What type/gauge wire for led pods?
Discussion in 'Lighting' started by Thyces, May 6, 2017.
  1. May 6, 2017 at 8:48 AM
    Thyces
    Thyces [OP] 2 seater taco
    Ontario
    2009 DCLB TRD Sport
    Custom painted 6112's Fox 2.0 12" in the rear Allpro expedition leafs (garbage) Pelfreybilt aluminum single hoop front Full size pickup bedslide modded to fit Satoshi grill Ubolt flip kit Archive garage shackle flip 5" Sumo supersprings 1500lbs SPC uca's Full set RCI skid plates Weld on sliders ABS killswitch Pop'n'lock power tailgate lock Falken Wildpeak mt on FJ rims Plastidipped emblems Ebay projector headlights Smoked aftermarket tail lights High output led reverse lights Hella horns 330w 5d led bumper bar 18w spots on track facing rear (fuck you lights) B&m trans cooler Bussmann fuse box ECGS bushing Big 4 (0 gauge ofc wire) upgrade Mechman 240 amp alternator Jl 10w7 in a 1 1/2" thick wall custom box Alpine 1000w rms mono amp Group 31 AGM battery installed next to sub Yaesu 2800 Bearcat 980 in dash with wireless mic and stainless whip Diff breather mod Hilux snorkel Turbine pre filter Baja Rack low profile cab rack Rifle case on rack Shovel and axe on quick fists in bed Flat and spade shovel mounted in bed Highlift mount in bed Tech deck with magnetic ram mount Tab s7 on ram mount
    I have a few led pods and one bar I need to install and wire to my bussmann. Just wondering what kind/gauge wire I should be looking to get. I'm running everything in a 3/8 split wire loom. Max watts would be 300 on the bar.
  2. May 6, 2017 at 9:23 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Wire gauge all depends on the amount of current that you're pulling. If you google 'wire current capacity', you'll find a bunch of sites with good information. This is the one I usually check first (http://www.powerstream.com/Wire_Size.htm). Anything you find online is an extremely conservative estimation and most likely bigger than you need.
    For your light bar pulling 300 watts (25A@12V), 14 gauge will cover you. Remember though that you don't need to wire everything in 14 gauge. The switch and relay coil can be smaller gauge. I usually go with 18 gauge for that which is massive overkill for the amount of current that the relay coil pulls, but it's easy to source and work with. 20-22 gauge would be fine for the switch/relay coil, but it can be a pain working with the wires as they get thinner.
  3. May 6, 2017 at 10:20 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    Cool. Thanks for the info. I'll probably be buying a 100' roll so I'll use the 14 for everything. I have the trigger wire and switches all wired already so basically just need to run wire from pods to bussmann. Any particular type of wire? Or is any automotive grade wire OK.
  4. May 6, 2017 at 10:23 AM
    Thyces
    Ontario
    2009 DCLB TRD Sport
    I actually have 14 gauge speaker wire, would it be OK to use that inside the split loom?
