What type of transmission fluid?
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaTyler_2002, Dec 20, 2019.
  1. Dec 20, 2019 at 2:10 AM
    TacomaTyler_2002
    TacomaTyler_2002 [OP] Well-Known Member
    Tyler
    Southern California
    2002 Tacoma 2wd 2.7L
    Recently purchased my 2002 Tacoma 2.7l and I have been changing out the fluids. I have done everything but the transmission. I have no idea the last time the transmission fluid has been changed and what type was used. I plan on draining about 2 quarts from the pan than adding 2quarts and doing this over a period of a couple weeks till I go through about 6quarts to hopefully get mostly clean fluid. My concern is mixing different types of trans fluids. will it hurt my transmission? what type to use? dexron iii? please help
  2. Dec 20, 2019 at 6:13 AM
    02hilux
    Planet: EARTH
  3. Dec 20, 2019 at 6:28 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
  4. Dec 20, 2019 at 6:30 AM
    agalloch07
    agalloch07 Well-Known Member
    I use this stuff in all 3 of my Toyotas it's cheap and you need 3 gallons https://www.walmart.com/ip/valvolin...utomatic-transmission-fluid-1-gallon/15125768
    You should flush it to get all of the old fluid out. Measure how much you drain out and if it's like 5 quarts put 5 quarts back in. Then remove the return line from the transmission cooler and stick it in one of the old jugs ad run the truck in neutral until it drains 2 quarts out. Then put 2 more quarts back in the transmission and repeat until you all 3 gallons are gone. In my experience you need 3 gallons to flush all of the old fluid out of the converter and the fluid runs blood red. A magnefine filter spliced into the tranny cooler in the line is a good idea especially if you dont drop the tranny pan and clean the magnets.
  5. Dec 20, 2019 at 10:17 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Curious if you tried searching this topic. It's been discussed a lot. I'm sure you'll find all the answers (and then some) to what you're asking.
    ace_10 and CS_AR like this.
  6. Dec 20, 2019 at 12:10 PM
    jmferg
    jmferg Well-Known Member
    I used Castrol Transmax Import and Toyota T-IV in the A340 automatic in my 2001 4runner. The trans seemed slightly happier with the T-IV fluid vs the Castrol transmax. the trans temp actually went up 5-8% on average after flushing completely and filling with the Castrol.
    I plan on flushing my new 1st gen with Toyota T-IV.
    An old transmission is 1 place that I do not switch to synthetic fluids.
  7. Dec 20, 2019 at 12:17 PM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    this is inline on what a member here says using the CASTROL ATF in place of the OEM T-IV ATF the shifting not as good as using the OEM Toyota T-IV, he even tried using the Valvoline Maxlife in his truck but says it was better when he had the OEM ATF in the tranny was better than both the others
  8. Dec 20, 2019 at 12:46 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    automatic transmission calls for DEXRON II but it has since been replaced with DEXRON III
    DEXRON VI and above are a different formula and should not be put in a DEXRON III and lower transmission
    Also, normally, DEXRON 4 and up are yellow while III and lower are red. So if you have red fluid coming you when you do your fluid change, you had D-III in there
  9. Dec 20, 2019 at 2:04 PM
    wingedone
    wingedone Well-Known Member
    2001 Toyota Tacoma
    I just did tranny fluid last month. Used t-iv and tranny seemed to shift a little better. Not sure what was in there before but it was black and I was starting to have issues on cold mornings with it shifting up. Mine is supercharged with 116k miles
    cruiserguy likes this.
  10. Dec 20, 2019 at 4:43 PM
    CS_AR
    CS_AR Well-Known Member
    1999 Tacoma PreRunner TRD
    Everything but the driveshaft. B03A - 410
    What ever fluid you use is better than running old fluid that needs to be changed.
    Be sure to stop by your local dealer and pickup some Toyota transmission drain plug "crush washers" for your 1st gen.
    I try to keep 2 or 3 extra in my toolbox.
    Area51Runner likes this.
