What's your new truck's fluid change philosophy?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ERdept, Mar 3, 2008.
  1. Mar 3, 2008 at 9:49 AM
    ERdept
    ERdept [OP] Well-Known Member
    It seems some people feel that new car engines are desiged so well in this era that it is only necessary to change out fluids in the engine, transmission and rear end, when the manufacturer recommends it.
    While others feel that it is wise the change out the new car engine oil, trans fluid, and rear end fluid ASAP because new engines, transmissions and rear ends have assembly lubes and possibly fine materials/metals from the initial assembly that must be flushed out before causing wear in the future.
    What's your personal take on this?
  2. Mar 3, 2008 at 9:51 AM
    Hotdog
    Hotdog My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    Along the same lines, do we have a magnetic drain plug? If we do, then I don't think you need to change to oil early.
  3. Mar 3, 2008 at 10:11 AM
    gsm
    gsm Well-Known Member
    Raleigh, NC
    08 Tacoma Regular Cab, 2.7L, Impulse Red Pearl
    DIY OEM Fog Lights on anytime, DIY OEM Cruise Control, Removed 2ndary Air Filter, Rear Speakers Mod, Traction Bar/Helper Spring Mod, Red Brake Drums and Rotors, Stainless Steel Exhaust Tip, Door Sill Protectors, Taco Bed Mat, Custom Front Mud Flaps (Mudguards), TRD Bucket Seats (pending)
    Engine and dff. should be changed.
    As I was told by my "New Owners Meeting" that my dealership holds for new owners, according to the dealership the tranny (manual) is sealed and the fluid is designed to last the life of the vehicle. Just went to the meeting and haven't had time to check yet, but the mechanic told me the tranny has a drain plug, but it's a big deal to add fluid as there isn't (supposedly) a normal fill plug for the tranny. That they have to use a computer assisted pump to fill to proper level. They've only done one Taco, as an owner insisted on changing his fluid at the 60k mark.
    I don't think I will "never" change my tranny fluiid either. I normally change mine in other vehicles between 60 - 75k
  4. Mar 3, 2008 at 10:13 AM
    utixrunner
    utixrunner I <3 Boost
    Florida
    2007 SWB X-Runner
    TRD S/C, DT Long Tube Headers, Jardine Catback, TRD Intake, Trd Short shifter, TTC Dual Traction Bars, Sway bar bushing kit, c2c lowering kit, lots of other little things
    Its actually pretty easy to do the transmission, nothing special with the drain or fill. It does have a magnetic drain plug. capacity is 1.9qt
  5. Mar 3, 2008 at 12:15 PM
    pdxyota
    pdxyota Well-Known Member
    Greg
    Newberg, OR
    2005 4x4 5M 2TR-FE SR5 Access Cab Indigo Ink Pearl
    TSB x 2 because first TSB leaf springs broke
    I've done mine twice now. from 30-41k miles it got pretty filthy & it was Amsoil. NOW I have Redline MT-90 in there, shifts a little better, and it's better on the copper parts.
  6. Mar 3, 2008 at 12:20 PM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    I hope that's bad info for the I4 5 speed because I am planning to switch to synthetic.
  7. Mar 3, 2008 at 12:20 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    I have a manual trans. so that'll be around 100,000 miles, my diffs will be at 50,000, engine oil always at 5000.
  8. Mar 3, 2008 at 5:14 PM
    gsm
    Raleigh, NC
    I thought that the mechanic story sounded strange. He did mention that it was Amsoil so at least he got that right! When I get back home (otta state right now) I plan to take a close look at it. I'll have to take a look at Redline as I was planning on staying with Amsoil.
    At the meeting they recommended 30k for diff. oil change. I might change mine then (breakin) and 50k then on.
  9. Mar 3, 2008 at 5:52 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    ARE Topper, Icon aal, OEM Audio+
    Er, I fit in the "others" category and believe in changing the fluids because of the break-in as you describe. If you decide not to do so thats probably fine too. I just did it because I did the work myself and fluids aren`t that expensive. Not ASAP though, for me it was something like engine oil @ 1000, 3000, then every 5k
    Transmission @ every 25k (drain &fill auto), transfer case I think around 10k (pretty much once a year) The diffs I went longer I think about 40k then 120k.
