Wheel spacer vs offset wheel ride quality
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lamb_of_the_freefolk, Jun 22, 2020.
  1. Jun 22, 2020 at 7:52 PM
    Lamb_of_the_freefolk [OP] Well-Known Member
    Simcoe County, Ontario
    2014 TRD Sport DCLB 4x4
    Bilstein 6112/5160, Icon progressive AAL, JBA UCA, BFG KO2's, Method MR305 NV Bronze, Baja Design WC fogs, Prinsu Cabrack
    So, while waiting for SCS to come out with the -38 offset wheels I want, I decided to put on a set of 1.25" spidertrax wheel spacers on my 0 offset wheels to give me an offset of -32 and a really nice stance imo.
    However, ride quality has gone to shit (rough over bad road conditions) since the spacers have been installed and I was wondering if offset wheels would have the same effect to ride quality. If so, would high end suspensions, like fox with dsc or kings with dampening adjusters help with this?
    I'm running bilstein 6112/5160(600lb coils) right now. The ride quality was really good, before I installed the spacers, with only 0 offset wheels.
  2. Jun 22, 2020 at 9:49 PM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Are you referring to vibes or rough ride quality? Spacers shouldn't affect ride quality, just more stress on wheel bearings, especially if you are at 3.25" backspacing. What size wheel and tires to need a 3-3.25" of backspacing?
    Ch78 and b_r_o like this.
  3. Jun 22, 2020 at 9:52 PM
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    A wheel offset or spacer won’t affect ride quality...
  4. Jun 22, 2020 at 11:00 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    @Lamb_of_the_freefolk can you be more specific on why you feel ride quality has gone to shit? What is it doing now that it wasn't doing before?
    The additional unsprung weight and adding length to the distance between the frame and wheel without changing control arms and shocks will impact ride quality. It's like geometry and physics and sciencey stuff.
    FlowShow likes this.
  5. Jun 23, 2020 at 1:58 AM
    Just rougher going over ruts/bumps/cracks in the road. Not as smooth as before wheel spacers. No vibs. Was running LT tires with same psi before spacers too.
  6. Jun 23, 2020 at 2:10 AM
    Texas T
    Texas T Well-Known Member
    TX
    '14 T Force
    You might be tracking. UCAs will fix that. I had spacers for a bit and they fucked up my studs.
  7. Jun 23, 2020 at 3:03 AM
    I'm running high caster jbas right now. Rocking 3.4 caster, 0 camber, 0 toe on both sides. Can still bump caster to 4.5 if that would help? I thought increasing wheel base makes ride quality rougher?
  8. Jun 23, 2020 at 3:56 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    You need to start the troubleshooting process by removing the spacers and test driving it. Maybe just removing the front spacers first. What kind of lift and setting along with tire size and type?
  9. Jun 23, 2020 at 5:34 AM
    2.5" lift with 265/70r17 LT at 32 psi. I've been running this set up long before putting on the spacers. I did recently get an alignment done though. Went from 4.5 caster to 3.5 and -0.05 camber to 0
  10. Jun 23, 2020 at 5:46 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    I'm assuming you are running spacers to get a wider stance since that current tire size(31x10") does not need either lift or spacers. Ditch the spacers to see if they causing your issues.
    stickyTaco likes this.
  11. Jun 23, 2020 at 5:49 AM
    Yes it's just for a wider stance. Until i can grab a hold of some -38 offset wheels. Will take em off this weekend and see what happens. Right now, It's kind of turning me off from -38 wheels even though they look phenomenal
  12. Jun 23, 2020 at 6:07 AM
    DG92071
    DG92071 Well-Known Member
    Wheelbase is the distance from the front wheel centerline to the rear wheel centerline. Track is the width side to side.
    If the track is equal the ride quality with spacers and without spacers is exactly the same. If the track is equal the stress on wheel bearings is exactly the same with or without spacers.
    Matmo215 likes this.
  13. Jun 23, 2020 at 6:38 AM
    Wattapunk
    Uncle K
    TX
    2005 DCLB 4WD
    I would disagree with this if you are stating that wheel offset has no affect on the wear of the wheel bearings. 3.25" BS is on the extreme side.
  14. Jun 23, 2020 at 6:42 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    It’s all in your head man.
  15. Jun 23, 2020 at 8:20 AM
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    I was running spidertrax 1.25 spacers on mine with 2 inches of lift all around. I'm running the Baja shocks (pretty much the same as the 6112 but not height adjustable and a 650lb spring) with a half inch spacer on top and JBA UCA's. At first I was on stock OR wheels (they have a +25 offset) with 285/75/16 Cooper Discoverer AT3 XLT's and the ride was fine and I liked the way they sat but I had been running the spacers before I put the 285/75/16's on with the stock tires and never had any issues. I put on the TRD fake bead locks on which are +10 and right away I could tell they tracked really weird due to the increased track width. The only reason I left them on was to clear the UCA's. I took the spacers off to test it out and what do you know no more rubbing. At full lock I slightly rub on the UCA towards the front but I'm perfectly fine with it. I ended up leaving the spacers off and I like the stance it has. If I go bigger in tire size I will probably have to put them back on but we will see if I do go up to 295's or not. The biggest thing that I have learned from running spacers is make sure they are installed correctly and torqued correctly. I ran them for over 3 years with no issues. Sorry for long story hope it helps.
  16. Jun 23, 2020 at 1:17 PM
    Island Cruiser
    Island Cruiser TVita
    Kauai
    Baja
    295/75R16 BFG KO2’s on TRD beadlock style wheels fit the stock Baja suspension providing CMC, pinch weld and corner fender flare trimming have been done.
    Age315[QUOTED] likes this.
  17. Jun 23, 2020 at 1:18 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    This ^^^^^!!!
  18. Jun 23, 2020 at 2:35 PM
    Age315
    AJ
    Castle Rock, CO
    Your just trying to make me buy new tires aren't you?
  19. Jun 23, 2020 at 2:40 PM
    Island Cruiser
    Kauai
    Baja
    If this site made me spend money on shit I could live without I’m taking anyone I can with me lol
  20. Jun 23, 2020 at 2:42 PM
    Age315
    AJ
    Castle Rock, CO
    I hear you there!
