What stand alone ECU under 1000
Discussion in '1st Gen. Tacomas (1995-2004)' started by Reyrey88, Mar 21, 2024.
  1. Mar 21, 2024 at 8:09 AM
    Reyrey88
    Reyrey88 [OP] Active Member
    I'm trying to finde a good stand alone that not over 1100.
    Can you guys help I was looking for my 01 taco 3.4 saw this
    AEM Infinity 358 Standalone ECU - 30-7114
  2. Mar 21, 2024 at 8:21 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    ... why?
    Most go megasquirt, but that whole industry is being squeezed pretty hard by the EPA.
  3. Mar 21, 2024 at 8:30 AM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    Save up some money and get a Haltech 750. Same question though, why?
    sonoran and ZColorado like this.
  4. Mar 21, 2024 at 1:31 PM
    Reyrey88
    I add a turbo kit
  5. Mar 21, 2024 at 1:32 PM
    Reyrey88
    Well this be good to start out with for now or just deal rough start up till haltec
  6. Mar 21, 2024 at 1:39 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    Definitely don't get an AEM, the company was acquired by Holley and its ECU division is dead. I cannot comment on the ECU Master, I don't know anyone who tunes that platform or uses it personally. Haltech Elite 750 is like $1100 and a patch harness is $580 from Boomslang, that would be my vote.
    sonoran likes this.
  7. Mar 21, 2024 at 1:48 PM
    Reyrey88
    Oh wow I didn't know that, okay thanks
  8. Mar 21, 2024 at 1:54 PM
    tcjacado
    tcjacado Well-Known Member
  9. Mar 21, 2024 at 2:15 PM
    Reyrey88
    Alright last question if use squirt till I get haltec what squirt should I go with it will be under 1100. Thanks
  10. Mar 21, 2024 at 4:45 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    I wouldn't mess with a half-assed solution or a stepped process, you're just throwing money away. Do you even have upgraded injectors and fuel pump to need an ECU/piggyback? You've done this backwards
    MS3 is $700 and with all the time you're going to spend wiring....
    Maybe @ZColorado can chime back in. Idk of anyone on here running a MS but doesn't mean there's not
  11. Mar 21, 2024 at 5:42 PM
    Reyrey88
    Now that you said that make me think that y it's tough getting it started . So I guessing that would make big difference starting?
  12. Mar 21, 2024 at 5:53 PM
    tacoman2001$
    tacoman2001$ Well-Known Member
    Dear god this thing won't even make it through a tuning session. Stock PCV system with a catch can? Maf sensor isn't even plugged in. Zip tie and glue for vacuum lines? Also that's a fucking massive turbo for a tiny 3.4l that things gonna take forever to spool. The MAF sensor isn't in a good spot and probably won't read the best. I don't want to be mean its cool I just don't want you to go try to get it tuned and A) get it tuned with a bunch of problems or B) get sent away for issues. I would start with fixing the PCV system and pressure testing the cold side and make sure it holds above your boost level.
  13. Mar 21, 2024 at 5:55 PM
    ZColorado
    13 DCSB OR 6MT
    This process usually works because the tuner you use has a brand they like. You should not just buy an ECU and expect it to work. There is a great deal of specialized knowledge and testing and changing to get right.
    Find a tuner, and ask them. We are not the right group to ask.
  14. Mar 21, 2024 at 6:00 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    So you're having difficulty starting on an otherwise stock system minus the turbo system?
    The picture you posted... is that how it currently sits?
  15. Mar 21, 2024 at 6:00 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    You're right but he already did it so no need to be a dick
    My question is why is his BOV attached to the fuel pressure regulator
  16. Mar 21, 2024 at 7:04 PM
    Reyrey88
    It was how cx one was set up. I kinda question it but I'm not sure
  17. Mar 21, 2024 at 7:58 PM
    treyus30
    Trey
    Mesa / AJ, AZ
    We need a lot more info to help you
    Speedytech7 likes this.
  18. Mar 21, 2024 at 7:59 PM
    Speedytech7
    This!
  19. Mar 21, 2024 at 8:04 PM
    Reyrey88
    I went by this n lil by YouTube. I can get lil better pic marrow after work . If after market fuel pump injectors will help run better till I get good stand alone I'm open.
    The only problem really having at the moment is it lil hard to start.
    https://www.cxracing.com/TRB-KIT-5VZFE-IC-KIT
  20. Mar 22, 2024 at 10:47 AM
    Reyrey88
    So I saw something say the line going to the bov should be t into 1 or 2. I was also told leave the top of waste gate free wouldn't that be the same for bov or no.
    But everything dose run good just getting it started lil blah.
