023 at 8:28 AM
    #37
    Sterling_vH111
    Sterling
    socal
    I’ll admit I’ve not measured or anything, but a couple GoPro videos I’ve taken under the wheel well show them compressed pretty flat.
    I’d say even if there’s minimal uptravel loss, it’s worth it for the control.
    Either superbumps or the durobumps will work great. The wheelers ones were the best suspension bang for buck mod I ever did to the truck.
    Kyle_[QUOTED] likes this.
  18. Feb 13, 2023 at 7:28 PM
    #38
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    Melted my superbumps off
  19. Mar 18, 2023 at 8:12 PM
    #39
    pnw_pro_taco
    pnw_pro_taco Well-Known Member
    2018 White Tacoma TRD Pro
    How!?
  20. Mar 18, 2023 at 8:24 PM
    #40
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    Lotta whoops
    SIK99Tacoma likes this.
