What Tonneau Cover
Discussion in '3rd Gen. Tacomas (2016-2023)' started by sittingbull, Jul 31, 2019.
  1. Jul 31, 2019 at 8:03 PM
    sittingbull
    sittingbull [OP] Well-Known Member
    Long story short I need a new cover I had 3 Extang Solid Fold 2.0 Tonneau Cover but its a big pile of crap. I been thru 3 in 3 years 2 leaked like swiss cheese and the other one the brackets broke so im done with that brand..
  2. Jul 31, 2019 at 8:41 PM
    GrittyTaco
    GrittyTaco Well-Known Member
    Hatboro, pa
    2017 dclb trd or
  3. Jul 31, 2019 at 8:43 PM
    timlovestacos
    timlovestacos Well-Known Member
    Tim
    Orange County, CA
    2018 TRD 4x4 OR Silver
    Spend the money and go Bakflip. You won’t regret it. Had mine almost 15 months now and zero issues.
  4. Jul 31, 2019 at 8:48 PM
    AKGSD
    AKGSD Warranty denied
    Joe
    Alaska
    2019 QSDCSBTRDOR4X4V6MT
    Dog hair, metaltech 4x4 rocksliders, KBVooDoo bed risers, Smittybilt RTT, 3” spacer lift (Removed!), caliraised ditch lights, amazon rock lights, OVtune, Skewp
    I’m sure you could find someone happy to be rid of their factory cover
  5. Jul 31, 2019 at 8:49 PM
    SCORPION 1A
    SCORPION 1A Well-Known Member
    Buffalo, NY area
    2017 TRD Off Road - Inferno
    Diamondback is the way to go for complete security and waterproof. A neighbor has one for over 10 years and only replaced the gasket seal once about 2 years ago. They are expensive but well worth it in my opinion.
  6. Jul 31, 2019 at 9:19 PM
    ILiketoFish
    ILiketoFish Member
    I have a Bakflip MX4.. a couple of things to keep in mind: water will still get inside the bed, prone to dent because it's aluminum. Kind of wish I went with a diamondback, but I'm happy enough with the BF to not want to get a DB just yet.
  7. Aug 1, 2019 at 9:32 AM
    LSUfan1975
    LSUfan1975 Well-Known Member
    Eric
    Washington NC
    2019 SR5 Dbcb MGM
    Bak flip or undercover. Both are owned by the same company truck hero. I went with undercover because i didn't want the cover sitting against my back glass when open. Pretty much the same other than that. Both will leak around the edges. It's a toyota problem not a cover problem. Look at the gaps between the body parts on the bed. You could easily make it water tight with a caulk gun though. I just don't have the time or worry enough to do it. Dbs are nice to look at. But $$$$$$ and heavy. Not practical either if you haul Anything taller then the bed rails.
  8. Aug 1, 2019 at 9:40 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Extang Trifecta.
  9. Aug 1, 2019 at 9:46 AM
    raidercraig
    raidercraig Well-Known Member
    Bak Flip MX4
    Under $900 is easy to find
  10. Aug 1, 2019 at 11:22 AM
    sittingbull
    Thanks for the replys. I paid like 800 for the extang and i can deal with the leaks around the corners but when they leak in the middle of the cover is where i get pissed. I will look at the ones you guys posted
    Thanks
  11. Aug 1, 2019 at 11:28 AM
    Steve0ct
    Steve0ct Well-Known Member
    CT
    2017 TRD Off-Road DCSB White