  10. Mar 3, 2008 at 5:59 PM
    TRDross
    TRDross New Member
    arizona
    08 double cap trd sport PreRunner
    im a toyota service advisor,trans is ws fluid. never change it. oil every 5,000 miles and my rear diff every 30,000 miles
  11. Mar 3, 2008 at 6:01 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    what is ws fluid?
  12. Mar 3, 2008 at 6:04 PM
    gsm
    Raleigh, NC
    Exactly what I was told. My question as well - what is ws fluid? And why not change it? Especially after a breakin period.
  13. Mar 3, 2008 at 6:08 PM
    tacotoe
    tacotoe Pastry Chef
    Nebraska
    `17 AC Sport MT
    lets guess Winter/Summer?
  14. Mar 3, 2008 at 7:27 PM
    4x4x4trd
    4x4x4trd My other ride weighs 200 tons
    North Texas
    08 White Access Cab TRD OR, Debadged
    AFE oil free drop in, Secondary removed, tint, front D-rings, Toyota bed mat, Undercover tonneau, TRD seat covers and floor mats, Pioneer speakers, Westin Platinum bars, Fumoto oil valve, short antena, Nifty Xtreme's, TSB leaf springs, Bilstein 5100's set at .85" in the front
    Waiting on a Quick Valve to install in the pan with the 1st oil change of probably 1500 miles. I know old school thoughts here. After that every 4000 to 5000 with GTX 5w-30 and a Toyota filter depending on use. Transmission with a full flush, Diff's, and the transfer about every 35,000. I may go to synthetic but never really saw the need. If your going to change it regularly with the same mileage limits anyway why use the high dollar stuff. I did switch to synthetic on the Harley mainly because it is an air cooled motor.
  15. Mar 3, 2008 at 11:08 PM
    waynea4
    waynea4 Active Member
    Western N.C.
    Red 08' Double Cab TRD Sport 4X4
    In my jeep I change the motor oil every 3000 miles, but when I had my owners meeting at the dealer they told me every 5000 on the 4.0 Taco. Plus the first 3 are free, I think 5000 miles on the break in oil is too much. But what do I know! I have the 5 speed auto so I will check the owners manual and see what is recommends, same with the diffs.
  16. Mar 3, 2008 at 11:21 PM
    TSUNAMI*22
    TSUNAMI*22 Obama can suck-it
    Stockton, CA
    '07 Standard Cab / White / 2.7 I4
    ScanGuage 2 equipped. Toyota DIY aftermarket Cruise Control mod
    Interesting. I planned on changing all the fluids including the manual tranny just so I could add the Microlon treatment to it.
    They even have Microlon for the wheel bearing re-pack.
  17. Mar 4, 2008 at 8:03 AM
    towerk
    towerk New Member
    Pasadena, MD
    Bone Stock '07 4WD DC Indigo
    I just did mine this weekend, front and rear diff, manual tranny and transfer case. All Amsoil, gl-4 in the tranny and case, severe gear in the diffs.
    Shifting into 2nd prior to the change was less than smooth, almost impossible on really cold days. Now it's much smoother.
    Front and rear diffs needed it. Very dark fluid in both, lots of "stuff" on the magnets. Tranny and case were pretty clean.
    Glad I did it as I only got a quart out of the tranny, so it was almost a quart low.
  18. Mar 4, 2008 at 8:14 AM
    Mudbug
    Mudbug Well-Known Member
    Amsoil 0w-20 engine oil and Amsoil Full synthetic 75w-90 in the Transmission, transfer case, front and rear Differentials. AFE Cold Air Intake
    Yeah I put amsoil thorughout in mine too. The rear diff had soem nasties in it with only 15k on it. I noticed a big difference in shifting with the manual five speed too it shifts MUCH smoother.
  19. Mar 4, 2008 at 8:39 AM
    4x4x4trd
    North Texas
    My maintenance guide says:
    Change oil, filter, and rotate tires. every 5,000.
    If you tow, replace front and rear differentials, torque & lube propeller shaft at 15,000.
    Replace rear differential (vehicles with limited slip only), plugs (V6), and if you tow the transfer, both differentials and manual transmission at 30,000.
    If you tow it showes auto transmission at 60,000 with front & rear differential and transfer again.
    I don't really see a mileage or time limit on the coolant.
    I guess I'll stick to past practice. Oil, filter, tires at 4 to 5,000. Both differentials, transfer, and auto transmission flush at 30 to 35,000. Coolant every three years. A good lube underneath every other oil change.
  20. Mar 4, 2008 at 8:59 AM
    Roland
    Rhode Island
    Coolant for the gen 2 tacomas is 100,000miles or 10 years and 50,000 miles or 5 years after that.
