What transmission numbers?
Discussion in '1st Gen. Tacomas (1995-2004)' started by juan chicoy, Jun 1, 2018.
  1. Jun 1, 2018 at 8:55 AM
    juan chicoy
    juan chicoy [OP] Member
    2002 tacoma 2wd
    hi,
    have a 02 tacoma 2wd, reg cab, 2.4 motor, need to replace clutch....in ordering input and output shaft seals the parts man wants to know what transmission i have....he said there would be #s on the trans....where would i find them?....i have had no luck....thanks....juan
  2. Jun 1, 2018 at 10:00 AM
    v5ensx
    v5ensx CARB legal is not CALI legal
    Checked label on driver door jam? It will tell you what type of transmission you have
  3. Jun 1, 2018 at 10:13 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    I think you have a w59-b but i could be wrong
  4. Jun 1, 2018 at 12:30 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Says on the VIN sticker. Pretty sure you have the W59. R150 came on the v6 5-lugs, and the R150F came on all 4x4 Manual v6 trucks.
    1995-2000 Automatic will be the A43D column shift, 2001-2004 Automatic will be the A44D floor shift.
    1995-1998 v6 Auto 5-Lugs had the A340E, along with all Automatic PreRunners. 1995-2004 4x4 Auto has the A340F, while the 4x4 Manual v6 has the R150F. The 4x4 Manual I4 always had the W59.
    Fun Fact: The Toyota Supra used the A340E, as well as Isuzu box trucks.
    Geneyota likes this.
  5. Jun 1, 2018 at 12:32 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    any 2wd v6 had the R150, 4x4 had the R150f. Idk what the difference is other then one was for 2wd and one is for 4wd
  6. Jun 1, 2018 at 12:35 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I’ve never heard of the “-b” designation before on the W59, is that what your VIN sticker says?
  7. Jun 1, 2018 at 12:36 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yep. F designates a 4x4 truck. I’ll fix that.
  8. Jun 1, 2018 at 12:39 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I think the 4cyl came with a w series tranny which is not as strong as the R series. But with the right adapter you can mount the stronger R series up to them. If I remember right.
  9. Jun 1, 2018 at 12:46 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Right. All 5-Lug I4 Manuals and 4x4 I4's came with the W59. The stronger transmission was the R150 series.
  10. Jun 1, 2018 at 12:49 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    I think i heard guys take the r154 (which is from a supra i think) when they can find one and swap bell housing so it bolts up to a engine that came with a W. I could be wrong though
  11. Jun 1, 2018 at 9:37 PM
    juan chicoy
    2002 tacoma 2wd
    Thank you all, it is a w59.....juan
