Wheel touch up paint?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bv8ma, May 4, 2018.
  1. May 4, 2018 at 7:19 PM
    bv8ma
    bv8ma [OP] Well-Known Member
    Bill
    MA
    2017 TRD OR
    I searched Google and the forums but can't seem to find the answer to this question, where can I get wheel touch up paint? I can call the dealer tomorrow to check, but is there any Amazon vendor (or other) that sells wheel paint for the TRD off road wheels?
  2. May 5, 2018 at 12:48 PM
    N2DesignsInc
    N2DesignsInc --------------------------- N2 Designs, Inc. Vendor
    Los Angeles, CA
    2018 that identifies itself as a 2021
    Mods: Is this still a Tacoma?
    In the past, I've used body type paint as touch up, but took many tries to find the right color...back n forth to Pep Boys..however, there are options out there, but most are alloy metallic which doesn't really matter the manufacturer they are made for, alloy is alloy but it will take trial and error, DupliColor is a good brand to start with and you can even call them and ask them if they have one for your wheels:
    https://www.autobarn.net/dupwpserie...MI4JX-n6rv2gIViK_sCh2wcwXoEAQYAiABEgJIUPD_BwE
    https://www.walmart.com/ip/Krylon-B...54589&wl11=online&wl12=47907913&wl13=&veh=sem
    https://www.amazon.com/dp/B00407X8IU/ref=twister_B01ITCRNE6?_encoding=UTF8&psc=1
    https://www.amazon.com/Dupli-Color-EHWP10107-Silver-Performance-Wheel/dp/B000B6DFZ0
    If it means anything, this is what I put into google: "alloy colored metallic wheel spray paint"
    Getting TOO specific in your search like "2017 TRD SPORT Tacoma Wheel paint" might limit or fail to show results in your search.
    bv8ma[OP] likes this.
  3. May 5, 2018 at 1:02 PM
    bv8ma
    Bill
    MA
    2017 TRD OR
    Ah ok so there isn't a specific Toyota color. In that case it sounds like I should go to a paint store and have them scan it and mix something custom, thanks for your help!
    N2DesignsInc[QUOTED] likes this.
  4. May 5, 2018 at 2:10 PM
    N2DesignsInc
    Los Angeles, CA
    By the way if you do have curb rash, there are mobile wheel repair shops out there that will grind it down, smooth it and spray it. The mobile guys charge around $100 per wheel, but dropping it off at a place that does it is around $60. If it’s just a chip then buy the spray, spray some onto a plastic bag and use a q-tip to dab.
  5. May 5, 2018 at 2:24 PM
    bv8ma
    Bill
    MA
    2017 TRD OR
    Ya it's just a couple real small chips, no rash.
