What's this clip/plastic bolt called?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kharth, Jul 22, 2024.
  1. Jul 22, 2024 at 6:02 PM
    Kharth
    Kharth [OP] Well-Known Member
    Tim
    West Texas
    '13 Tacoma 135k miles
    Leer Cap, black barrel tire valve caps, Steelers sticker, Air Freshener
    What is this plastic clip piece called? I wanted to order 2 the piece they hold down are rattling I noticed the dash rattle noise a while ago while driving, finally figured out what it was (maybe). Both sides are loose and missing tabs on back of piece.
  2. Jul 22, 2024 at 7:30 PM
    Jerry Bear
    Jerry Bear Well-Known Member
    Jerry
    Mesquite, Texas
    2010 Access Cab
    tint, topper, receiver hitch, trailer wiring, topper lighting, cruise control, intermittent wipers, backup camera, auto-dim mirror
    Generically, it's called a trim fastener. Toyota's name for it seems to be "clip."
    It looks like a Toyota part number 90467-06133-C0, but I don't know enough about your truck to be sure. Go to parts.toyota.com, enter your VIN, and look in the Body > Cowl Panel and Windshield Glass section to verify it's the right part or to find the right part. https://autoparts.toyota.com/products/product/clip-9046706133c0
    SR-71A likes this.
  3. Jul 22, 2024 at 7:35 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    why not just go to a auto parts store and get one that looks like it? :notsure:
    ridefreak and OldSchlPunk like this.
  4. Jul 22, 2024 at 7:41 PM
    Jerry Bear
    Jerry
    Mesquite, Texas
    2010 Access Cab
    OffroadToy, he might get lucky with a generic one, but every time I've tried that, the fastener never fit right. I have a whole bin full of them. They're always not quite the right size. So I just buy the OEM ones now.
    SR-71A likes this.
  5. Jul 22, 2024 at 7:57 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    A stupid plastic clip! :mad:
    I just used a zip tie. But you can go to any automotive parts store and get them for a few bucks.
  6. Jul 22, 2024 at 8:05 PM
    Bagman
    Bagman Dental Floss Tycoon
    Area 51
    2023 4Runner SR5 Premium
    Cheap enough and you'll have plenty of spares.
    DoubleB likes this.
  7. Jul 22, 2024 at 8:05 PM
    RockfordTaco2006
    RockfordTaco2006 Well-Known Member
    Alexander
    2006 Toyota Tacoma TRD Off Road 4x4
    2 Inch Lift
    The best info I could find for you is the first five digits 55781G [​IMG]
    That said I have used zip ties but I don't think I have anything in that slot right now. Good Luck!
  8. Jul 22, 2024 at 8:06 PM
    Kharth
    Tim
    West Texas
    That website is amazing I never knew about it. That seems to be the thing they never fit just right form auto store but i was thinking maybe zip tie or nut and bolt to hold it maybe instead I can never find like just 1 of something.
    The only reason I want to fix it is it sounds like there is a rattling in the dash when I drive and I am thinking that is what is causing it.
  9. Jul 22, 2024 at 8:10 PM
    RockfordTaco2006
    Alexander
    2 Inch Lift
    I bought this set and I've used a few of the clips but I can confirm that set does not contain a clip that will work in that slot. The hole in the fender was too small.
  10. Jul 22, 2024 at 8:14 PM
    WOODY2
    WOODY2 Well-Known Member
    RAMONA,CA.
    Amazon has a gazillion of those things dirt cheap.
    ridefreak likes this.
  11. Jul 23, 2024 at 5:38 PM
    Kharth
    Tim
    West Texas
    I just used 2 bolts 2 nuts and 4 washers.
  12. Jul 23, 2024 at 7:13 PM
    BluberryBCtaco
    BC Canada
    Looks good! Don’t forget to add blue loctite don’t want that thing vibrating itself off, and getting itself jammed in a place you cannot reach only for it to rattle forever and ever.
  13. Jul 25, 2024 at 10:52 AM
    ridefreak
    ridefreak Well-Known Member
    NM
    2006 DCSB TRD
    minor tweaks
    I've been using a toyota clip assortment I bought from Amazon about 6 years ago. The only clip that I've needed so far that wasn't in the kit were the clips for the stereo bezel. It's a great investment on an older tacoma since many of the old clips are broken already or break when you try to take them apart.
  14. Jul 25, 2024 at 11:45 AM
    OffroadToy
