What's a good shift module to eliminate trans hunting/shifting issues?
Discussion in 'Performance and Tuning' started by CVOTRDSPORT, Jan 27, 2025.
  1. Jan 27, 2025 at 7:28 AM
    CVOTRDSPORT
    CVOTRDSPORT [OP] Well-Known Member
    2016 White Tacoma TRD Sport 4X4 Longbed
    OK, Ive been away for a long time now and coming back to ask for suggestions on the notorious shifting issues with 6 speed auto trans. Im so sick and tired of the drivability issues with this truck. I installed the OV tune and it was absolutely useless, whether it was my lack of installing it correctly or if that program is crap. Im not going to read 3500 post on it, dont think I would live long enough to finish. Any help or suggestions appreciated. Maybe is there anyone in the San Francisco that could do a proper install might be worth a try. TIA.
  2. Jan 27, 2025 at 7:44 AM
    truckmike26
    truckmike26 New Member (2009)
    Toronto
    '21 DC TRD Off-Road, '94 Pickup (Hilux) V6/Auto 4WD
    The three-second delay for a full-throttle downshift is the most frustrating. It's like City Council needs to vote on a downshift after I floor it. Back in the good ol' days, there was a cable, rod or electric switch (under the accelerator) that told the transmission to downshift NOW.
    dryheat and musicisevil like this.
  3. Jan 27, 2025 at 7:57 AM
    banjoGrampa
    banjoGrampa Well-Known Member
    David
    East Tennessee
    2019 TRD Sport 4x4 DCLB
    OME/ Bilstein 2" lift, Deaver aal Pro/Heritage grill TRD PRO wheels w/ Goodyear Ultraterrain 265/70/17 Westin HDX DROP NERF STEP BARS LEER 100R shell Custom bed platform High flow air filter/air accelerator Marine Corps graphics A-Premium mud guards Emblem black-out Rove R2-4K Dash cam
    look in to the OTT tune. (Overland Taylor tune) It does wonders for the shifting, as well as torque and HP.
  4. Jan 27, 2025 at 8:01 AM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    Nothing is going to "fix" the transmission issues. You can change shift points, you can change engine timing, but the gears are the gears. Regearing the differentials will help some with the gear hunting but will reduce top speed. The best thing I have found is to just shift it manually.
    jjsinaz, BullComa4.0L and CB350G like this.
  5. Jan 27, 2025 at 8:19 AM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    I dunno, perhaps I'm not savvy enough to notice, but I find NOTHING wrong with my stock 2021
    transmission. It works just fine.
  6. Jan 27, 2025 at 8:21 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    All these years and I still haven't figured out what "gear hunting" means? My auto shifts up when it needs to and down when it needs to. Seems pretty normal to me but maybe I am missing something. Good luck to the OP in finding some level of satisfaction with his truck.
  7. Jan 27, 2025 at 8:34 AM
    trailmeisterjoe
    trailmeisterjoe Well-Known Member
    Joe
    Pacific Northwest USA
    2017 Tacoma SR5 2WD AC
    I automatically (pun intended?) always use "S" drive and go with S4 for back streets, easily flick up to S5 for 2 lane highways, and S6 only when on the freeways (unless real hilly, then S5. Works well for me.
    Joe
  8. Jan 27, 2025 at 8:35 AM
    socalexpeditions
    socalexpeditions IG: @socalexpeditions
    OTT Tune and 91 octane
    VLTHNTR77 likes this.
  9. Jan 27, 2025 at 8:43 AM
    KevlarBear
    KevlarBear Well-Known Member
    SSM 2023 TRD OR DCSB
    I just booked an appointment at my local tuner for the OTT. I'm pretty excited. I'm only doing it for the transmission behavior, as I don't expect a truck to be a sports car, but any noticeable gains with HP/torque will be cool to.
    In all honesty the transmission is fine the way it came but I do notice its odd/awkward shifting behavior, especially in stop and go traffic, and wouldn't mind an improvement. Plus I'm a nerd for things like this so very much looking forward to see what the OTT can do.
  10. Jan 27, 2025 at 8:54 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Unfortunately the 3.5 V6 doesn't make much usable power in the lower RPM range. You could try a different tune, re-gear, or sell it off. The transmission is doing it's job,,,, shifting to get the RPM's up when power is needed,,, then shifting back to reduce emissions and fuel consumption (big GOV mandated).
  11. Jan 27, 2025 at 8:56 AM
    offroadguy651
    offroadguy651 Well-Known Member
    The North
    2023 TRDoffRoad
    5100's 1.5 front. 1 inch Eibach block in the rear. KO3 285/70/17 RRW RR6-H 17x8.5.
    I have one solution that will guarantee to fix your issues, sell the truck.
  12. Jan 27, 2025 at 8:57 AM
    BoomerGVNG
    BoomerGVNG GET OFF MY LAWN
    2022 TRD SPORT DCSB
    You did the tune yourself? OVT i believe is one of the older tunes. I have OTT (mild/medium) and it fixed everything you're describing.
  13. Jan 27, 2025 at 9:28 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    The reason there are so many posts on this subject is because people like you keep asking the same question.
  14. Jan 27, 2025 at 9:53 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Try driving with ETC on. I drive with it on 100% of the time
    PandaPandaPanda likes this.
  15. Jan 27, 2025 at 10:18 AM
    majpooper
    majpooper Well-Known Member
    Dennis
    North Carolina
    2022 Black TRD OR
    OTT Tune Front 2" lift OME 888 coil Bilstein 5100 DuroBump extended front bump stops Archive Garage extended rear bump stops Rear 1.85" lift Icon RXT leaf pack Bilstein 5100 SPC UCA DX4 16x8 +10 wheels 285/75R16 KO2 viper cut CMC sway bar delete exhaust reroute exhaust cut just past the rear axle U-bolt flip LFD engine skid plate RCI transmission and x-fer case skid plates Spindle gussets
    ^^ what he said ^^
  16. Jan 27, 2025 at 10:40 AM
    Mallcrawler20
    Mallcrawler20 Well-Known Member
    Trd off-road 4x4 Manual
    Manual transmission ….. :anonymous:sorry had to … lol
    MagicToolbox likes this.
  17. Jan 27, 2025 at 6:05 PM
    Two4Runner
    Two4Runner Well-Known Member
    LD
    Shreveport
    2017 DCSB TRD Offroad 4x4
    I had pedal commander and it helped some but replaced with an actual tune (KDMax) and it drives like a normal transmission should. Kept me from selling the truck but it did take a small hit on gas mileage.
    TacoManOne likes this.
  18. Jan 28, 2025 at 7:33 AM
    CVOTRDSPORT
    I do drive with etc on and manually shift 95% of the time. But its still a pita to drive smoothly. Sometimes I have to give almost half pedal travel before it goes, and when it does it downshifts and throws everyone back in the seat. When it was new, I got a speeding ticket trying to go from 15-25 mph. Is the VTT an update for the OVT? Is there a link for this or pedal commander? Sometimes I consider selling it, Tacoma is not very impressive on the quality between peeling paint, timing cover leak ($6k) and crappy shifting issues.
    I will add I live in the hills where constantly going up or down 6-12% grades, in second gear this vehicle has no downhill compression hold back unless Im going 35-40 mph. hard not to keep warping front rotors.
  19. Jan 28, 2025 at 7:45 AM
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    Get a bigger engine, and a 4 speed transmission to avoid the transmission dance we have with this gen Tacoma v6. Ski
  20. Jan 28, 2025 at 8:03 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I only use ETC when getting onto a freeway or going up a hill.
    Coasting speeds cause a pulsating effect, for me, when etc is left on.
