Wheel Specs
Discussion in 'Wheels & Tires' started by replica9000, Mar 18, 2009.
  1. Mar 18, 2009 at 8:15 AM
    replica9000
    replica9000 [OP] Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    Hey, I know I'm new, and everyone hates that new guy who comes in and wants to change something but I've noticed many, many new wheel threads pop up just in my short stay here. I was thinking that one way to alleviate this, and I've seen this done on many forums, is to sticky a thread with with the general information commonly used to answer all these repetitive threads. As a I start I'd like to propose a sticky on the specifications for the stock wheels available to Tacomas. Personally, I own a 2nd Gen with the 16" steelies, so I would need input from other members, but this thread can also be expanded to include info for 1st Gens as well. Useful information would be: diameter, width, offset, backspacing, weight and bolt pattern. Here is what I know so far:
    2nd Generation Tacoma:
    Base Steel Wheels: 15x6, +40 mm offset, ? backspacing, 5x4.5" bolt pattern, ? hub bore, ? lbs
    SR5 Steel Wheels: 16x7, +? mm offset, ? backspacing, 6x5.5" bolt pattern, ? hub bore, ? lbs
    TRD Sport Alloy Wheels: 17x7.5, +30 mm offset, 5.5" backspacing, 6x5.5" bolt pattern, 108 mm hub bore, ? lbs
    TRD Off-Road Wheels: 16x7, +32 mm offset, 5.25" backspacing, 6x5.5" bolt pattern, ? hub bore, ? lbs
    X-Runner Alloy Wheels: 18x8, +30 mm offset, ? backspacing, 5x4.5" bolt pattern, ? hub bore, ? lbs
    TRD Baja Alloy Wheels: 16x7, +? mm offset, ? backspacing, 6x5.5" bolt pattern, ? hub bore, ? lbs
    Ivan Stewart TRD Alloy Wheels: 16x8, +1 mm offset, ? backspacing, 6x5.5" bolt pattern, ? hub bore, 23 lbs
    TRD FJ Cruiser Allow Wheels: 16x7.5, +15 mm offset, ? backspacing, 6x5.5" bolt pattern, ? hub bore, ? lbs
    This list is far from complete but I will try to continue to update it if people offer up the needed information. Perhaps even expand this to include tire sizes as well?
    Hey guys. I'm going to clean up this post, make it more presentable, and keep it up to date. Going to try to get any specs I can for any 6-lug OEM wheels compatible with our trucks. Stay tuned...
    Steel Wheel
    Part# 42601-AD041 (42601-AD040)
    Dimensions: 16x7 +30mm??
    Weight: 30 lbs
    TRD Off-Road Wheel - 2nd Gen
    Part# 42611-AD031 (42611-AD030)
    TRD Sport Wheel - 2nd Gen
    Part# 42611-AD041 (42611-AD040, 42611-35270, 42611-35271, 42611-35280)
    Dimensions: 17x7.5 +30
    TRD Beadlock Wheel - Black
    Part# PTR18-35090
    Dimensions: 16x7.5 +10
    Weight: 23.5 lbs
    TRD Beadlock Wheel - Graphite
    Part# PTR18-35090GR
    Weight: 23.5 lbs
    TRD Beadlock Wheel - Bronze
    Part# PTR18-35090BR
    Weight: 23.5 lbs
    TRD Ivan Stewart Wheel
    Part# PTR20-34070
    Dimensions: 16x8 +01
    SR5 Alloy Wheel - 3rd Gen
    Part# 42611-04150
    Dimensions: 16x7 +25
    Weight: 25 lbs
    TRD Off-Road Wheel - 3rd Gen
    Part# 42611-04160
    TRD Sport Wheel - 3rd Gen
    Part# 42611-04170
    TRD Dark Anthracite
    Part# PT946-35160
    4Runner 3-Spoke Wheel
    Part# 42611-35140 (42611-35130)
    Dimensions: 16x7 +16
    Weight: 24 lbs
    Note: Does not fit 2005+ Tacoma
    4Runner TRD Sema Pro - Matte Black
    Part# PTR20-35110-BK
    Dimensions: 17x7 +04
    Weight: 25 lbs
    4Runner TRD Sema Pro - Graphite
    Part# PTR20-35110-GR
    Weight: 25 lbs
    ramy, 23MGM, MattiasdelTaco and 47 others like this.
  2. Mar 18, 2009 at 9:05 AM
    HOSS454
    HOSS454 Well-Known Member
    Pukalani
    08 Sport
    Bolt ons here and there
    TRD Sport wheels are actually 7.5" wide...
    biker639 and danmtchl like this.
  3. Mar 18, 2009 at 9:16 AM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    and if the administrators would make it a sticky they should do it in the first gen fourms too
    alarka and Boghog1 like this.
