What's good about lighter wheels?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sgmstr, Jan 23, 2020.
  1. Jan 23, 2020 at 4:07 PM
    sgmstr
    sgmstr [OP] Well-Known Member
    Doing some reach on wheels.
    One wheel is about 19lbs and another is about 26 lbs. $250 v. $150 per wheel.
    Both are 16 inch with 0MM offset with probably 265/75 Tires. What can you get for lighter wheels besides better stopping distance and MPG. Less wear on suspension? Quicker acceleration (since less weight)? Are these differences minimal being that it's only 7lb difference (28 lb for four total)?
    BTW - how much does OEM OR wheels weigh?
    TIA!
  2. Jan 23, 2020 at 4:08 PM
    TRDProOne
    TRDProOne Well-Known Member
    CA
    2019 TRD Pro in Super White
    Lighter wheel = less unsprung weight.
  3. Jan 23, 2020 at 4:08 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Better acceleration and braking.
  4. Jan 23, 2020 at 4:09 PM
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    less strain on the differential
  5. Jan 23, 2020 at 4:11 PM
    sgmstr
    Wonder if 28lb difference make a lot of difference though.
  6. Jan 23, 2020 at 4:17 PM
    sgmstr
    good catch. never intended to put in their. Must have pasted something that I copied. Tried to get rid of it, but can't.
  7. Jan 23, 2020 at 4:17 PM
    sgmstr
    There.. did it.
  8. Jan 23, 2020 at 4:21 PM
    CrippledHo
    CrippledHo I'm calling about your car's extended warranty
    Eric
    Biggest Little Dumpster
    2016 DCSB Diet Coke
    Dents and a rattle can
    It's where that weight is that makes the difference, so yes
    Junkhead likes this.
  9. Jan 23, 2020 at 4:46 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    For 7 lbs/corner you'll never notice the difference. All of those advantages are theoretical. You'll need an Olympic grade stopwatch to measure any difference in acceleration and stopping distance. And likely have to go several places to the right of the decimal point when figuring how much better fuel mileage you're getting.
    Someone posted a link on here some months back trying to prove how important reducing unsprung weight was. The article was geared toward drag racing and they were showing how much faster a car with 200 lbs less unsprung weight was. The lighter car was 1/2 car length farther down the 1/4 mile track in the same time as the same car 200 lbs heavier.
    To someone racing for prize money that 5-10' might have been a huge deal and the article said so. Aluminum wheels got their start in racing where the tiny gains in performance over steel wheels matter. For most drivers they just look better.
    badkids likes this.
  10. Jan 23, 2020 at 5:04 PM
    lloydbm4
    lloydbm4 Member
    Lloyd
    19 Taco
    On a motorcycle this kind of weight decrease would be the equivalent of approx 1hp increase, less unsprung weight for faster acceleration and being able to lean the bike over quicker. All great for making the bike handle better.
    On a truck this won’t make a lick of difference.
  11. Jan 23, 2020 at 5:07 PM
    sgmstr
    That's what I think, too. It would matter for a lighter mass, but not so much on heavy mass. In any case, lighter is always better.
  12. Jan 23, 2020 at 5:08 PM
    Shouldnthave
    Shouldnthave Where all the white women at?
    Jay
    TRD-OR Trail Limo
    You should always buy the lightest tires and wheels that do the job you want and look the way you want. 7 pounds a corner adds up over the life of a truck/car. It may be a little bit per mile of driving, but over 250,000 that can be a chunk of money.
    Coming from a race car background you can really tell the difference between 2 pounds a corner at speed. Not so much on the street, but gains are there.
    Here’s an article about it.
    https://www.cjponyparts.com/resources/what-is-unsprung-weight
  13. Jan 23, 2020 at 5:17 PM
    navin r
    navin r Well-Known Member
    2017 double cab short bed trd off road 4wd w/ premium pkg.
    My own humble opinion; tire and wheel weights on a truck with a strong motor won't matter much, but on a truck with a barely adequate motor like the 3rd gen. V6; it makes a difference. Just my non-scientific personal opinion.
  14. Jan 23, 2020 at 5:25 PM
    sgmstr
    Going for the 19 lbs wheels. Think I can recoup $400 over the life of the truck.
    Haven't purchase truck yet, but test driven it. and YES, I felt the truck needed a bit more power and was little sluggish.
  15. Jan 23, 2020 at 5:27 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    I know on a triathlon bike wheels are the number 1 area you want to cut down weight. Reducing the power it takes to turn the wheel and tire is the best way to go faster at the same output. I did some research and it actually makes big difference.
