What would cause my trip odometers to reset automatically?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by phdog, Jul 27, 2021.
  1. Jul 27, 2021 at 4:15 PM
    phdog
    phdog [OP] Well-Known Member
    Jim
    Northern Colorado
    2017 TRD Off Road
    w/Super Terrific Happy Hour Mod
    This is odd. The truck was outside in the sun all day while I was at work and it was pretty hot. Probably close to 100 degrees. When I started the truck it was rather hesitant to start. It did, but it did like 3 short vruunns with longish gaps between and then started.
    I didn't think much of it, but I noticed when I got home my odometer wasn't on Trip A which is where I normally leave it tank miles and when I clicked over to Trip A it was showing just the miles I drove from work and both Trip A and Trip B were the same. They clearly were reset when I started it. However, nothing else seems reset like when the battery is dead. And I don't think a dead battery causes the odometer to reset although I've never really paid attention.
    Anyone have something like this happen before or have any idea what might be going on?
    helix66 likes this.
  2. Jul 27, 2021 at 4:28 PM
    513Mugsy
    513Mugsy Well-Known Member
    Cincy
    2020 VOODOO AC OR MT sold now
    Have you put in a new battery yet? If not, have AutoZone do a check on yours. It's free. They will tell you whether it's good or not.
    shakerhood likes this.
  3. Jul 27, 2021 at 4:43 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Still original battery. It's a 2017 with about 58,000 miles. I'll take it over tomorrow to get the battery tested.
    So the odometer issue could be from the battery blinking out or something? It started, so that tells me the battery was "good enough" so not sure why the odometer reset.
  4. Jul 27, 2021 at 4:57 PM
    fisherick
    fisherick Well-Known Member
    Rick
    Ma
    2016 Tacoma TRD OFF Road, AC, AT, Super White
    20" LED Bar, 265x75x16 S/T Maxx none
    I had this happen to me last month. (2016 + 61,000 miles) My odometer reset itself twice and then the battery died. Low voltage Buy a battery ASAP.
    helix66, Chew, 06Tacooo and 2 others like this.
  5. Jul 27, 2021 at 6:21 PM
    513Mugsy
    Cincy
    The high temperatures you have been having, plus sitting on a hot black parking lot. The temps have to be around 150ish. Temps like that will just cook any battery.
    RustyGreen likes this.
  6. Jul 27, 2021 at 6:29 PM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    100% from low voltage on the battery. It might still start the truck but if its slightly less than what it needs it will reset the odo.
    Skydvrr likes this.
  7. Jul 27, 2021 at 6:31 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Yap. The starter temporarily drops systems voltage below the keep alive memory voltage. Or something like that anyway.... :D
    RustyGreen and Chew like this.
  8. Jul 27, 2021 at 8:22 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Sounds reasonable I guess. Just didn't know the odo was battery dependent like that and nothing else seemed to reset. I'll get it checked and probably a new battery.
    Thanks everyone for the help.
    ABA180 likes this.
  9. Jul 27, 2021 at 8:30 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    ODO or trip? Afaik the ODO has "keep alive memory". Fucked that up last time.
  10. Jul 27, 2021 at 9:42 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Yeah, trip. I was just being lazy with the keyboard.
    Skydvrr[QUOTED] likes this.
  11. Jul 27, 2021 at 9:57 PM
    toyotology
    toyotology Well-Known Member
    SW Show-Me State
    2021 TRDPRO 6MT
    I think trip will go to 9999 max and reset. Did you happen to be near that mileage when you parked it?
  12. Jul 27, 2021 at 10:15 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Definitely is on 2nd gen, can confirm..so I'd surmise the same is true here. Had this happen whenever I disconnected mine or had it die on me.
    9999.9 off the top of my skull..again, 2G but pretty sure this is true of 3G
  13. Jul 28, 2021 at 12:18 AM
    MaverickT883
    MaverickT883 Paintless
    Maverick
    Ontario, Canada
    2021 Tacoma TRD Off-road Access Cab
    Check build thread!
    Battery is probably on its way out. If you disconnect it for an hour or so, you should get similar results.
  14. Jul 28, 2021 at 1:24 AM
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I had a friend with a similar weird issue on one of his cars. Every couple days the clock would reset.
    Truck never had an issue starting. He got the battery replaced and the clock no longer resets.
  15. Jul 28, 2021 at 3:27 AM
    mattm55
    mattm55 Well-Known Member
    Mid-Hudson Valley, NY
    2017 BBPearl Tacoma TRD Sport Access/AT w/SnoWay
    I also had this happen after I installed the remote start and started it remotely. Once in awhile it will reset the trip odometers.
  16. Jul 28, 2021 at 5:14 AM
    allen993
    allen993 Well-Known Member
    Allen
    Alabama
    2019 TRD Off-Road, Access Cab, Cement
    It's almost definitely a low battery. The only other culprit would be a defective trip odometer RESET button/switch...but this is VERY unlikely.
  17. Jul 28, 2021 at 7:01 AM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    No, it was like 250 miles and Trip B was probably 1300 or something. I don't reset that one as often. both are now exactly the same and the distance home. Pretty sure based on the feedback here it's the battery.
  18. Jul 28, 2021 at 1:01 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    Quick follow up. Wouldn't start today. Had to jump it. Yep, bad battery. Got a new one and all is good.
    Bonus was it gave me a chance to test my new NOCO Boost. That thing is the shitz. Can't believe I waited this long to get one. Started right up like it had a new battery.
  19. Jul 28, 2021 at 5:16 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Gb40 or 70?
  20. Jul 28, 2021 at 5:39 PM
    phdog
    Jim
    Northern Colorado
    2017 TRD Off Road
    GB50. Seemed a good compromise.
