What trailer hitch?
Discussion in '4 Cylinder' started by clc clc, Dec 7, 2013.
  1. Dec 7, 2013 at 2:20 PM
    clc clc
    clc clc [OP] Well-Known Member
    PA
    2012 4x4 reg cab tacoma/2020 subaru crosstrek
    Im looking at getting a class III hitch for my truck and need help picking a brand. Looking at them online they all seem to be priced similar so what are the brands to go with and some to stay away from? My friend suggested going to the local U-Haul store.
    I plan on using it as a recovery point and for hauling a small boat.
  2. Dec 7, 2013 at 2:36 PM
    BDBSoCal
    BDBSoCal The Safety Guy
    Brad
    SoCal
    Silver 2008 SR5 V6 4x4 TRD Sport
    Just starting...
  3. Dec 7, 2013 at 2:41 PM
    clc clc
    PA
    I actually don't have a boat yet but I am most seriously buying one by spring. Problem is I cant really think about buying a boat until I get my truck rigged up to haul one. Sooooooooo........ I need help getting set up.
  4. Dec 7, 2013 at 3:34 PM
    toyodajeff
    toyodajeff Well-Known Member
    jeff
    06 reg cab sr5
    HLook on craigslist, I got a factory one new in the box for $75.
    The factory one seems to be fine, but I dont have another one to compare it to. Also the little circle covers over the bolt holes on the plastic tag piece wont work anymore and you will need some that are dome shaped. IF whatever hitch you get doesn't come with them and you want the holes covered, I price checked them at the dealer and I believe they were $38 a piece and you need 2.
  5. Dec 7, 2013 at 3:42 PM
    MudFlap
    MudFlap Well-Known Member
    Tim
    Memphis (north mississippi)
    2012 TRD Off Road
    I wanted to point out that it is probably best to TOW the boat and not HAUL it. LOL :eek:
    Just bussin your balls bro...... no harm intended
  6. Dec 7, 2013 at 10:05 PM
    rickcrna
    rickcrna Well-Known Member
    Rick
    Vancouver, WA
    '13 AC SR5 4WD I4 Auto MGM
    Curt seems to make good hitches and are reputed to be easy to install on the Tacoma/
  7. Dec 7, 2013 at 10:09 PM
    TexasPreRunner
    TexasPreRunner Well-Known Member
    Anthony
    San Antonio/Houston,TX
    2011 PreRunner
  8. Dec 8, 2013 at 4:11 AM
    Tacoma Mike
    Southern Maine
    If your going to be using it as you describe then a factory hitch would be your best bet.
    The factory setup has reinforcement plates that wrap the side of the frame at the attachment points. I have not seen any other hitch come through the shop
    with these added plates. This would help any side loads you may put on the truck. There are new bumper plates also.
    Hitches have different price ranges but like anything else, you get what you pay for.
    Your not setup for the heavier capacity so the factory maybe a little overkill but I would rather see u with it with your intended use. Just my opinion.
    Also.
    It's has been beat to death but the factory wiring setup is the way to go.
    Aftermarket stuff is crap. I see so much corroded wiring from scotch locks etc it is horrible.
    The factory plugs unto the trucks system. Uses factory fuse locations.
    We change out more u-haul stuff than anything. Converters fry and feedback causing all sorts of issues.
    If you think a factory hitch is overboard for you that's understandable. But do yourself a favor and get a factory harness.
    :wave:
  9. Dec 8, 2013 at 11:19 AM
    ecoterragaia
    ecoterragaia Everyone lives downstream.
    Central Virginia
    2006 RC 4X4 5 speed & 2021 4Runner SR5
    I've got a Curt on mine, it was very easy to install. High quality product, no problems in over a year.
  10. Dec 8, 2013 at 2:55 PM
    clc clc
    PA
    What do you mean by bumper plates?
    Honestly I didn't think of going OEM so that might be the way I go. So Ill need the hitch (PT791-04050), harness (PT725-35120) and obviously the ball and all that but am I missing any important OEM parts for the factory TOWING setup?
  11. Dec 8, 2013 at 3:48 PM
    Tacoma Mike
    Southern Maine
    The side plates are also the bumper plates. Sorry I mistyped.
    They are much thicker and extend across the side of hitch and frame to the bumper. It really reinforces the back corners of the frame.
    As far as the factory towing setup with a v6 a bigger battery, alternator, oil and trans coolers. Your limited to 3500 pounds anyway no matter what you do to the truck. Either a 4 or 6 would benefit from a cooler. 4cyl should be used for lighter loads anyway.
  12. Dec 10, 2013 at 12:15 AM
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Curt 13323 hands down
    https://www.curtmfg.com/part/13323
    $116 on Amazon + free shipping at time of posting this
    Carried a 1500 trailer from Oak Harbor, WA to Spartanburg, SC with no problems.
  13. Dec 11, 2013 at 2:07 PM
    Maineiack
    Maineiack Well-Known Member
    Maine
    2013 stock reg cab 4x4
    Yeah, I looked into getting a factory one and it was $350 for just the hitch, not including the wiring harness. I think the price is more overkill than the tow capacity. Do you know of any used ones sitting around??
  14. Dec 11, 2013 at 3:45 PM
    Tacoma Mike
    Southern Maine
    He wanted to use the hitch as a recovery point hense the info for the factory hitch. Like I said it has it's advantages. If we have any laying around they are not worth using. ...
    You wouldn't want to put a rusted out old hitch on a new truck.
  15. Dec 13, 2013 at 7:55 AM
    Maineiack
    Maine
    true.
  16. Dec 22, 2013 at 3:42 PM
    clc clc
    PA
  17. Dec 22, 2013 at 3:57 PM
    EatMyTacomaDust
    EatMyTacomaDust Well-Known Member
    2014 "Black Beauty" Baja DC 4x4
    ICON 3" LIFT, Console Vault, Tailgate Security Clamp MOD, SuperBumper Crash Attenuator, TRD Front Skid Plate, Wet Okoles - 1/2 Piped, Undercover SE Tonneau
    Agree with the Curt Hitch. Good Price / Easy Install. Good Product - American Made.
    Got one on my Tacoma.
