Wheel Hub Dust Cap Damaged; Required?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MolonLabeTaco, Oct 22, 2018.
  1. Oct 22, 2018 at 2:52 PM
    MolonLabeTaco
    MolonLabeTaco [OP] Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I dented the piss out of one of my wheel hub dust caps replacing my wheel bearing the other day. I can't see what it keeps dust or dirt from but I guess some muddy water could get in behind it then work it's way past the splines then get into the wheel bearing, but that seems very highly unlikely. It's $19 to replace but I will if necessary.
    Does this actually provide any protection or no need to replace it?
  2. Oct 22, 2018 at 3:00 PM
    danbow
    danbow Member
    Daniel
    Texas
    18 F150 Crew 4x4
    To me it seems like cheap insurance against early wheel bearing failure considering time/labor plus parts to replace the hub/bearing assembly. I can't say that those caps do a whole lot, but Toyota thought we needed them.
  3. Oct 22, 2018 at 3:02 PM
    jp_flynavy
    jp_flynavy IG: @TrailLimoOverland
    2015 Tacoma DCLB
    It will keep any water out that's for sure. I have a small dent in my drivers side and compared to my passenger side, I can see difference. I applied some rtv on the dent to keep the crap out.
  4. Oct 22, 2018 at 3:03 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I would replace it. I've popped off peoples virgin dust caps, and it looks brand new in there.
    Mine has a big dent in it from me impatiently prying it off. A few months later I popped it off again and there's a light surface rust everywhere. I'd replace it if I were you.
  5. Oct 22, 2018 at 3:12 PM
    Taco'09
    Taco'09 Well-Known Member
    The thing is you have not lived a full life until you have tried to remove a CV shaft that has rusted its splines inside the hub. I had to use a 10 lb. sledge to get a rusted CV out of a Subaru one time. It ruined the CV, wheel bearing, hub, and made the knuckle suspect too. Very expensive.
  6. Oct 22, 2018 at 3:19 PM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    Well, that settles it. I'll order a new one! Thanks.
    fla_sun likes this.
