What thickness steel for rear bumper?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Dogs, Mar 26, 2018.
  1. Mar 26, 2018 at 4:05 PM
    Dogs
    Dogs [OP] Well-Known Member
    Nick
    Missouri
    02 tacoma TRD SR5
    I'm going to build a rear bumper with a swing out tire carrier. I'm just not sure how thick I should make it. Would 1/8" be enough? or is 1/4" too much? or should I go for 3/8"? Along with that, do I need to frame the bumper with tube to help strengthen it? Or will just welding the plates together be enough? If you've made your own or have any insight please let me know!
  2. Mar 26, 2018 at 4:11 PM
    Woundedyak
    Woundedyak Well-Known Member
    Indy
    Definitely 1.5 with a wall of .120 Mild. No need for D.O.M
  3. Mar 26, 2018 at 4:17 PM
    Dogs
    Nick
    Missouri
    02 tacoma TRD SR5
    The tube with a thickness of .120? What about the plate?
  4. Mar 26, 2018 at 4:21 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    1/8” is too thin to support a swingout, unless you really design it well. 1/4” is overkill unless you wheel by Braille. I have 3/16” wall rectangular tubing, it is a good compromise for strength and weight.
  5. Mar 26, 2018 at 4:23 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Most plate bumpers are 3/16"
    Blue92 likes this.
  6. Mar 26, 2018 at 4:25 PM
    kystnTRD
    kystnTRD Ramblin Man
    NW Pennsylvania
    2016 TRD Sport 6MT
    This^^^ 3/16" is the norm for mild steel on bumpers
  7. Mar 26, 2018 at 4:27 PM
    Dogs
    Nick
    Missouri
    02 tacoma TRD SR5
    Okay thank you guys! I'll go with 3/16" for the plate and .120 for the tube!
  8. Mar 27, 2018 at 10:21 AM
    jbrandt
    Justin
    BTW, you don't typically need to mix the two. Your OP mentioned using tube for the structure then plating over it. That's totally overkill.
    Unless you are doing a plate bumper with hoops for headlight/grill protection, that is..
    Here's the CBI plate bumper DIY kit for reference (no tubes). It's like an Ikea flat packed shelving unit, but with steel!
  9. Mar 27, 2018 at 10:22 AM
    jbrandt
    Justin
    :rofl::rofl::rofl::rofl::rofl:
  10. Mar 27, 2018 at 10:25 AM
    akkyle
    akkyle Well-Known Member
    Kyle
    Alaska
    2014 regular cab 4x4
    No less than 3/16 for a swingout. I retrofitted my 10ga bumper with a swingout and is a little flexy even after welding some 2x2x1/4 angle to resist flex.
  11. Mar 27, 2018 at 10:30 AM
    akkyle
    Kyle
    Alaska
    Also take not that the way the swingout is built has a big effect.
  12. Mar 27, 2018 at 11:21 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Bottom Line use what you want !
    Build it like you want After all it is yours .
    Fuergrissa likes this.
