Wheel Bearings Changed (Pictures)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Taco93, Apr 25, 2011.
  1. Apr 25, 2011 at 11:18 PM
    Taco93
    Taco93 [OP] Well-Known Member
    Milton, Ontario
    2011 TRD Sport
    Extang Trifecta Tonneau, Weathertech Floor Liners
    So after ranting about my front bearings for a while now I finally had the chance to finish the passenger side today. I decided to take a few pictures to show the procedure as well as the procedure for changing the inner seal.
    So here goes:
    First the is the inital picture with just the tire removed:
    Next I removed the caliper by removing the two bolts you see in the center of the picture:
    Before moving the caliper I disconnected the brake line from the steering knuckle so I could move it all out of the way (the center bolt):
    So with the caliper moved and tied out of the way:
    To remove the rotor I had to use a threaded bolt to assist in pushing it away from the hub:
    Rotor removed, the next step was to remove the hub grease cap (I found this difficult to do without damaging the cap a little) :
    Once the cap was removed, it was time to remove the cotter pin, lock cap and axle hub nut, I used a 36mm impact socket to remove the nut:
    Pin, lock cap, and hub nut removed:
    The next step was to loosen the four bolts that keep the bearing assembly attached to the spindle. I didn't take pictures of this step as it's pretty straight forward. You have to tap the hub/bearing assembly loose once the bolts are loosened. Tap it on each side, and on top and bottom. I used a rubber mallot for this part. Once the assembly is partially out you'll have to unscrew the 4 bolts the rest of the way out as there isn't enough room between the bolt heads and the hub to initally take em out all the way out. Once the hub/bearing assembly is removed the dust shield just falls away, don't forget to reinstall the dust shield when putting back together. Also at this step I disconnected the speed sensor and put it out of the way.
    Hub/bearing assembly removed:
    I wanted to change out the inner seals as well but in order to do that I needed to swing the whole steering knuckle section that the axle sticks out of in order to have access to the inner seal. I needed to remove the stabilizer link from the steering knuckle, I used a wrench and a 6mm hex wrench to hold the stud because the ball joint was turning with the nut:
    Next I removed the two bolts and separated the front suspension lower arm from the front axle:
    I should mention that when I was doing this I had a hydraulic jack supporting the front axle, not sure if needed but I wanted to be sure:
    Once the 2 bolts were removed I could swing the steering knuckle:
    Removed the old inner seal, it was in rough shape:
    New inner seal installed, tight fit, careful not to damage it:
    The steering knuckle back together, seal greased up and axle cleaned and ready for the new bearing/hub assembly:
    New hub/bearing assembly, I had a shop remove the old bearing, install the outer oil seal and press on the new bearing (note that the o ring is not installed on the bearing in this picture, I forgot to install it so I had to take the whole thing apart again, DO NOT FORGET THE O RING) :mad::
    Bearing/Hub assembly, speed sensor, dust shield, hub nut, lock cap and cotter pin installed:
    Everything back together:
    The truck now rides like a dream again, I was optimistic that the hum would still be present but no, changing these bearings solved it.
    I want to thank tacomaworld.com for helping me do this. If it wasn't for all your help, I would have never even attempted this. Thank you :)
    ucdbiendog and Ryleyh like this.
  2. Apr 25, 2011 at 11:27 PM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    You fucking rock. Rep sent.
  3. Apr 25, 2011 at 11:53 PM
    ColtsTRD
    ColtsTRD Well-Known Member
    Scott
    AZ
  4. Apr 25, 2011 at 11:56 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Nice write-up, but is all that rust on your suspension and frame normal for a 5 year old truck?
  5. Apr 25, 2011 at 11:59 PM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    I didn't even stick around to watch them do the bearing. They had it for over an hour so I just went home and picked it up later. They charged 40 bucks per side to remove and reinstall the bearing.
  6. Apr 26, 2011 at 12:00 AM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    No it's not normal, thats what the salted roads and the canadian winters give ya. :(
  7. Apr 26, 2011 at 8:15 AM
    romafern
    romafern Hug diz nuts
    Rob
    80918 Let's meet!
    Paid for and saving a shit ton of $$$$$
    Thinking of adding a second battery...
    OH TACO!!!!
    You rock brother! Thanks for posting these pics along with the write up. Rep sent. My mileage is just barely 35xxxx but I will print your write up for reference.
    Any pics of the old bearings? You should send a pic to corporate.
    Well done!
  8. Apr 26, 2011 at 10:27 AM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    Hey Thanks, No I didn't get any pictures of the old bearings. I did ask the shop to let me see them, the insides where pretty rusty and the shop did one hell of a job getting them off, he had the whole bearing assembly sliced through and it looked pretty mangled...but lets hope these last a while.:)
  9. Apr 26, 2011 at 11:27 AM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Great write up :thumbsup:
    Only thing I would do differently is use a jack stand to support the axle as I don't think the lifting jack is very safe (its got wheels).
    Thanks for the great pics.
  10. Apr 26, 2011 at 1:07 PM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    Thanks for the info, I had the wheels chocked, jack stands under the frame, a 3 ton hydraulic jack to raise the truck and I used the smaller lifting jack to just support the axle. I thought it was safe, but in the future I'll probably take your advice. Thanks
  11. Apr 26, 2011 at 1:31 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    STICKY
    Great write up, great photos!
  12. Apr 26, 2011 at 1:33 PM
    kite
    kite Well-Known Member
    Squamish, BC
    Red Truck
    How much were all the parts?
  13. Apr 26, 2011 at 2:04 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    badass!! you are awesome.
    (how do i send rep?)
  14. Apr 26, 2011 at 2:44 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    In Atlantic Canada it is, salt on roads, close to the Atlantic Ocean...thats normal for these parts. hell I got a 07 and you can`t even see black on mine... we will undercoat on a yearly basis
  15. Apr 26, 2011 at 2:53 PM
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Nice write up! This will probably come in handy in the future. :) Rep sent.
  16. Apr 26, 2011 at 3:08 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    (how do i send rep?) Left side bottom under his TW name there is a white thing a blue thing and a triangle thing - it's the white thing.
  17. Apr 26, 2011 at 3:43 PM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    40 bucks per bearing on ebay + shipping 107$
    2 x inner and 2 x outer oil seals from part source 70$
    machine shop to press in 2 bearings 80$
    O ring from Toyota 9$
    Total 266$
    Midas quoted me 800 for 2 bearing changes
  18. Apr 27, 2011 at 6:15 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    Nicely dont man! :thumbsup: I just hit 55k so ill keep this link handy. Is it just a noise that signifies it is going bad?
  19. Apr 27, 2011 at 7:18 AM
    Dean25
    Dean25 Active Member
    Fort Polk, LA
    Nice write up! Im saving this one to do the same soon
  20. Apr 27, 2011 at 10:32 AM
    Taco93
    Milton, Ontario
    2011 TRD Sport
    Yeah, I was hearing a whirring noise that got louder as I sped up, plus I had Midas do a free inspection. They confirmed that it was in fact the bearings that were gone bad!
