What's the biggest tires you'd go on 16X8?
Discussion in 'Wheels & Tires' started by iJDub, Mar 31, 2013.
  1. Mar 31, 2013 at 8:32 PM
    iJDub
    iJDub [OP] Well-Known Member
    Without regards to rubbing and the other variables, what's the biggest size tire you'd safely put on a 16X8 wheel?
  2. Mar 31, 2013 at 8:33 PM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    i once had 305/70/16's on my TRD OR alloys. looked sick.
  3. Mar 31, 2013 at 8:36 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Ya, I wouldn't go more than 305.
    Here's 285/75's on 16x8 on my Duramax.
  4. Mar 31, 2013 at 8:42 PM
    lawman2010
    lawman2010 Member
    Ohio
    2013 Tacoma 4dr SR5 4wd
    Magnaflow exhaust,air intake,throttle body spacer,rims&tires,stainless brush guard,hood w/scoop(added on after),fender flares
    I have 275/75/16's on aftermarket wheels(no lift) and get a slight rub on mud flaps..I'm hoping my fender flares take care of it otherrwise I would go with a lower profile tire like 275/70/16..Check where you go to buy as they should know if not they'll have to take care of if there is a problem..they have all the answers- don't they?
  5. Mar 31, 2013 at 9:37 PM
    iJDub
    I want to get the TRD beadlock rims and put 265/75/16 for now (stock setup). I want to be able to upgrade to bigger tires later (such as 305s) when I CMC, lift, cut/trim later.
  6. Mar 31, 2013 at 10:11 PM
    Boost JuNkY
    Boost JuNkY Well-Known Member
    Billy
    Vancouver, BC
    2003 TACOMA DC OFF ROAD
    35'S ON 3s
    305s are perfectly fine with 16x8s. 315s are also ok with them. Theres enough sidewalls on those.
    17s + are the ones you'd have to run wider wheels.
  7. Mar 31, 2013 at 10:12 PM
    TherealScuba
    TherealScuba Sober Member
    Stephen
    Austin, Texas
    99 Single Cab 4x4
    12.5" wide.
