Wheel Bearing Replacement Advice
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BrokeCollegeKid, Sep 5, 2023.
  1. Sep 5, 2023 at 2:50 PM
    BrokeCollegeKid
    BrokeCollegeKid [OP] Member
    Cormac
    2006 Silver Access Cab Tacoma [4WD, Manual]
    Camping shell, sleeping platform, and mattress in the bed.
    I just got my maryland safety inspection on my '06 (163000 miles) done and they failed me because my front left wheel bearing is loose. It definitely is but I have a few questions.
    1. I have limited tool access at school. I have jack and jack stands and a basic wrench/ratchet set. Can i even do this on my own?
    2. If I can't is this a part that i should make sure gets replaced with an OEM part? or does it matter?
  2. Sep 5, 2023 at 2:54 PM
    Merling
    Merling Well-Known Member
    James
    NH
    2021 Black Tacoma TRD OR
    RCI IFS Skid Eibach Stage 2 Explore Overland Sliders
  3. Sep 5, 2023 at 2:58 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Is a 35mm socket part of your basic tool set? Axle nut, I believe, is 35mm.
    I feel with a basic tool set there will be many knuckle busters and F bombs thrown around but it's doable.
  4. Sep 5, 2023 at 2:58 PM
    Merling
    James
    NH
  5. Sep 5, 2023 at 3:01 PM
    2ndhandTacoman
    2ndhandTacoman Well-Known Member
    Walter
    Maryland
    '15 Base AC 4x4, 2.7 powerhouse
    3rd gen TRD OR suspension
    You need the big 35mm socket for the axle shaft nut and a torque wrench that goes to 175#'s to properly torque it. I recently did one on my '15 Taco in the driveway in about 1.5 hrs. I used a Carquest hubset unit, as there were only a few options for parts around where I live. The local stealership would have taken 2 days to get on.
  6. Sep 5, 2023 at 4:45 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    This is also something your local national brand Auto Parts store should rent you
  7. Sep 5, 2023 at 5:09 PM
    Alealexi
    Alealexi Well-Known Member
    Houston, TX
    2007 Tacoma Prerunner
    There is only 7 bolts and 1 nut you need to remove and it is easy to do.
    Unbolt the ABS sensor x1 , caliper bolts x2, Axle nut x1, then the 4 bolts holding the hub assembly to the knuckle. If you want a prebuilt assembly you can get them on rock auto. The SKF brand is well known and a reputable brand.
  8. Sep 5, 2023 at 5:12 PM
    Tiedie
    Tiedie The Only Shantytown Resident.
    David
    WFOY
    Katzkin, Dobinsons full suspension. Redlinegoods console cover and door panel arm rests, Double USB charger in dash installed, Ballistic Jesters 16x8. BlackVue DR 590 Dash Cam
  9. Sep 5, 2023 at 6:39 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
  10. Sep 5, 2023 at 8:16 PM
    BrokeCollegeKid
    Cormac
    Does it being 4wd complicate things at all? also here's the part I'm looking at right now. Does that look right?
  11. Sep 5, 2023 at 8:41 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    It being 4WD doesn’t complicate it at all.
    That part linked, looks correct.
  12. Sep 5, 2023 at 9:28 PM
    gkomo
    gkomo Well-Known Member
    San Diego, CA
    2014 MGM AC SR5 4x4
    It doesn’t complicate things but I did make the mistake of not seating my CV axle correctly in the new hub assembly the first try when I did mine. Caught it as I was tightening the axle nut, just something to think of.
  13. Sep 5, 2023 at 10:52 PM
    Desert Dog
    Desert Dog Well-Known Member
    Los Gatos
    2007 DCSB
    Work in progress
    You may want an 1/2” impact gun to help get the caliper bolts off. These are likely to have a lot of rust on a 2006 truck. The 35 mm nut is behind a metal cap so should not have rust but impact gun will help here for removal. Per link you included, only use impact gun to loosen and not tighten bolts.
    Other thing you need is a small chisel or sacrificial screwdriver to pry off the metal cap over the 35 mm nut and a rubber mallet to reinstall. It’s thin material so don’t get too aggressive with it or you’ll be back at parts place for a replacement cap.
    Geeves77 likes this.
  14. Sep 6, 2023 at 6:29 AM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    I don't think I'd trust a $60 hub and bearing. I'd recommend the hub and bearing set sold by the TW member. All quality parts.
  15. Sep 6, 2023 at 6:30 AM
    diesel305
    diesel305 Active Member
    miami, fl
    2011 tacoma prerunner DCSB trd sport
    Go to rockauto.com and buy the skf brand, already comes assembled with hub so all u do is r/r and its only like around $110
    wayupnort and Geeves77 like this.
  16. Sep 6, 2023 at 6:45 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Anybody have any experience with Bluepit bearings?
    -J
  17. Sep 6, 2023 at 6:45 AM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    wayupnort likes this.
  18. Sep 6, 2023 at 6:47 AM
    wayupnort
    wayupnort Well-Known Member
    Agree 100%
  19. Sep 6, 2023 at 7:00 AM
    BrokeCollegeKid
    Cormac
    seems like the consensus is the SKF brand. I found this part ($96)
    i also found this DORMAN part ($116)
    and this WJB part ($114)
    can I go wrong with any of these? do I get what I pay for?
  20. Sep 6, 2023 at 7:11 AM
    BrokeCollegeKid
    Cormac
    Also would you all recommend replacing both front bearings? I assume if the driver side is gone the passenger cant be too far behind.
