What tires are good for 15x8 wheels
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rise007, May 28, 2020.
  1. May 28, 2020 at 8:21 PM
    Rise007
    Rise007 [OP] Well-Known Member
    2012 white Tacoma 5 speed manual
    Just bought me some aftermarket rims and idk what size of tires I should put on it. I want all terrain tires but I want a good sidewalk for the tires and also want it to look wider when the tires on, what could be a great size of tire for my 15x8 rims
  2. May 29, 2020 at 1:38 AM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    are you sure them rimzzz will clear your calipers yet???
  3. May 29, 2020 at 6:05 AM
    Rise007
    They should it just one inch wider stock ones are 16x7
  4. May 29, 2020 at 6:08 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
  5. May 29, 2020 at 6:13 AM
    Rise007
    It should a clear man they deep dish but not to much offset
  6. May 29, 2020 at 8:18 AM
    JL8Jeff
    JL8Jeff Well-Known Member
    Jeff
    Ewing, NJ
    2013 Tacoma reg cab
    OME 885/nitros, SPC UCA, 305/65/17, AAL
    If you have 4 wheel drive or the 6 lug wheels, 15" wheels won't clear the brake calipers, it needs at least 16" or larger. The width of 8" vs 7" doesn't make a difference. But offset or backspacing can make a difference. Let us know exactly what your 2012 truck is, 2wd or 4wd and how many lugs hold the wheel on , 5 or 6?
  7. May 29, 2020 at 8:53 AM
    Rise007
    6 lug 4x4
  8. May 29, 2020 at 8:59 AM
    Rise007
    Damn hopefully they fit man you got me worried now
  9. May 29, 2020 at 9:06 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Pretty sure you're going to have to grind down some of your caliper for clearance. What made you want to get 15in wheels?
  10. May 29, 2020 at 9:10 AM
    Rise007
    I like small rims and well also looking to get a tire with big side wall
  11. May 29, 2020 at 9:16 AM
    MAG GRY TACO15
    Alan
    GA
    '15 TRD Off-Road
    well best of luck. let us know how it goes. when you test fit one of your wheels.
  12. May 29, 2020 at 9:46 AM
    Muddinfun
    Muddinfun Well-Known Member
    15s on a 4WD only work in Hawaii.
    Wattapunk likes this.
  13. May 30, 2020 at 5:31 AM
    Rise007
    Well I gotta say they look sick but the calipers hits, I was think on looking for slimmer calipers or just get spacer, I also could grind them but that not might be a good idea
  14. May 30, 2020 at 9:04 AM
    Cbak_Taco
    Cbak_Taco Well-Known Member
    2008 Silver Tacoma Prerunner
    I got a set of spidertrax spacers I’m not using anymore if you wanna pm me, if not good luck my man
  15. May 30, 2020 at 9:40 AM
    dairyman
    dairyman Well-Known Member
    Beat up 08 Tacoma
    3” lift 285s
    I ground my calipers down and it worked good for awhile but off-roading in sand and mud eventually rubbed a hole in one side.
  16. May 30, 2020 at 9:42 AM
    Rise007
    Do you mind sending a picture of them grinder down? You think spacer would help just to not grind a lot from the caliper???
  17. May 30, 2020 at 9:48 AM
    dairyman
    Beat up 08 Tacoma
    3” lift 285s
    It’s hard to tell but I just put the wheel on and spun it and then ground where it hit. It took about 10 tries till they cleared. If you grind too much it will go through and junk the caliber FD04D2F8-1F0C-4408-AA08-790D32751A6A.jpg
  18. May 30, 2020 at 9:49 AM
    dairyman
    Beat up 08 Tacoma
    3” lift 285s
    My wheels are 16” so it might not even be possible with 15”
  19. May 30, 2020 at 3:41 PM
    Rise007
    Well they do fit I am thinking on adding spacer so I’ll just have to grind less on the caliper so I am with one question what’s the backspace of the stock 16 6lug wheel so I know what spacer I need
  20. Mar 9, 2022 at 2:57 PM
    1stTacoDre
    1stTacoDre Member
    Andre
    Toyota Tacoma TrdOffRoad ‘21
    Front Grill/ Raptor Lights Off Line Dash Cam Front/Rear Hard Low profile RC Bed Cover
    Any updates ?
