Wheel Well Rust Repair
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chopchop, Jan 28, 2018.
  1. Jan 28, 2018 at 6:35 PM
    Chopchop
    Chopchop [OP] Active Member
    Nick
    2004 Tacoma 4WD Ext Cab
    I've purchased the wheel well replacement panels and will be replacing them this next week. I'll post pics of my progress. The panels if I can use them correctly will remedy the rust above the wheel well, but I've not been able to find how to remedy the rust immediately in front of and behind the wheels. any suggestions or references would be appreciated.
    My brother says I should try to find a complete bed, and I see merit in his suggestion, but I've not found a suitable bed in my searches.
    I see some tacos on here where they have constructed a flat bed....that may be an option, but I sure like the looks of 1st generation Red Tacos... I have a 96 and a '04.... both have some rust issues, but still run and drive great.
    Thanks in advance for any suggestions!!
  2. Jan 28, 2018 at 6:37 PM
    Chopchop
    Nick
    I am also looking for replacement parts for the '04 skid plates and the plate protecting the gas tank on the '04.
  3. Jan 28, 2018 at 8:10 PM
    ClevSix
    ClevSix Well-Known Member
    IL/IA
    01 DCSB SR5 TRD, 13 T4r SR5
    Suspension, 33s, some armor... Rust, Gray wire and 2Low, and more. T4r is stock.
    If you're having bed rust issues, how's the frame? In my experience the frame rusts faster than the body unless something happened to the body panels.
  4. Jan 29, 2018 at 7:11 AM
    Chopchop
    Nick
    So far the frame looks to be solid. There is some rust on it. I'm headed out to try and weld the replacement panels today. I'll post pics of my progress and I can only hope it goes smoothly.
    Enjoyed reading about your build.. I'm working to get my e-brake working again. I have the initial part freed up, but the cable to the back brakes is still stiff. The person who sprayed the undercoating was very generous with the material...I may find he/she covered up some frame compromise... I'll keep everyone posted...
    The link to the skid plates on your build seems a bit old... is the fellow who provided those skid plates still in business. I have lots to learn in this area...
    Thanks for your post...
  5. Jan 29, 2018 at 7:51 PM
    Chopchop
    Nick
    Progress todayC2B9BD00-0968-454D-9460-EEC42CACEE3C.jpgC2B9BD00-0968-454D-9460-EEC42CACEE3C.jpgD7B51D9A-D9C7-4678-BE7C-D9FA201896BF.jpg113B42C9-54AC-4BD2-94ED-8712BDB758BA.jpg
  6. Jan 29, 2018 at 8:11 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Wow if the body is that bad I would really inspect that frame. Hit it with a hammer in a few places.
    ClevSix likes this.
  7. Jan 29, 2018 at 8:54 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    X2^^^
    BartMaster1234 and ClevSix like this.
  8. Jan 29, 2018 at 9:13 PM
    ClevSix
    IL/IA
    Looking at the parts of your frame that I can see in those pics, it looks as bad as mine. At least check the handful of trouble spots like around the spring hangers. Remember, the frame on these trucks tend to rust from the inside out.
  9. Jan 30, 2018 at 4:56 AM
    Chopchop
    Nick
    Made some progress but our fiberglass mix lacked hardener. Lower portions of the quarter panel are a challenge for DIY body men.
  10. Jan 30, 2018 at 5:08 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Could be worth it to just get glass bedsides? That way you could just cut the rest off and start over without having to blend the two. Im not a body work guy, but I cant imagine the blend of glass to metal like that would be the best combination in the long run although glass will crack the paint regardless in time.
  11. Jan 30, 2018 at 5:29 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Coot83 likes this.
  12. Jan 30, 2018 at 5:33 AM
    INSAYN
    PNWet, Oregon
    DIY Fabricobbler.
    On second thought, it looks like this is mostly just the arch, and is still a weld in patch. Not the entire fender as I was seeing it.
    My bad!
  13. Jan 30, 2018 at 8:12 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    This is why having fender flares is a bad idea. it traps mud and moisture and when you see signs of rust, it is already too late (because you don't see it until it is)
    I would ditch them after this repair, or the story will repeat itself. Or keep them and regularly remove them to clean the wheel arches and the flares
    yeah, it is just the patch for the wheel arch, not the whole fender
  14. Jan 30, 2018 at 12:51 PM
    Chopchop
    Nick
    Yes, I looked for the entire quarter panel and haven’t been able to find one. If you come across one let me know.
    We are going to do some inspection with s hammer. My brother is giving me smack saying don’t hit it to hard...maybe all thst’s Holding it together.
    We are having a good time... two old retired Texas boys.
    Thanks for all the posts!!
    I’m going to call Toyota customer service and see if there may be some other options.
    BartMaster1234 likes this.
  15. Jan 30, 2018 at 12:52 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I would call as soon as possible, you have a 2004 and you have one of the last trucks to qualify for the 15 year recall depending on the in service date.
  16. Jan 30, 2018 at 5:19 PM
    Chopchop
    Nick
    Yes, been on the phone with the dealership and Toyota, got conflicting reports initially. Toyota initially said it was eligible for frame replacement..a call to the local dealer and they say it has been replaced. A call back to Toyota and they now say the frame has been replaced.
    So I’m back to looking at my besft options regarding this Tacoma.
    They say the criteria for replacing the frame is to hit frame with ballpeen hammer and if it goes through the frame then it is eligible for replacement then and Toyota will do it.
    I don’t have any areas where this is occurring.
    Hey, really appreciate the TW members and their input...it’s a bit lonely dealing with this rusty Tacoma, but you folks are encouraging.
  17. Jan 30, 2018 at 5:26 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    Wow, just can’t fathom that much rust on a ‘04- I just sold my 2002 and it was clean- difference between the rust belt and sun belt. I feel for you though, that must be heartbreaking to see your rig do that, some even starting out with signs at 2016! Anyways, I always liked these- Maybe you could do so much better than rebuilding that bed - make a red expedition rig with style:
    11Bguy and Toy4me like this.
  18. Jan 30, 2018 at 5:36 PM
    Chopchop
    Nick
    I’m open to any and all ideas.
    Thanks for the suggestion.
    I actually have two Tacoma’s. I’ve had my 96 for about 5 years it has just over 130k and has been rock solid, bought this 04 because it seemed a really good deal. Time will tell on that.
  19. Jan 30, 2018 at 5:40 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    You're saying Toyota said the frame on the '04 is brand new?
  20. Jan 30, 2018 at 5:41 PM
    OnHartung'sRoad
    Our 1985 was rust proof too when we sold it. We’re lucky out here in the desert for that, but have other issues like wire eating rats!!
