Wheel offset?!?!
Discussion in 'Wheels & Tires' started by LVtaco76, Jan 1, 2024.
  1. Jan 1, 2024 at 10:51 PM
    LVtaco76
    LVtaco76 [OP] New Member
    Hey new to the forums. Just bought my first Tacoma. 2021 TRD off road. I currently have the stock wheels with Falken wildpeak tires (265/70 r16). I’m looking to upgrade to 17” wheels with 265/70 r17 tires. I’m hoping to have the tires poke out enough to be flush with the fender or maybe a tiny bit more. This whole offset thing has me confused. How much of an offset would I need to achieve this? Any help would be greatly appreciated.
  2. Jan 1, 2024 at 11:11 PM
    mauctopa
    mauctopa Well-Known Member
  3. Jan 2, 2024 at 8:25 AM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Depends on your rim width mainly.
    Understanding what offset and even backspacing is will really only give you good results. Asking for opinions is like @$$holes... everyone has one.
    Offset is when you take how far your actual rim centerline is in relationship to a perfectly centered rim. Most fwd's have neg offset and rwd's generally more positive. More positive more poke
    . For example a 10 inch wide rim with 0 offdet would be centered. The same rim with -25mm (1 inch) would bave the center line offcenter (moved over) 25mm (1 inch). Or when measured would be 100mm (4 inches) inner rim lip to center line and 150mm (6 inches) outer rim lip to center line..
    To confuse things that is also 4" backspacing
  4. Jan 2, 2024 at 8:32 AM
    Mrcooperou812
    Mrcooperou812 Well-Known Member
    Las Vegas NV
    2016 DCSB OR 4WD
    Offroad stock wheels are 7" wide x 16" diameter, +25mm offset.
    A 1" wheel spacer (-25mm) will take the stock wheel to a zero offset position, which will be close to flush on those 265 width tires.
    I had the same situation with my 2016 OR but I ran 1.5" spacer for a couple months before buying new wheels at slight negative offset.
  5. Jan 2, 2024 at 8:47 AM
    Strictlytoyz
    Strictlytoyz Well-Known Member
    Charles
    HA\/\/AII
    07 Shitbox
    As everyone already said. The more negative of an offset you go the further out the tire will be. Take a measurement for where you want your tire to sit and go from there. For example if your current wheel is a +25 offset and you measure and need the wheel to be 2" further out, convert that 2" to mm and subtract from current wheel offset. So +25mm minus 2" (roughly 50mm) = -25mm offset wheel to sit where you measured to
  6. Jan 2, 2024 at 9:02 AM
    PirateMica
    PirateMica Well-Known Member
    2014 Pyrite Mica SR5
    My stock wheels were a +30 with 245s. I upgraded to a 0 offset with 265s. Here's the result.
    Tan Ten Ten likes this.
  7. Jan 2, 2024 at 9:08 AM
    1 Limited Toyota
    California
    08 XRunner
    Backwards. Its ez to do
    The more negative -, the more INset the wheel
    The more positive +, the more "poke"
  8. Jan 2, 2024 at 9:10 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Negative ghost rider
  9. Jan 2, 2024 at 9:21 AM
    1 Limited Toyota
    California
    08 XRunner
    Negative on the negative.
    0 offset = centered
    Negative - offset (most fwd rims for example) sit with centerline inset or negative "poke",
    Say -25mm is normal offset
    -45mm would be way inboard
    Thats why fatter than o.e. rims generally have more negative - offset to spread the additional width
  10. Jan 2, 2024 at 9:31 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
    Are you saying a 17x9 wheel with +25mm offset will sit further out than the same wheel with a -38mm offset? Riddle me that
  11. Jan 2, 2024 at 9:33 AM
    1 Limited Toyota
    California
    08 XRunner
    Strictlytoyz likes this.
