What to look for when maint reqd light comes on?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Paulh, Oct 13, 2014.
  1. Oct 13, 2014 at 7:08 AM
    Paulh
    Paulh [OP] Member
    paul
    Atlanta
    2010 Prerunner V6
    My 2010 tacoma "Maint Reqd" light just came on at 48600 Miles. Beside the basic oil, air filter, microfilter change, is there anything I need to look for? Sorry I'm new so forgive me if I post in wrong place. I plan to do it myself. thanks.
    I forgot to mention mine is CPO. I haven't call them. should I bring it in or I better take care it myself. Thanks.
  2. Oct 13, 2014 at 7:18 AM
    medic2230
    Murph
    Bama! Roll Tide
    It's just telling you it's time for the oil change since the last oil change and light reset. Change oil, filter, and check your cabin air filter. You can lube the various zerk fittings also and rotate your tires. As far as them or you doing it, it's just a matter of what you want to do.
  3. Oct 13, 2014 at 7:22 AM
    06yoda
    06yoda Well-Known Member
    Tanner
    Clovis, CA/ Emmett, ID
    1996 Landcruiser FZJ80
    After your done doing it make sure you are reading your odometer miles and hold the trip button while the truck is off and turn the key to ON just don't start it, and you will see the trip turn to dash marks and it will reset your light and interval so it will sart a new schedule for you.
    YouTube has a few vids to reset.
  4. Oct 13, 2014 at 7:35 AM
    SeaToSky
    SeaToSky Sea to Sky
    Travis
    Wet Coast of BC
    TuRD
    Lift, tires, sliders, skids, and growing collection of comfort items
    2011's need to be set to Trip-A
  5. Oct 13, 2014 at 7:42 AM
    Paulh
    Paulh [OP] Member
    paul
    Atlanta
    2010 Prerunner V6
    Ah tires rotating. good one. didn't even think of that. Thanks!
  6. Oct 13, 2014 at 7:46 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Maint Required light will FLASH on & off at 4500 miles and stay on constant at 5,000. It's an oil change reminder....
    How long have you had this truck? Do you have any past maintenance information on it? There is a lot of other maintenance that you should verify that its been done in the past..... like differential oils, lubricate drive shafts, spark plugs, etc.
    Don't forget to rotate tires every 5,000miles.
  7. Oct 13, 2014 at 8:01 AM
    Atomic47
    Atomic47 Well-Known Member
    Denis
    Manitoba, Canada
    08 V6 4x4 TRD Sport
    Leveling kit, AAL, air-ride, Rear diff breather mod, Illuminated 4wd Switch, 4 more D rings, fog lights anytime, 7 pin relocate, Coca-Cola mod, TRD Off-Road hook, Weathertechs, secret custom cargo light, 09 lower dash panel, heated seats, 2013 oem touch screen radio, reverse camera added into Pop'n'Lock locking tailgate handle, black powder-coated TRD Sport rims, 32" light bar in custom fabricated mount, aux reverse lights in rear bumper
  8. Oct 13, 2014 at 8:06 AM
    Paulh
    Paulh [OP] Member
    paul
    Atlanta
    2010 Prerunner V6
    I have it since May of this year. This is my first Maintenance. I looked up the service hist from Toyota website but it's unclear what has been done. None of that mentions anything regarding differential oil or spark plugs etc. Here is the portion of most recent services maybe someone can read it better than I do...
    03/12/2014 Dealer Atlanta Toyota 41,209 Repair Order Number: 0589253
    40K SVC FACT REC, INSPECT TIRES, BRAKE INSPECTION, YLW TREAD DEPTH 10/15/2013 Dealer Atlanta Toyota 35,676 Repair Order Number: 0988431
    35K SVC FACT REC 05/17/2013 Dealer Atlanta Toyota 30,490 Repair Order Number: 0959887
    30K SVC FACT REC 12/04/2012 Dealer Atlanta Toyota 25,250 Repair Order Number: 0929807
    25K SVC FACT REC, *REPL.AIR FILTER
    The rest....
    06/07/2012 Dealer Atlanta Toyota 20,180 Repair Order Number: 0896965
    20K SVC FACT REC, BLOWER 01/06/2012 Dealer Atlanta Toyota 15,104 Repair Order Number: 0870332
    15K SVC FACT REC, *BALANCE(ADD TO ROT), MISC RECALL 07/09/2011 Dealer Autonation Toyota Mall Of Georgia 9,972 Repair Order Number: 0738658
    VIP CAR CARE OIL AND FILTER CHAN 02/07/2011 Dealer Stone Mountain Toyota 4,580 Repair Order Number: 0254197
    5K FACTORY SERVICE TRUCK, OIL &, MULTI POINT INSPECTION AND RECOM 09/15/2010 Dealer Stone Mountain Toyota 3 Repair Order Number: 0241708
    90L PDL & FLR MOD, REFLSH, SSC
  9. Oct 13, 2014 at 10:39 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    it is also a reminder to read the owner's manual. ;)
