Wheel bearing hub assembly for the front right on my 04 Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by 04truckman, Jun 23, 2020.
  1. Jun 23, 2020 at 5:06 AM
    04truckman
    04truckman [OP] Member
    2004 3.4L 4 doors 2wd
    none
    Does anyone know rather or not I can use the front hub assembly from an 05 Taco on my 04 Taco with 2WD? It looks to be identical. I am trying to avoid having to find a press somewhere and go to the trouble of pressing the old bearing out and installing the new one. Advice so appreciated!
  2. Jun 23, 2020 at 5:28 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You will still need to press the bearing in/out of the spindle/knuckle, either with a shop press or an OTC Hub Grappler-type tool. 2005+ has a bearing housing that attaches to the spindle with 4 bolts.
    As for the hub, Rock Auto has PreRunner hubs available for 1st gens, but not available separately for 2nd gens.
  3. Jun 29, 2020 at 9:02 AM
    04truckman
    none
    Thanks for your replies. What I would like to know now is rather or not I will have to necessarily remove the spindle/knuckle from the truck, as opposed to just unbolting the hub from the knuckle and having the bearing pressed out of the hub only? It is a lot of extra work to remove the spindle...