  12. Jan 2, 2024 at 9:33 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    You might want to double-check that. You're visa-versa on negative vs positive. Stock OR 16" wheels are +25mm, stock 17 and 18" wheels (non-pro trims) are +30mm. Most Pro wheels are +4mm
    Most TW members prefer either +4, 0, or -10 offset. Going too negative with a wide tire will kick gravel into your own paint.
    Here's a fun comparison. These are the same exact tires, same exact suspension. 265-70/17.
    Stock wheels are +30, the 4Runner wheels are +4mm. Notice that it pokes more with a delta negative 25.
  13. Jan 2, 2024 at 9:34 AM
    Strictlytoyz
    Charles
    HA\/\/AII
    07 Shitbox
  14. Jan 2, 2024 at 2:09 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Super easy. 17x8 0 offset and call it good.
    JdMeF9SiR2 likes this.
  15. Jan 4, 2024 at 2:58 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
    Here is an additional LINK that might help clarify how offset works.:thumbsup:
    Jeffch likes this.
  16. Jan 12, 2024 at 10:30 AM
    JdMeF9SiR2
    JdMeF9SiR2 FN Wheels
    Corona, CA
    05 Tundra 06 Tacoma 14 FJ Cruiser 19 Tundra
    Agreed. I always recommend 16x8" +0mm or 17x8" +0mm to achieve the look and fit that @LVtaco76 described. This is about as optimal as it gets for the 2005-2023 Tacoma.
    8" rim width with +0mm offset maintains the ride quality and drivability. There is minimal (if any) rubbing with 265/75R16 or 265/70R17 tires, and the rubbing is easy to remedy should you have any.
  17. Jan 28, 2024 at 12:41 PM
    HCorps
    HCorps Member
    2023 Tacoma SR5 Double Cab 4 Door Short Bed.
    Would there be an issue (alignment, tire rod wear ect) with putting 18x9 wheels with 265/60/18 tires on a 2023 toyota tacoma 4 door 4x4? What, if any, wheel offset would I need? Thanks in advance. Right now the 245/75/16s have so much tire flex I think I am in a 1977 cadillac.
  18. Jan 29, 2024 at 7:18 AM
    Asc_0989
    Asc_0989 Well-Known Member
    Andrew
    2020 Tacoma Sport 4x4
    I’m running -10 off set and it has alittle poke and I’m still able to tuck my tires without ripping my fender flares off.
  19. Jan 29, 2024 at 12:21 PM
    HCorps
    HCorps Member
    LOL! I think you have a little more lift than I do. The firestone destiny tires just have so much tire flex. All online sites show that very small difference between the ride height of 245/75/16's and 265/60/18s. Its the rubbing Im concerned about. What if any offset on 18x9 wheels should I get?
  20. Feb 1, 2024 at 3:02 PM
    JdMeF9SiR2
    Corona, CA
    For your 2021 Tacoma :
    18x9" +0mm offset fits perfectly with 265/60R18 tires.
    An offset that is higher than +0mm on a 9" rim width (i.e. excessive positive offset) will put the wheel/tire too close to the upper control arm, particularly if you install wider tires in the future. Technically you could get away with something between +0mm and +6mm (maybe even a few millimeters higher than +6mm on the offset) with tires that are only 265mm wide, but if you ever want to go up to 285's in the future you'll want +0mm offset otherwise you run the risk of the tire rubbing on the inside.
    On the other hand, too much lower of an offset (i.e. negative offset with 9" rim width) will cause your tires to rub on the front bumper and/or backside of the wheel well, which in turn will require trimming and possibly other modifications.
    18x9" +0 with 265/60R18 won't cause any issues.
    I'll try to come up with a picture of that exact set up for you (18x9" +0 with 265/60R18 on a 3rd Gen Tacoma), but in the meantime here's a good picture sent to us by one of our customers who has a mild lift and 275/65R18 tires with our 18x9" +0mm BFD flow formed wheels (thank you to the customer for the picture!):
    Bryan R 2016 Tacoma Black 18x9 BFD flow formed matte bronze Cooper ST Maxx.jpg
