Wheel and Tire Size for 2002 XtraCab Overland Build
Discussion in '1st Gen. Tacomas (1995-2004)' started by RubikTheKid, Jul 28, 2020.
  1. Jul 28, 2020 at 6:00 PM
    RubikTheKid
    RubikTheKid [OP] New Member
    Hello!
    I'm trying to get an idea of what rim/tire size combo works best for an overland Tacoma build (5VZ).
    Currently, the truck is using the Bilstein suspension package (Stock TRD) but will eventually be riding on some coilovers (Which ones I haven't decided, but I'm expecting a 2-3" lift).
    I've heard 33" tires will rub on the front and rear without going to an LT conversion with fiberglass fenders or some FAT spacers (Looking for robust and reliable).
    So what are your guys' opinions on a 32" tire with 16" rims? If I go with 32s, what rim width would be optimal? Will I need spacers or custom fenders?
    Thank you!
    Taco critter likes this.
  2. Jul 28, 2020 at 6:18 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    You can run 33s and do the pinch weld mod.
    Plenty of people run either.
    Comes down to budget, type of driving, etc. as you'll get many different suggestions.
    Personally, I run 235/85/16 but will be switching to 255/85/16 for my next set
    Taco critter and frizzman like this.
  3. Jul 29, 2020 at 9:16 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Here's a good post about what goes into choosing wheels and tires, and what affects various things like backspacing will have on the amount of work you need to do in order to clear them. The bottom then lists the general work for various sizes.
    Take a read, and by all means, ask questions!
    What size tires fit my (lifted) Tacoma?
  4. Jul 29, 2020 at 9:41 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    265/75r16 unless you regear , 285/75/16 w/ 4.56 manual trans or 4.88 auto
  5. Jul 29, 2020 at 9:42 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    285s and locking diffs will get you a long ways
  6. Jul 29, 2020 at 1:58 PM
    02hilux
    Planet: EARTH
    343/85R17 :D
