What to do about battery acid leaking from caps
Discussion in '1st Gen. Tacomas (1995-2004)' started by cmj, Nov 17, 2013.
  1. Nov 17, 2013 at 10:24 PM
    cmj
    cmj [OP] Well-Known Member
    Oregon
    98 Tacoma 4x4
    There is a 4 year old NAPA battery in my truck and it leaks acid on to the metal around it. The acid is filled just enough to cover the plates, so it doesn't seem overfull. Short of replacing the battery, is there anything I can do about it?
  2. Nov 17, 2013 at 10:39 PM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    Clean it up with some baking soda and water but it must be unplugged and make sure you don't short the terminals. Use a terminal brush then apply dialectic grease on the terminals and it should be clear of the acid for a while. I'm not too familiar with batteries but I wouldn't replace it until it's reliability is compromised.
  3. Nov 17, 2013 at 10:45 PM
    cmj
    Oregon
    98 Tacoma 4x4
    Thanks for the reply zbaldo. I should note that its not so much the buildup on the terminals as it is just leaking from the vent covers.
    I cleaned it all up today - removed the rust and painted over, but I don't want to have to do it again. Alternator seems fine at about 14.1 volts. The battery is operating fine except for the leak.
  4. Nov 17, 2013 at 11:07 PM
    zbaldo
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    It seems like you have it under control but I will say that "the traveler" I think had a battery blow in the sense that the acid dispersed all over his motor compartment. If you want the thrill of knowing that your truck may not start someday or splatter battery juice then keep it as is, it may be time to swap batteries or start saving up. Good luck man
  5. Nov 18, 2013 at 6:00 AM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    I would consider swapping the battery. Something is going on, whether it's a compromised case, or cover...or? this would be much cheaper than fixing rusty sheet metal and damage caused by the battery acid.
    Look into the Optima battery....you'll never have that problem again. Optima used to be a high quality battery, but I don't have any experience with them recently.
  6. Nov 18, 2013 at 6:15 AM
    BamaToy1997
    Bill
    Navarre, FL
    If there is repeated discharging of the electrolyte in the cells, then the battery is on it's way out the door. That is usually an indication that a battery is not properly taking a charge, or overcharging. What is most likely occurring is that the battery is getting too hot while charging, and the electrolyte is boiling. When it boils the electrolyte becomes an explosive gas, and any spark can ignite said gas. Replacement of battery is your only safe and correct solution at this time. I have seen this failure result in a blown battery, and you do not want to be around it.
  7. Nov 18, 2013 at 6:37 AM
    offrdmania
    offrdmania Taco Wagon
    Templeton, Ca
    96 Tacoma LX 4 banger
    Like said above, pick up an Optima which uses gel so its a sealed unit without any vent holes
  8. Nov 24, 2013 at 9:08 PM
    Bahamayellow
    Bahamayellow Well-Known Member
    2002 tacoma sr5
    I agree with the other posts. Probably a bad cell acting up. I have seen them before. I would replace it. I like the carquest battery as it is totally sealed with no caps and a small vent hole to the side of battery. It doesn't corrode ur terminals.
  9. Nov 24, 2013 at 9:16 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Optima is not that it was a few years ago.
    Best to stick with tried and true Die-Hard.
  10. Dec 1, 2013 at 5:55 PM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    The four more common causes for wet batteries to leak electrolyte through their vent caps are overfilling, overcharging, overheating, or a combination of the above.
  11. Dec 1, 2013 at 6:18 PM
    hitmans.army
    hitmans.army Just a guy.
    Myrtle Creek, OR
    '07 PreRunner & '40 Chrysler Coupe
    Bilstein 5100s up front with OME 885s, rear Add-A-Leaf, LED lights (tails, dome, map, plate lights), Kicker 8" in custom fiberglass enclosure under back seat, Kicker speakers throughout and Kicker amp for sub, Pioneer DVD Player, Satoshi Grille with Devil Horns, Leer 100XQ.
    Like stated ^^^, sounds like there is an issue with over charge/heat. While I do run a RedTop in my truck, Optima is no longer the only option at auto parts stores for an AGM battery. Also, look at Walmart. Some still carry batteries with a 5yr free replacement warranty and most have the 3yr.
  12. Dec 1, 2013 at 8:50 PM
    cmj
    Oregon
    98 Tacoma 4x4
    I've been keeping an eye on it. I think its just splashing when I go over bumps. Its not leaking bad, but there is a little dried electrolye on the top. The vent holes are pretty big on this battery and the caps don't really have any baffles to keep the stuff from splashing out. I'll get one of those AGM batteries when this one takes a dump
  13. Dec 2, 2013 at 6:51 AM
    Rickalders
    Rickalders Well-Known Member
    Has anyone suggested checking your charging system for over voltage? If the electrolyte isn't overfilled and it's still being expelled though the caps, I'd check the charging system first. If that's ok, probably time to replace the battery. Four years isnt necessarily young in battery years...
  14. Dec 3, 2013 at 4:39 AM
    Hansel
    Glenn
    Arizona
    base
    good point. I've had many years of experience with batteries, and usually four years is pushing it. Of course it depends on many factors...but my guess is you'll be replacing it pretty soon anyway.