  4. Mar 18, 2009 at 9:21 AM
    Mazdayota
    Mazdayota Well-Known Member
    Mason, OH
    '09 SR5 4X4
    K&N Drop-in air filter
    Updated!
    I'm willing to add info on 1st Gens as well considering this is the Wheels & Tires section. I just don't know anything about 1st Gens :(
    ShiftyShank, Tundra2 and Geronimo1111 like this.
  5. Mar 18, 2009 at 4:30 PM
    epa4wd
    epa4wd Well-Known Member
    Eduardo
    2019 SR
    Clazzio Seat Covers OR Wheels 40% tint Side Steps KC Fog Lights
    Base Steel Wheels: 15x6, +40 mm, ? backspacing, 5x4.5" bolt pattern, ? lbs
    corywayne likes this.
  6. Mar 18, 2009 at 5:40 PM
    Mazdayota
    Mason, OH
    '09 SR5 4X4
    Got it! Wow, I never realized the offset was so high. That's nearly as high as the wheels on my Protege!
    Let keep the info coming guys!
  7. Mar 18, 2009 at 5:46 PM
    epa4wd
    Eduardo
    2019 SR
    You should add the X-Runner wheel
    X-Runner Wheels: 18x8, +30 mm, ? backspacing, 5x4.5" bolt pattern, ? lbs
    Squatcher likes this.
  8. Mar 18, 2009 at 5:49 PM
    Mazdayota
    Mason, OH
    '09 SR5 4X4
    D'oh! How'd I forget those. Updated again, thanks!
  9. Mar 19, 2009 at 4:26 AM
    Mazdayota
    Mason, OH
    '09 SR5 4X4
    Bump for more info!
    Geronimo1111 likes this.
  10. Mar 19, 2009 at 6:52 PM
    Mazdayota
    Mason, OH
    '09 SR5 4X4
    Late night bump for info!
    Or is this just going to die out...?
  11. Mar 21, 2009 at 8:00 PM
    Mazdayota
    Mason, OH
    '09 SR5 4X4
    I guess this died...
    Matt19703 likes this.
  12. Mar 21, 2009 at 8:04 PM
    epa4wd
    Eduardo
    2019 SR
    I hope not, this is the kind of information that people usually look for.
    BTH1, BatteredTaco and Geronimo1111 like this.
  13. Mar 21, 2009 at 8:19 PM
    Mazdayota
    Mason, OH
    '09 SR5 4X4
    ...and that's why I tried to put it together. I've been searching around online and I can't really find a lot of info. I'm just surprised there aren't more stickies here. I've seriously only been a member for a week and I've seen the same questions asked like 10 times!
  14. Mar 22, 2009 at 7:25 AM
    Lane Cypert
    Lane Cypert Well-Known Member
    Lewisville, Texas
    2008 silver prerunner double cab TRD
    I believe the offset on the TRD Sport rim is +30. That is what discount tire said at least.
  15. Mar 22, 2009 at 7:29 AM
    Mazdayota
    Mason, OH
    '09 SR5 4X4
    Thanks, I thought most of the stock wheels are +30 mm but I didn't know for sure. Just another of the reasons I wanted to put this together...
  16. Mar 23, 2009 at 9:15 PM
    TengoTaco
    TengoTaco Newb
    La Quinta, CA
    2020 OR 4x4 Manual
    8112, SPC, Elka 2.0 rear and Icon AAL. About 1.5”
    Anyone know 1st gen. wheel specs?
    Poncate, 04PreJogger and Tacoma04CA like this.
  17. Mar 25, 2009 at 1:49 PM
    Mazdayota
    Mason, OH
    '09 SR5 4X4
    Well I certainly don't know anything about 1st Gen wheels specs but I'm willing to put together a list. I just don't know where to start.
  18. Mar 25, 2009 at 1:53 PM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Consider it stickified.
    RevIza and ChadsPride like this.
  19. Mar 25, 2009 at 2:06 PM
    Mazdayota
    Mason, OH
    '09 SR5 4X4
    Awesome thanks! Now I know you aren't typically supposed to respond to stickies but I think an exception can be made in this case because the list is far from complete. With that being said, on with the information!
  20. Apr 23, 2009 at 8:49 PM
    leo08pirate
    leo08pirate Katzo production
    Leo
    Oceanside CA
    08 PreRunner 4.0L
    TRD exaust - Tinted Windows - TRD Intake - Alpine type S speakers
    confuse so what size do i have in my 2008TRD tacoma PreRunner access cab 4.0L 2WD
    i know their 16 but by what
    16 X ?
    So may i fit some 16x8 on my truck with my Bf goodrich Rugged trail T/A P265/70R16 (stock)
