What's the best/cheapest idle air control valve for 1st gen 2.4 2rz's?
Discussion in '1st Gen. Tacomas (1995-2004)' started by austi012, Oct 6, 2020.
  1. Oct 6, 2020 at 8:46 AM
    austi012
    austi012 [OP] Active Member
    Thaddeus
    1997 Tacoma
    Title says it all. I have a wandering idle and a new MAF, no vacuum leaks I can find, so I'm thinking the IAC valve may be tired after 23 years.
    thanks
  2. Oct 6, 2020 at 9:34 AM
    Xbeaus
    Xbeaus Well-Known Member
    Beau
    Black hills South dakota
    98 Tacoma 3.4 5 speed SR5 limited TRD 4x4
    Toytec coilovers. Height adjustable Bilstein's. 265/75/16 MT. TRD wheels. Rebuilt r150f. Marlin clutch kit. All kinds of new parts...
    Have you looked on rockauto? Might be your best bet
  3. Oct 6, 2020 at 11:21 AM
    austi012
    Thaddeus
    1997 Tacoma
    I did. There's about 5 out there with a wide variation in cost. I'm wondering if any cheap ones are any good....
  4. Oct 6, 2020 at 11:26 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    23 years is a long time.
    Makes you wonder if an aftermarket would last that long?
    My vote would be OEM if not a lot more. I kind of like to stick with OEM electronics.
    If I had to go after market, I’d look at Bosh or Denso.
    If they even make than IAC for the truck?
  5. Oct 6, 2020 at 11:27 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Do you want the best OR the cheapest? No such thing as getting both.
    Have you tried cleaning your IAC?
    Also, what MAF did you get. Non OEM ones are kinda known to be junk.
    Wyoming09 and Old n' slow like this.
  6. Oct 6, 2020 at 12:26 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I went with the one from my Dealer solved the problem.
    Cleaning is always the first move they do tend to get dirty
    Dalandser likes this.
  7. Oct 11, 2020 at 6:46 AM
    austi012
    Thaddeus
    1997 Tacoma
    I realized the problem had stated with a change in the weather. I replaced the intake air temperature sensor and the wandering idle went away.
    Getting correct data to the computer is really key with any modern car... garbage in, garbage out, good data in, good performance out.
