What type of antifreeze?
Discussion in '1st Gen. Tacomas (1995-2004)' started by OldmanBob, Jul 6, 2018.
  1. Jul 6, 2018 at 1:18 PM
    OldmanBob
    OldmanBob [OP] New Member
    Rio Rancho NM
    2001 Tacoma extended cab 4WD 3.4
    Stock
    Can any one tell me what type of Antifreeze to use on a 2001 Tacoma 4WD , 3.4 engine.
    Thanks
  2. Jul 6, 2018 at 1:28 PM
    Kerby J
    Kerby J Well-Known Member
    Kerby
    Lincolnton, NC
    1998 Quicksand Tacoma
    Toyota long life red concentrate from the dealer and mix it 60 parts concentrate to 40 parts distilled water
  3. Jul 6, 2018 at 1:33 PM
    OldmanBob
    Rio Rancho NM
    Stock
    thanks , was told by NAPA ok to use standard green antifreeze , Will stick with Toyota long life red.
    Thanks for the Help
  4. Jul 6, 2018 at 3:04 PM
    Indy
    Indy Master of all I survey.
    1. Any of the universal stuff will work.
    2004TacomaSR5 likes this.
  5. Jul 7, 2018 at 10:46 AM
    skeezix
    skeezix Well-Known Member
    Colorado
    1998 Limited
    I use Aisin straight anti-freeze and mix it 50% with water. I could also use Genuine Toyota Parts antifreeze but that's a bit more expensive. Besides, mixing my own makes me feel like I'm still a bit useful... :D
    knayrb and TOMRR like this.
  6. Jul 7, 2018 at 3:23 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    It would depend just what is in there now.
    Unless your doing a complete flush
    Had a Female Friend add Green to the Toyota Red When Her Boy Friend checked it looked like pure rust He was quite worried till we figured out what happened.
  7. Jul 7, 2018 at 7:49 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Toyota OEM red anti freeze will NOT mix well with other anti-freeze. No matter what the guy at Napa tells you.
    I would not suggest putting any other antifreeze in your system unless you plan on fully flushing the OEM antifreeze out first. (you have to flush it, then flush it again, and flush some more... you can't just drain it.)
    Also... I would not mix concentrate antifreeze at a 60% antifreeze to 40% water mix. Unless you live in an extremely cold climate during winter. Especially if you are taking your rig off road in the heat. I go a minimum of 50% water, during the summer I even go closer to 60% water. (But I drain and replace the coolant in my radiator every oil change and flush once a year) I use distilled water because it doesn't have calcium/minerals/etc.
    Water cools your vehicle better than antifreeze... but with that said, even in hot weather, it's best to use at least 40% antifreeze due to corrosion and cavitation issues.
    And for the record... I flushed the Toyota red a long time ago and have been running Prestone.
  8. Jul 7, 2018 at 11:17 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    I had Toyota do a flush a few years ago and they added green coolant back in. I installed a new radiator today in mine and added Prestone back in it.
    Edit: Lol that reads badly. The green coolant didn't mess up my radiator, it had 200k miles on it and my truck was showing some temp increases. I think it ran its course. I'm back to a steady 190 on the scan gauge.
    El Taco Diablo likes this.
  9. Jul 8, 2018 at 8:43 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I had to replace my radiator a few months ago as well. It wasn't from the Prestone, it was just from age... the radiator had over 260,000 miles on it when it popped. Which is actually a lot more miles than I usually see people talking when their radiator goes... normally that seems to happen between 180,000 and 230,000.
    When I replaced the radiator, I also did the water pump, thermostat, timing belt etc. The waterpump was still not even leaking at 260,000... I saw no indication of any problem being caused by the Prestone.
    Nessmuk likes this.
  10. Jul 8, 2018 at 2:27 PM
    ggmanning
    ggmanning Well-Known Member
    07 FJC, 03 TRD Offroad, 11 TRDPro, 14 Landcruiser
    I use Pentafrost. They have a red and a pink Toyota equivalent depending on what year Toyota you have. As stated yours is red......newer models are pink. I use their blue Nissan equivalent also.....good stuff.
  11. Jul 8, 2018 at 8:33 PM
    vern650
    vern650 Well-Known Member
    brandon
    hyrum, ut
    '97 4x4 taco xtra cab 3rz/5spd
    HBS leveling kit, 31x10.50 mudders, header/imco exhaust, rear billies, LR ucas, home brewed onboard air, cb radio
    Use whatever color is in there to keep it simple, but any color WILL work and WILL NOT damage anything.
  12. Jul 8, 2018 at 8:40 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    As long as you keep it the SAME color. Toyota Red + any Green, over time, WILL gum up the system. I've seen it first hand.
    And Dexcool + Toyota red = you're fucked.
  13. Jul 8, 2018 at 9:02 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Toyota Red Long Life
    TRVLR500 likes this.
  14. Jul 8, 2018 at 10:06 PM
    UnderFire
    UnderFire Well-Known Member
    Seen it first hand, when you mix red and green it eventually turns into gummy orange crap in the coolant passages inside the engine and heater core, you can't tell by looking into the radiator, but once you start tearing into stuff it ain't pretty.
  15. Jul 9, 2018 at 4:35 AM
    johnny3
    johnny3 Well-Known Member
    01 Tacoma TRD
    Peak Global concentrate in the tan bottle.
  16. Jul 9, 2018 at 5:09 AM
    Clearwater Bill
    Billy
    Largo Florida
    :eek:
    Have to add that to my book in the chapter 'First I Heard of That'
    :D
    DoorDing and Wulf like this.
  17. Jul 9, 2018 at 5:15 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Some people love to waste money.
    I use zerex asian BLUE! I like to be different. Lol.
  18. Jul 9, 2018 at 6:12 AM
    Pervy
    Pervy Well-Known Member
    East Texas
    2.4 Tacoma, 3.4 4Runners
    Does sound a bit extreme haha, but it is certainly one way to not have coolant issues.
    Personally all I do is just change out my coolant reservoir every oil change or so since flushing is a pain. Do the same for powersteering and brake fluid (occasionally) - but more so just to get rid of the extra bottles of ATF/Dot I have left over haha. I'm waiting for the drain holes to finish drizzling anyways.
  19. Jul 9, 2018 at 7:18 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Lol... I'll just keep "wasting money"
    Meanwhile... I got over 260,000 miles out of my water pump and radiator, while on average I see others lose theirs at around 175-180,000 miles. :thumbsup:
    JayRolla[QUOTED] likes this.
  20. Jul 9, 2018 at 8:21 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Around 5000 miles sometimes a bit longer if I'm being lazy. I use High milage Mobil 1 syn and Lucas oil stabilizer.
    So an extra $12-$15 every 5000 miles isn't that big of a deal. And again, I'm not saying I flush the antifreeze every oil change. I just dump the radiator and refill... takes longer to bring it up to operating temp on refill than anything. But while I'm running it up to operating temp is when I'm doing the rest of my visual inspection and looking under the truck to make sure I didn't leave out the plug or something stupid.
