What to look for on buying a used Tacoma?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by joms, Feb 8, 2024.
  1. Feb 8, 2024 at 11:29 AM
    joms
    joms [OP] Well-Known Member
    2021 Super White Tacoma SR5 2wd
    Bone stock baby
    Pretty common sense on what to look for but, what do you guys commonly check on used tacomas ( common problems/issues)?
    I just got my 21 sr5 2wd yesterday and it looked and sounded okay when I checked it but not sure what to really look out for. Noticed some rust on the outter part of the drum brake but I believe it would be normal since it’s cast iron? I know it’s a 2wd but it’s my daily and I have my 17 TRD offroad tundra 4x4 on standby for some outback adventures.
  2. Feb 8, 2024 at 11:38 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Surface rust is completely normal.
    I would check for timing cover leaks and coolant bypass leaks. They are pretty pricey to fix when you are out of warranty.
    GarrettTacoma, kahanabob and joms[OP] like this.
  3. Feb 8, 2024 at 11:38 AM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    Two big things are:
    1. Timing cover (big job)
    2. Composite cooling tube on back upper engine
    kahanabob, joms[OP] and Junkhead like this.
  4. Feb 8, 2024 at 11:53 AM
    joms
    Bone stock baby
    Thanks guys much appreciated
    Chew and Junkhead like this.
  5. Feb 8, 2024 at 12:03 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    to check coolant crossover pipe crawl under passenger side behind the front wheel. shine light up behind the engine and look for pink corrosion build up. if it is there you will see it, can't mistake it for anything else.
  6. Feb 8, 2024 at 12:07 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Apparently steering racks seep too. I don’t think it’s a very common issue though. I checked mine the other day and things look good.
    joms[OP] likes this.
  7. Feb 8, 2024 at 12:13 PM
    joms
    Bone stock baby
    @Junkhead @Chew @kahanabob A lot of good info. Forgot to put the mileage on my truck it has 23900+ miles. Hoping these issues would not come to surface around this lifetime of the truck
  8. Feb 8, 2024 at 12:14 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Chew and joms[QUOTED][OP] like this.
  9. Feb 8, 2024 at 12:15 PM
    joms
    Bone stock baby
  10. Feb 8, 2024 at 12:38 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    If it’s still under warranty, take a look at both, or get it checked out by an independent shop in the know. The timing cover is definitely worth it. It’s rumored, they now have a way to replace without removing the engine, but full removal has historically been the fix.
    joms[QUOTED][OP] likes this.
  11. Feb 8, 2024 at 12:49 PM
    OZ TRD
    OZ TRD Well-Known Member
    Central Coast CA
    6sp Manual TRD PRO - Lunar Rock '21
    Evo A SmartCap, Cali Raised Sliders (0 degree), 2WD low Mod, Puddle Pods, 3 switch overhead panel, 8 slot middle console panel, Custom driver's switch panel, Rek Gens, 265 75 16 Falkens, lil B Bed Stiffeners, All new Speakers, Diff Breather, AC Drain, Many interior bits...
    Review the owner's maintenance record on toyota.com
  12. Feb 8, 2024 at 2:49 PM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    For me, when I go to buy any vehicle....
    -In-the-ballpark price (too cheap is usually a red-flag)
    -Reasonable amount of Kms/miles for its age (super low kms isn’t always better IMO)
    -Body/interior in good shape.
    -Unmodified or reasonably modified.
    -One owner is usually better.
    -A service history or a stack of receipts is always a good sign.
    -Good vibes and no sketchy feelings about the seller.
    -No ‘Monster Energy’ or similar stickers.
    An good/honest seller will take it to a reputable shop for me to do an inspection on a hoist (not expected on a $1000 as-is vehicle but definitely on any 3rd Gen Tacoma)
  13. Feb 8, 2024 at 3:01 PM
    joms
    Bone stock baby
    @Big tall dave thank you. I’ve been reading about these timing cover leak issues and it kinda gave me an uneasy feeling about these trucks. Just inspected it today and no leaks so far. Will keep an eye on it tho. It’s a certified pre-owned so hopefully everything is good with the truck.
