Whats the proper lubricant for this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RockfordTaco2006, Apr 22, 2023.
  1. Apr 22, 2023 at 9:04 PM
    RockfordTaco2006
    RockfordTaco2006 [OP] Well-Known Member
    Alexander
    2006 Toyota Tacoma TRD Off Road 4x4
    2 Inch Lift
    I just removed and cleaned up my HVAC Box.
    The white levers have some kind of lubricant that I may have wiped too much off in the process of cleaning them. I'd like to put a dab of something back on there but I'm not sure what to use. The guy at Autozone didn't know either. Would just petroleum jelly work?
    Robnik likes this.
  2. Apr 22, 2023 at 9:23 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    RockfordTaco2006[OP] likes this.
  3. Apr 22, 2023 at 9:29 PM
    RockfordTaco2006
    Alexander
    2 Inch Lift
    Cool thanks I'll look for it locally
    does it really say "Heavy Duty, Dielectric, Food Grade, Clear" Food Grade? thats a little odd huh?
    Thanks again!
  4. Apr 22, 2023 at 9:31 PM
    Friend of Crows
    Friend of Crows Well-Known Member
    2022 Tacoma SR
    Painted steelies black
    Probably the cheapest bulk grease there is. It's for plastic pieces after all. Dielectric is what I have in my box so I'd just use that but I'm sure you can use anything.
  5. Apr 22, 2023 at 9:38 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Looks that way, I'm honestly not sure what kind of grease they use on those but like I said anything is better than nothing.
    It came up when I was searching for the MolyKote grease in the post below.
    We were speculating on the grease in the 4wd actuators which I believe is the same stuff used on those slides, apparently Toyota calls it body grease.
    https://www.tacomaworld.com/threads/4wd-system-operation-help-thread.742420/page-23#post-28173976
    This seems to be a viable alternative.
    https://www.tacomaworld.com/threads/4wd-system-operation-help-thread.742420/page-27#post-28247732
  6. Apr 22, 2023 at 9:39 PM
    aCrimsona
    aCrimsona Member
    @RockfordTaco2006, food grade just means not poisonous. So, if you accidentally eat some, you'll be okay. No need to induce vomiting or seek medical attention. Also, I'd recommend white lithium grease.
    Breknraj and Robnik like this.
  7. Apr 22, 2023 at 9:54 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Toyota's grease SDS https://toyota.jp/pages/contents/after_service/car_care/yohin/sds/pdf/Grease/08887-02007_201602.pdf
    shows it's Molykote YM-102, which is white lithium grease: https://www.dupont.com/content/dam/...nts/en/MOLYKOTE_YM-102_Grease_80-3102C-01.pdf
    I've used CRC "Super White" with good results https://www.fastenal.com/product/details/63296
  8. Apr 22, 2023 at 10:23 PM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    $8.00 at Home Depot
    A little dab will do ya! :)
  9. Apr 23, 2023 at 7:44 AM
    TacomaMaine86
    TacomaMaine86 Member
    Maine
    2006 Red SR5
    White Lithium grease as Robnik said.
  10. Apr 23, 2023 at 8:49 AM
    TacoTuesday1
    FL
    I'm sure it's something. Not sure what it is. You could try white lithium grease. I would. Better than nothing.
    I'd avoid petroleum jelly. It's based on petroleum. Which is where gas comes from. I don't know for sure, but I imagine something like that would gradually eat away and dissolve plastic components.
    Same reason they say that if you have a tub of yellowish wheel bearing grease laying around, do not use it on things like rubber sway bar bushings, as it's petroleum-based and will dissolve them
    same way if you take a plastic red solo cup and put some gasoline in it, by the next morning the bottom of the cup will be dissolved
    any why red fuel carry containers are red; the plastic is a specific design to handle that
  11. Apr 23, 2023 at 9:17 AM
    RockfordTaco2006
    Alexander
    2 Inch Lift
    Thanks so much, Y'all are awesome!
    I'll see what I can find at the Hardware stores.
  12. Apr 23, 2023 at 9:40 AM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
    Also Petroleum Jelly has a low melting point around body temp
    The inside of our turks on a hot summer day in the sun can get much hotter than that so it would melt and run/drip off
  13. Apr 23, 2023 at 11:26 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    superlube, put that shit on everything.
    White lithium would work damned good as well.
  14. Apr 23, 2023 at 11:54 AM
    RockfordTaco2006
    Alexander
    2 Inch Lift
    Ended up with a tube of the Lucas White Lithium $7.98 at Home Depot.
    Thanks for playing everyone!
    3JOH22A likes this.
  15. Apr 23, 2023 at 5:39 PM
    vtdog
    vtdog Well-Known Member
    NH
    KY Jelly
  16. Apr 23, 2023 at 7:28 PM
    CadCamMan
    CadCamMan Well-Known Member
    Mission Viejo, California
    2011 DCSB, 4WD TRD OR, 2.5 Kings
    TRD SC, suspension
    The grease found on all of the interior components (switches, levers, etc..) is called damping grease. Besides being a lubricant, the main function of damping grease is to exhibit a specific feel for the component it is being used on. The damping grease(s) on the different components, switches, etc.. are usually proprietary and the manufacture of the grease won't offer those specific greases for sale. They may have something close, but you will have to know specifically what you are looking for. Nye lubricants makes damping grease.
    Can't help you on the petroleum jelly.
  17. Apr 24, 2023 at 12:54 PM
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    ive used white lithium for stuff like that for years.
