Wheel bearing life expectancy?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by three west, Aug 6, 2013.
  1. Aug 6, 2013 at 6:38 PM
    three west
    three west [OP] Well-Known Member
    JD
    UP MI
    09 DC SB TRD Sport
    Hey guys, my 09 DCSB with 34k on the clock has a pronounced left turn growl.
    Stock suspension, stock sport wheels running BFGs.
    What the heck?
  2. Aug 6, 2013 at 6:40 PM
    texascolt45
    texascolt45 Well-Known Member
    mike
    groves texas
    prerunner 4 cylinder
    wheels,bilsteins,side bars
    damn I got 115,000 on my 09 prerunner.the bearings still sound ok.you sure its bearings?
  3. Aug 6, 2013 at 6:46 PM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    You sure is not your CV joints? Bearings make noise all the time when picking up speed.
  4. Aug 6, 2013 at 10:44 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Running through lots of water will wash out the bearings and shorten the life. The same goes for the universal joints.
  5. Aug 6, 2013 at 11:02 PM
    Shaners
    Shaners Offroad Legion
    Shane
    Mountains Central CA
    2004 Long Travel Tacoma
    Panty Delete Kit
    Jack the front end up, grab your tire at 12 o'clock and 6 and push and pull to see if there's any play. If there isn't then grab the tire at 9 o'clock and 5 and do the same. There should only be very minimal play. Make sure your tie rods are tight too and that there are no leaks from anything.
  6. Aug 7, 2013 at 7:22 PM
    three west
    JD
    UP MI
    09 DC SB TRD Sport
    Nope, not sure it's bearings.
    I checked the CV boots and they are fine on the outside.
    Jacked it up and no excessive play according to my finely calibrated hands.
    Maybe a dragging brake pad?
    No time to mess around with it myself, taking the bike for a few days and it goes to a shop Monday.
  7. Aug 7, 2013 at 7:25 PM
    That Dude Tim
    That Dude Tim Toyota Technician
    Elyria, OH
    11 TRD Sport 4x4 DCLB
    Falken Wildpeak AT3/W, BLK Mk6, ICON's, Firestone Ride Rites, SHLM, Rear view camera switch, 7-pin in bumper, Lighted 4x4 switch, ImMrYo bracket, mudflap delete
    Even better wheel bearing check method. Jack up the front corner in suspect. Turn the wheel and while doing so touch one of the coils on the strut. If you feel anything when the wheel is spinning it's the bearing. The grinding and such will transfer up into the suspension.
  8. Aug 7, 2013 at 7:27 PM
    Rupp1
    Rupp1 "If you can dodge a wrench, you can dodge a ball."
    NC
    2024 Nissan Titan Pro4X
    My '06 DC 4x4 ran 103k without a noise.
  9. Aug 12, 2013 at 4:52 PM
    three west
    JD
    UP MI
    09 DC SB TRD Sport
    Whaddya know, rotated the tires....no more noise.
  10. Aug 12, 2013 at 5:30 PM
    Benny
    Benny Well-Known Member
    2008 DC LB more mods by the month
    Have replaced both my fronts, drivers at 115k and passenger at 135k. Both were grumbling at highway speeds and went away when cornering. Both were badly pitted at the bottom of the housing, as if water had accumulated in there.
  11. Aug 12, 2013 at 5:39 PM
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Well on the 2nd gen tacoma, the wheel bearings are sealed (that is if the seal is still good) :)
    On my 2nd gen my Driver side front bearing lasted 140k miles, the replacement only lasted 3k miles... sigh
  12. Aug 12, 2013 at 5:46 PM
    kws129
    kws129 Well-Known Member
    PA
    TRD Off Road Double Cab
    Front ones are good with about 70k on the odometer. But I put a right rear wheel bearing in it at around 62k.
  13. Aug 31, 2013 at 1:37 PM
    1manjobTaco
    1manjobTaco 1man
    Florida
    05 Tacoma Double Cab LB 4x4 with 3 inch lift.
    3 inch front strut spacer and 2 inch real add a leaf with dif..drop down spacers.
    My sounded bad at 60k but after taking it out and examine it, it looks good still. Put it back on and runs great again but last week took it in for Spiral recall and deal told me that the left side is bad and wanted $750 to fix it. Though I have not notice changes since last examined.
  14. Aug 31, 2013 at 2:07 PM
    jhamm2287
    jhamm2287 Active Member
    Jerry
    Alabama
    2010 PreRunner SR5 V6
    My 2010 has 56k on it and I just had to have my driver's side front bearing replaced. However, my dealership replaced it under powertrain warranty.
  15. Feb 2, 2022 at 7:13 PM
    Green Jeans
    Green Jeans 6MT AC TRD OR 1GR-FE FTMFW
    Oregone
    '13 TRD Off-Road
    Thread revival. I’m at 160k on the front end. CV’s and Bearings all OG. No signs of failure to speak of.
  16. Feb 2, 2022 at 7:15 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Nice, you’ve made it about 60k further than me:thumbsup:
  17. Feb 3, 2022 at 1:26 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    My 2015 has 139k and no bearing issues yet
