What size wiper blades on 1st gen?
Discussion in '1st Gen. Tacomas (1995-2004)' started by coff33, Dec 22, 2021.
  1. Dec 22, 2021 at 5:20 AM
    coff33
    coff33 [OP] Well-Known Member
    5vzfe manual
    I think the PO installed a different size on this one.
  2. Dec 22, 2021 at 7:19 AM
    02hilux
    Planet: EARTH
    Should be 17" for both driver and passenger side
    Nessal and ControlCar like this.
  3. Dec 22, 2021 at 7:23 AM
    Wulf
    Wulf no brain just damage
    rock raisin
    I put 19" on the driver and 18" on the passenger for a bit of extra coverage
    tha_roost likes this.
  4. Dec 22, 2021 at 7:31 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    That little extra
  5. Dec 22, 2021 at 7:48 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Just as a reference......
    Any place that sells wipers has some sort of an index to determine the wiper needed. Some indexes are manual paper catalogs, others are electronic push button units.
    Really, no need to remember.
    Our stable has vehicles, 8 wiper blades are needed for our fleet. No way do I try to remember which ride needs what size wiper. Every wiper is a different length. If I try to remember all that, then I'll forget the combination to my bicycle lock.
    RobZ9132 likes this.
  6. May 30, 2024 at 2:55 PM
    tha_roost
    tha_roost Member
    Deep East TX
    03 PreRunner DubCab TRD SR5
    This worked without any in-motion contact or off glass over travel? I've long felt that the 17" blades are insufficient during heavy downpour. I've been hesitant to get longer blades fearing that the added length (and increased surface area contact=more drag) might put too much stress on the wiper motors and burn them up or wear them out faster...pretty sure they're the oem's.
  7. May 30, 2024 at 4:25 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Lil tech tip I saw on a 1980’s VW car magazine many years ago…..
    You can move pass side arm ‘up’ a few splines on the wiper shaft for faster coverage
    Not level but does work
    Too each his own.
    17” btw
    15psd likes this.
