What would be an alarming transmission temp?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joe23, Jan 25, 2017.
  1. Jan 25, 2017 at 12:51 PM
    Joe23
    Joe23 [OP] Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Since I've got the ScangaugeII running and reading it transmission temp I'm curious what is considered high or abnormal?
    I'm currently sitting at around 82 degrees Celsius. (180F).
  2. Jan 25, 2017 at 12:53 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    250ish I would think
    Joe23[QUOTED][OP] likes this.
  3. Jan 25, 2017 at 1:00 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Seems like @gearcruncher has mentioned a temp before that is pretty much the point of fluid damage/mechanical damage.. can't recall.
  4. Jan 25, 2017 at 1:01 PM
    Noelie84
    Noelie84 What Could Possibly Go Wrong?
    Noel
    Wales, Maine
    '15 Ram 2500 Land Barge
    8.5 Fisher XV2, some switches, some lights.
  5. Jan 25, 2017 at 1:02 PM
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    Referring to a 2nd Gen auto trans:
    https://www.tacomaworld.com/threads/transmission-max-temp-toyota-answers.279990/
    We apologize that the Owner's Manual does not include the temperature in which the automatic transmission oil light will illuminate in your 2013 Tacoma.
    If you are towing with your vehicle, the automatic transmission oil temperature light may illuminate at 302 degrees. If the light comes on, it indicates that the auto transmission fluid temperature is too high. If the light flashes, it indicates a malfunction in the auto transmission system.
    Jfb44 and JoeCOVA like this.
  6. Jan 25, 2017 at 1:07 PM
    Noelie84
    Noel
    Wales, Maine
    My F150 runs around 185-190 for normal driving (once it's up to temp, at least. Takes about 30-40 minutes of driving to get there) Towing a bass boat this fall it ran between 195-205, depending on the terrain. Modern transmissions with efficient coolers have to work pretty hard to get into the 'danger zone' as far as temperatures go, as long as you keep the fluid fresh and keep it out of OD while you're towing.
    Joe23[OP] and JoeCOVA[QUOTED] like this.
  7. Jan 25, 2017 at 2:48 PM
    Joe23
    I thought running close to water temp was high but I guess not lol. So Im in a safe zone
  8. Jan 26, 2017 at 4:52 AM
    gearcruncher
    Canadain bumper technician
    You are correct that the light on the dash comes on far too late . At 302 degrees , you have basically cooked your transmission fluid and almost guaranteed damaged internal transmission components .
    Keep in mind if you overheat your engine , you have also overheated your transmission . Why does this happen ? because the transmission is heated and cooled using the engines cooling system .
    Taking the truck for a mud run in 4x4 low , youve got little to no air movement through the transmission cooler , stop and go traffic as well as towing also heat up your transmission very very quickly.
    This is why I push members to purchase either a scan gauge or ultra gauge and try their best to keep the transmission temps under 200.
    What we have found after members purchased either gauge is they then realize they will be needing a larger transmission cooler
    Here is a recent transmission cooler install with some pics
    https://www.tacomaworld.com/threads/aux-transmission-cooler-diagram-pic.324202/
