Wheel spacers - Vibration after installing them
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Porroquio, Jun 1, 2020.
  1. Jun 1, 2020 at 10:00 AM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I only have 2 things…
    You get what you pay for &
    This is part the reason spacers have a bad rep; cheap versions have to cut corners somewhere (other being install error/over torqued lugs breaking studs).
  2. Jun 1, 2020 at 10:08 AM
    eurowner
    eurowner Duke Sky
    Scoty
    "Material: T6 Aerospace Grade Aluminum with 12.9 grade studs"
    Scott4032 likes this.
  3. Jun 1, 2020 at 10:43 AM
    Porroquio
    Porroquio [OP] IG: @porroquio
    Miami, FL
    2016 Magnetic Gray Tacoma SR5
    Yep, I bought this truck at hgreg, they told me that it was a trade in, therefore sold as is.
    No accidents, pretty good all around, this is the only issue I've had since I bought it. Maybe I wouldn't have noticed those cb were different if I didn't install the spacers..
    I'll send dropstars a message to see what they say.
  4. Jun 1, 2020 at 10:45 AM
    Porroquio
    Miami, FL
    I checked that this weekend, no scratches at all
  5. Jun 1, 2020 at 11:11 AM
    ericvega
    ericvega Well-Known Member
    Eric
    2019 MT TRD OR DCSB
    Magnusson Supercharger Kit RCI Skids C4Fab Sliders CBI BedRack Bilstein Bypass Shocks Icon RXT Leaf Pack
    Well that would imply that nothing is sliding around, so it must be tight enough.... so something else isn't lining up. Apologies if I missed it, but the spacer should have come with lugs, yeah? Did you use those to mount the wheel or to mount the spacer? When I installed my spacer it came with lugcentric lugs, even though it was a hubcentric spacer. These needed to be used for the spacer to hub mounting. Then, re-use the original wheel lugs for mounting the wheel to spacer.
    As some others commented, perhaps the lugs aren't properly centered on the bore of the hub. Definitely try moving the spacers between the front and back wheels and see if the vibes change.
    Porroquio[QUOTED][OP] likes this.
  6. Jun 1, 2020 at 11:17 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Spidertrax , Bora great products. Spend the money on great products Just my .2
    RelentlessFab and Porroquio[OP] like this.
  7. Jun 1, 2020 at 11:23 AM
    Porroquio
    Miami, FL
    Yeah, I like living on the edge
    Just kidding lol.
    I understand. If it were only for reputation, I would have never installed spacers on my truck as there are a lot of people saying they're bad.
    I got spacers for 2 reasons. The truck was heavily rubbing when turning, and I also wanted to have the wheels aligned with the fender flares. I don't go off-roading or put excessive stress on my truck, I only use for my daily commute.
    I decided to take the risk by trying these as they have pretty good reviews. Nonetheless, upon receiving them I literally looked for reasons not to install them. However,
    measurements from bolt length to hub thinckness where pretty good and matched exactly what I needed.
    I'll try Windigo's suggestion. If that doesn't work, I'll give Spidertrax a shot, and if that doesn't work either, I'll just leave my truck without spacers for now.
  8. Jun 1, 2020 at 11:26 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    Spidertrax will work
  9. Jun 1, 2020 at 11:41 AM
    Porroquio
    Miami, FL
    Thank you!
    Yes, exactly as you say. the spacers came with lugs that I used to mount them into the hub, then I used the stock lugs to mount the wheel on to the spacers, I took special care in centering the wheels, by gradually hand tightening them and making sure they were centered prior torquing.
    But I'll check that again when changing the position of the spacers this weekend.
  10. Jun 1, 2020 at 11:43 AM
    facefirst
    facefirst Well-Known Member
    Geoff
    Cleveland, OH
    2017 MGM TRD Off Road DCSB
    I run them with zero issues.
  11. Jun 1, 2020 at 12:48 PM
    ericvega
    Eric
    2019 MT TRD OR DCSB
    Sounds like you did everything correctly then, just need to narrow it down to see if it's a manufacturing defect. Good luck!
  12. Jun 1, 2020 at 1:53 PM
    synaps3
    synaps3 Wag more bark less
    Dave
    Los Alamos, NM
    2017 White SR5 4x4 DCLB
    SOS armor, ARE MX walk-in, Fox coils, Dakar leafs, etc
  13. Jun 1, 2020 at 2:12 PM
    Porroquio
    Miami, FL
    Thank you!
    I just saw that brand but I was afraid to ask, it also has pretty good reviews on the spacers I want:
    KSP 6X5.5 Wheel Spacers Fit for Tacoma 4runner, 1.5 inches Forged Hub Centric Adapters Kits fit 6 Lug Wheel, Package of 4, (B07DLX519N) https://www.amazon.com/dp/B06VWQHDTD/ref=cm_sw_r_wa_apa_i_.Xw1EbZNA4H7W
    Couldn't find spidertrax in 1.5inch, so the only one left is bora, which is the most expensive of all I have seen today. $250 plus tax and shipping..
    :rain:
    I'll keep doing my research while returning these.
    synaps3[QUOTED] likes this.
  14. Jun 1, 2020 at 2:18 PM
    synaps3
    Dave
    Los Alamos, NM
    Just make sure you get the extended lug nuts too. They're an added cost, but worth it.
    Nothing's wrong with spacers. The hate is unwarranted, and from people who have heard horror stories from improper installations. Use loc-tite with good torque settings as suggested in this thread already and you'll be fine. I check mine every time the tires are rotated and they've stayed tight. I tow a LOT and actually wheel mine, so these have been well-used under relatively tough conditions.
  15. Jun 1, 2020 at 2:21 PM
    #35
    boston23
    boston23 Well-Known Member
    Adam
    Bend, OR
    2019 SR5 DCSB 4x4
    I'd return those spacers stat.
    Saw a guy on instagram who had a cheap spacer crack on him and he almost lost a wheel on the highway.
    Porroquio[OP] likes this.
  16. Jun 7, 2020 at 9:23 AM
    #36
    Porroquio
    Miami, FL
    revtune and synaps3[QUOTED] like this.
  17. Feb 3, 2021 at 8:24 PM
    #37
    AlphaQ1ns
    AlphaQ1ns Well-Known Member
    2020 SR DBC V6 4x4
    I'm using these spacer for over a year and no issues.
