Wheel Bearing needs replacing. Oem or other?
Discussion in '1st Gen. Tacomas (1995-2004)' started by bodhi armor, Aug 10, 2021.
  1. Aug 10, 2021 at 4:25 PM
    bodhi armor
    bodhi armor [OP] 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    Hey TW
    My 02’ Tacoma needs a front passenger wheel bearing replaced very soon. Lots of noise coming out of there!
    My mechanic quoted $300 labor on each side!! Wowee !! That is to be expected I suppose, but right now it’s a kick in the pecker!
    The Toyota dealership quoted about 115$ for an oem bearing, while Oreilley quoted $70 for a “Mastercraft” full wheel hub assembly with a new bearing already installed, which would make it a bolt in part and save a ton of labor cost, not to mention the parts cost.
    I assume that the “Mastercraft” option is not a good idea. I’ve never heard anything good about that brand..
    Just before someone jumps up on a soapbox about oem vs aftermarket, I know nothing stacks up to oem. Thanks anyway..
    Only one side is making noise. My truck has 290K, Should I go ahead and replace both bearings, Driver and passenger, to ensure both wheels are rolling smoothly?
    B: Due to the amount of noise coming from the bearing I’m concerned I’ll have to replace the wheel hub anyway.
    Is there a high quality wheel hub replacement with the bearing already installed that won’t break the bank?
    I replaced my lower ball joints recently with “555’s” per recommendations from TW. Maybe they make this part...
    As always..
    Thank you in advance for any good advice!!
  2. Aug 10, 2021 at 4:42 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    That MasterCraft is for 2nd Gens.
    $300 is legit
    Abeyancer likes this.
  3. Aug 10, 2021 at 4:48 PM
    Black DOG Lila
    Virginia
  4. Aug 10, 2021 at 7:07 PM
    DashMaple
    DashMaple Well-Known Member
    Louisiana
    01 V6 4wd PreRunner DCSB OME lift
  5. Aug 10, 2021 at 7:18 PM
    JudoJohn
    JudoJohn Well-Known Member
    St. Louis
    96 Tacoma 2WD 5 speed
    I would try to get OEM from RockAuto.
    AODRN likes this.
  6. Aug 10, 2021 at 8:39 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    I’m you’re huckleberry for a complete bolt up package deal shipped to your door with all OEM parts just shoot me a PM.
    Area51Runner likes this.
  7. Aug 10, 2021 at 8:40 PM
    ROAD DOG
    ROAD DOG Well-Known Member
    2019 I4 WHITE SR PRERUNNER
    FEW
    not so much anyone is throwing shade
    290k is a lot o miles
    the thing replacing oem with oem expectations are usually reasonable & realistic
    fronts are easy.........U could save alot o money
    yet if U dont use oem’s a second crack at same issue down the road
    U wont have saved ANY $$$$$
    TACOTU3 likes this.
  8. Aug 10, 2021 at 8:45 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    High Noon and eon_blue like this.
  9. Aug 10, 2021 at 9:13 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    No, for sure, there is no manufactured setup off the shelf assembly that I have found yet. And, shamefully, I have learned the hard way on pressing in the bearings. YouTube makes it look way easier, but I have done enough now to have a good system even though destroying an OEM bearing is a painful sunk cost to swallow.
    swellcat and (deleted member) like this.
  10. Aug 14, 2021 at 7:20 AM
    leid
    leid Well-Known Member
    Brandon, MS
    1997 V6 Tacoma 4x4 & 2020 V6 Tacoma TRD 4x4
    ECGS & ZUK diffs w lockers/Marlin R150F/NITRO axles/winches
    OP,
    I am changing both my front wheel bearings on my '97 TACO 4WD right now: Front Wheel Bearings on '97 V6 TACO 4WD 5 speed w Manual hubs | Tacoma World. This will be FW bearing set number 4 in this '97 TACO. Still waiting on the seals and other small parts to arrive from toyotapartsdeal. My advice is either do an exchange with zippsub9 or buy the KOYO bearings off ebay for $140 a pair shipped and have your mechanic change the bearings/seals in your knuckles. These are the same OEM Toyota/KOYO DU5496-5 "Made in Japan" bearings that Toyota will sell you: Toyota Tacoma 95-04 Tundra 00-06 4Runner 96-02 Front Wheel Hub Bearing KOYO PAIR | eBay Bearings are very important but so are the seals especially if you 4 wheel in deep mud/high water like I do. Buying the OEM seals off ebay may also save you money. Some OEM Toyota seals, which are also made by KOYO, have now gotten crazy expensive such as the seal on the inner side of the knuckle (90316-69001). If I had to use bearings/seals other than OEM Toyota/KOYO, it would be TRW or NATIONAL from Rockauto. HTH
    EDIT: I gave the "Made in JAPAN" 555 LBJs a try on my TACO mud machine because they were greaseable. They were a good value & lasted thru 8 years of severe use in deep mud/high water 4 wheeling here in MS. But I am going back with the OEM Toyota LBJs for their added strength/durability. Greasable '97 Tacoma 4WD Ball Joints? - YotaTech Forums
    zippsub9 likes this.
