What's with the 3rd gen Tacoma V6 needing spark plug replacement at 60k?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by captainjim, Mar 20, 2024.
  1. Mar 20, 2024 at 12:07 PM
    captainjim
    captainjim [OP] New Member
    New England
    2020 Toyota Tacoma SR5 Access Cab 4x4
    None
    Just wondering, my 2020 babe Tacoma who is named Rosalita has just about 60 k on her now. Toyota recommends plug replacement at this time on the V6 which is her powerplant Has anyone followed through with this or had issues from not following through? I've been shopping for plugs online and the packages all include ignition coils so I am like what the? Any other recommendations for servicing at 60 k is appreciated. Thank you in advance folks.
  2. Mar 20, 2024 at 12:08 PM
    killthehippies
    killthehippies French Fry Enthusiast
    Joseph
    Southern California
    '16 TRD OR AC 4x4
    i replaced mine at ~120k. huge pain in the ass. but you can get just the Denso spark plugs from Rock Auto.
    Stevie17 likes this.
  3. Mar 20, 2024 at 12:14 PM
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    I did mine around 65k. That's what Toyota recommends and..well doesn't hurt to change them even if not truly needed. Myself and many others on the forums have found one of them on the passenger side to be slightly loose from the factory.
    You can get plugs on Amazon, just double-check they aren't fakes. Got all mine on Amazon for $60~ last year.
  4. Mar 20, 2024 at 12:19 PM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Take a look at this. Soft Taco has it all laid out for you.
    https://www.tacomaworld.com/threads/update-3rd-gen-maintenance-maps-get-300k-miles.789809/
  5. Mar 20, 2024 at 12:19 PM
    TN1000
    TN1000 Well-Known Member
    2018 metallic silver TRD OR
    Work in progress
    How can you tell they aren't fakes?
    Stevie17 and faawrenchbndr like this.
  6. Mar 20, 2024 at 12:25 PM
    Technique
    Alex
    Utah
  7. Mar 20, 2024 at 12:27 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    You can postpone the replacement for another 10-20k miles. Do not replace coils, just plugs. Buy from reputable sources
  8. Mar 20, 2024 at 12:29 PM
    Clinch Mountain Preacher
    Clinch Mountain Preacher Serpent handler
    3rd gen AC SR5 4x4
    By not buying plugs on ebay or Amazon nor plugs that are being sold suspiciously cheap and claiming to be oem Denso
  9. Mar 20, 2024 at 12:38 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Would you like to know more about the vacuum pump replacement every 100k as scheduled in the maintenance booklet?
    Malvolio, Stevie17 and musicisevil like this.
  10. Mar 20, 2024 at 12:41 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    Changed my plugs on the 2016 out at 40k because, why not?
  11. Mar 20, 2024 at 12:49 PM
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    Gendering and naming a truck is wild.
    That said 60k is the service interval, plugs are pricy but it’s good to change them at least then. They are known to be under torqued. Also I’d recommend going oem from Toyota apparently fake plugs are a thing
  12. Mar 20, 2024 at 4:00 PM
    Mas Olas
    Mas Olas Well-Known Member
    Woody
    10 miles north or 400 miles south of the border.
    2020 Blacked-Out White DCLB TRD OffRoad 4x4
    My Toyota master mechanik neighbor laughed and said no, wait until 100,000 miles. So until I notice the engine missing or shit(tier) mileage I’ll wait.
    Tocamo and Kolache007 like this.
  13. Mar 20, 2024 at 4:57 PM
    Williston
    Williston Well-Known Member
    New England
    2014 Tacoma SR5 4x4 DC SB V6 AT Tow Pkg Entune+ Mostly stock with a few OEM mods.
    Stock (99.999%) OEM Bed Floor Mat, Front Bed Rail Cargo Net and hooks, Auto-Dim mirror w/Compass and outside Temperature display, TRD Pro Grille, Uni-Filter air pump modification, WeatherTech floor liners f/r. OEM All-Weather floor mats (summer), Factory/TSB OEM rear leaf spring modification.
    Buy them OEM from a local dealer. Look them up on the Toyota parts site, and order them from a local dealer that allows free pick-up. You can find them for $5-7 each without much trouble. (Unless your truck requires something other than copper Denso's: platinum, etc.) They'll likely be ready for pick up by the next day and they won't be counterfeit.
  14. Mar 20, 2024 at 5:04 PM
    BigCarbonFootprint
    BigCarbonFootprint Well-Known Member
    Andy
    2019 TRD Off Road
    King Racing 3” lift
    I just rolled 60k on my 2019 and I'm planning on proactively changing my plugs this weekend for the following reasons:
    1) Toyota recommends it. 60,000 miles is a very appropriate balance of time and distance. It is almost the ideal definition of a "preventative maintenance" interval.
    2) It is much better to change plugs at 5 years than wait another 5 years when they have increased risk of being brittle, fragile, and seized in the cylinder head such that being unable to remove one is a risk worth mitigating now. This is a big factor for me.
    3) Call me crazy (and I've been called far worse) but when it comes to plugs, coils, fuel injectors and fuel pumps, and other critical electrical components, but I'm only buying such parts directly from my local Toyota dealer.
    YMMV
  15. Mar 20, 2024 at 5:25 PM
    spp
    spp OC, Kalifornia
    OC California
    Every 30 K miles on my 2015. Emissions thing.
  16. Mar 20, 2024 at 5:36 PM
    Vlady
    Issy, WA
    Could you please elaborate on emissions thing?
  17. Mar 20, 2024 at 6:34 PM
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    I would.
    Malvolio likes this.
  18. Mar 20, 2024 at 6:57 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    The 1GR had copper plugs with 30k replacement interval in the maintenance booklet. Worn spark plugs cause misfires, increasing emissions and can burn the cats. If your catalytic converter failed during the 8yr/80k emissions warranty period, Toyota may require evidence of on-schedule spark plug replacement to honor the warranty.
    Apparently the 2GR-FKS doesn't generate enough intake manifold vacuum to power the brakes, so there's a vacuum pump. Toyota life'd the pump to 100k. Replacement requires jacking up the transfer case and transmission to pitch the engine forward in the frame, in order to access the pump at the back of the engine.
    Toyota did a recall on some 2017 pumps, so this recall document shows the replacement procedure: https://static.nhtsa.gov/odi/rcl/2018/RCRIT-18V211-7735.pdf If my truck had a vacuum pump, it would've probably been in the recall range.
  19. Mar 20, 2024 at 7:01 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    It’s like $100 and 90 minutes. Not a bad way to spend an evening or Saturday morning.
    sbl23 and soundman98 like this.
  20. Mar 20, 2024 at 7:02 PM
    TacoSupremo19
    NJ
    Almost wish I didn't ask. Between the front timing chain cover, rear coolant manifold and now this...Yikes
