What years were the solid front axles?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sddarkman619, Jun 24, 2016.
  1. Jun 24, 2016 at 9:46 PM
    sddarkman619
    sddarkman619 [OP] Well-Known Member
    Larry
    San Diego
    2015 Tacoma Sport TRD
    None(Yet)
    I'm going to start looking for a solid front axle as I'd like to build a rock crawler.
    So what years did Toyota have the solid front axle 4x4?
    I mean seriously, these guys make it look so easy!
    Watch the Toyota.
  2. Jun 24, 2016 at 9:47 PM
    Pigpen
    Northwest Montana
    Up to '85, I think
    Ugly Betty likes this.
  3. Jun 24, 2016 at 9:51 PM
    Kyitty
    Kyitty Mr. Beard
    Bozeman, MT
    2015 Tacoma DCLB Better Than TRD
    See Build Page
    Yeah.... if you want a solid front axle on a Tacoma you're going to be doing a lot of modifying.
    Met a guy in Moab early June who did a solid front axle on his Tacoma. Talking total front end rebuild. Not for the faint of heart.
  4. Jun 24, 2016 at 9:51 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Better off looking at the land cruiser axles. Fj80 had solid front axle up to 1997.
    I'm about to chop off my IFS stuff, but I'm using a diamond axle up front.
  5. Jun 24, 2016 at 9:53 PM
    Pigpen
    Northwest Montana
    I just want to mod a minitruck with solid front.
  6. Jun 24, 2016 at 9:54 PM
    Ugly Betty
    Ugly Betty Well-Known Member
    mark
    TX
    85 extra cab on propane
    1985 ex cab, 92 toyota pickup, 95 4runner
    If ur sas'ing your 2nd gen you should go bigger that a mini truck axle. They are much narrower than your truck. Dana 60 up front and 14 bolt in the rear is ideal. Check out the solid axle bs thread
    Large likes this.
  7. Jun 24, 2016 at 10:08 PM
    n0rth
    n0rth Well-Known Member
    J.W.
    New Mexico
    2019 Tundra Platinum
    2009 Tacoma Access Cab SR5, 4wd, 2.7L URD S/C, 4:88's ARB lockers, 36x9.8r16 Radial TSL
  8. Jun 25, 2016 at 3:17 AM
    sgtnewundies
    sgtnewundies Well-Known Member
    Eric
    Florida, Citrus County
    14 trd sport red
    Working on it now....UNDER CONSTRUCTION
    My 1985 had a solid front axle. I am pretty sure that 1986 did too.
