Wheel damage after mounting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Theshortbusmafia, Mar 23, 2018.
  1. Mar 23, 2018 at 4:14 PM
    Theshortbusmafia
    Theshortbusmafia [OP] Well-Known Member
    Justin
    2017 Tacoma Offroad
    So I took my BRAND NEW, straight out of the box R8 wheels get mounted at a shop today. After getting them back I noticed they had completely wrecked my Sh**
    Scratches on the bead lock, dented the center caps and damaged to the inside of the wheel surface (back side) if that wasn’t bad enough I could litterly take my pink and lift the weights used to balance the wheel from the wheel itself.
    The manager was out but I’m speaking with him tommmrow. What chance do i stand of having them replace th entire damaged wheels in lieu of taking them to a wheel shop for repair? 63A43243-F055-4E21-8C2C-9C7A068BE595.jpg414914D7-0E81-463A-8FE3-4862C17EC87B.jpg
  2. Mar 23, 2018 at 4:26 PM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    So a guy I work with had a set of new wheels not Toyota wheels and the idiot mounting tires bent the bead on a wheel it leaked and was visable.
    The dealer same as me refused
    to do anything!!! Aholes,
    Good luck man!!
  3. Mar 23, 2018 at 4:31 PM
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    Sue the bastards.
    wirenut likes this.
  4. Mar 23, 2018 at 4:40 PM
    SWB Tacoma
    SWB Tacoma Well-Known Member
    Arkansas
    2017 Tacoma Limited DC AT SB 4x4
    You got inspect your stuff while it is there. Not just wheels, whole vehicle.
    9th likes this.
  5. Mar 23, 2018 at 4:42 PM
    toyotatacomaTRD
    toyotatacomaTRD Senior Member
    Grab a sharpie and call it good. The more you go to a tire shop, the worse they'll be. With black, you can fix easily and you won't see unless you look up close.
    9th, 4WALKER and 1bad2k like this.
  6. Mar 23, 2018 at 4:44 PM
    Theshortbusmafia
    Justin
    2017 Tacoma Offroad
    Every pic except the center cap was taken at the shop before I left with the tech standing right next to me. Thanks for the advice, Dad. But that doesn’t answer my question...
    jamonsote likes this.
  7. Mar 23, 2018 at 4:45 PM
    Theshortbusmafia
    Justin
    2017 Tacoma Offroad
    Is the damage to inside of the wheel normal when mounting? I don’t think I’ve ever seen that before but this is mj first set of brand new wheels.
  8. Mar 23, 2018 at 4:53 PM
    Stash419
    Stash419 Well-Known Member
    Ohio
    2017 Black SR5 AC V6
    Ongoing Process
    F@&k that!! Definitely should be replaced. That’s why they have insurance! If I go into someone’s yard with my skid steer and hit their house I’m responsible, hence why I pay out the ass to cover my ass.
  9. Mar 23, 2018 at 4:56 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    That's why we can't have nice things.
    Theshortbusmafia[OP] likes this.
  10. Mar 23, 2018 at 4:57 PM
    Doggman
    Doggman Well-Known Member
    Alabama
    2017 TRD OR MT
    This is pretty common really. The dented center cap is maybe worse than normal but the other stuff happens more times than not. Gotta find a shop who knows what they have their hands on and how their customer feels about them. Talk to them before you let them do the work. If you let them know up front you're gonna have an issue if they're damaged they will either turn down your business or take their time with em.
    At this point I'd say the most you could possibly get is a new center cap and an offer to have the wheels repaired some where. Highly doubt they will replace any of those wheels.
  11. Mar 23, 2018 at 5:01 PM
    bassgoboom
    bassgoboom New Member
    Atlanta, GA
    I would say this is not normal. I just had a set of black TRD pro 4Runner wheels installed this week and there is not a scratch on them. I checked their equipment before install to make sure they had plastic shields on all their tire changing equipment. From past experience they will probably make you go to a wheel repair place.
    remgu2000 likes this.
  12. Mar 23, 2018 at 5:03 PM
    tacotroy17
    tacotroy17 Well-Known Member
    Dustin
    SoCal
    2017 DCSB TRD-OR
    I had my shop inspect each rim before install. I talked to the owner and he said he had a guy that fixed damage like this if it ever happened. He said more often than not that guy is fixing damage done by other shops that refuse to fix their mistakes.
    tcjacado likes this.
  13. Mar 23, 2018 at 5:04 PM
    SWB Tacoma
    Arkansas
    I'm not your dad. But, I have worked at a tire shop for 20 years. Take pictures of what you are getting worked on before you have it done. How are you going to defend yourself if he says. He doesn't know if his guy did that or not? Believe me, I have seen it several times over years.
  14. Mar 23, 2018 at 5:08 PM
    tcjacado
    tcjacado Well-Known Member
    I am sure there is a sign or a clause in the paperwork you signed before having them do the work.... probably reads something like this. "We are not responsible for damages gen mounting a tire on a aftermarket rim."
    Good luck
    9TRDTCO and shakerhood like this.
  15. Mar 23, 2018 at 5:14 PM
    trazerr
    trazerr Well-Known Member
    Oregon
    2024 Tundra Plat 4x4 LB (prev 2018 DCLB SR5 4x4 and 1996 AC LX 4x4 5sp)
    Definitely not how it worked/works at LS. Nothing signed before. The only thing you signed was for your CC company when you were paying for the work (after completed). Not sure how it works at other wheel/tire stores though.
  16. Mar 23, 2018 at 5:18 PM
    tcjacado
    Out here you have to sign a estimate of the work being performed.
    tomwil and the.sight.picture like this.
  17. Mar 23, 2018 at 5:19 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    I don't believe I had to sign anything when mine were installed.
    tcjacado[QUOTED] likes this.
  18. Mar 23, 2018 at 5:21 PM
    tcjacado
    That maybe, but i will almost guarantee there is a sign hanging in the shop that states, not responsible for damage.
    4WALKER likes this.
  19. Mar 23, 2018 at 5:23 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    I bet there are places like that. I know at the shop I went to the owner said he takes full responsibility if they do any damage.
    shakerhood and tcjacado[QUOTED] like this.
  20. Mar 23, 2018 at 5:41 PM
    tacotroy17
    Dustin
    SoCal
    2017 DCSB TRD-OR
    The wheels should be checked before they do it. If you check after they could say it wasn't them.
    hiPSI likes this.
