What size torx socket is this?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JustinL, Sep 27, 2011.
  1. Sep 27, 2011 at 3:01 PM
    JustinL
    JustinL [OP] Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    Does anyone know the torx size needed to remove the bolts holding on the top trim piece of the tailgate cover? I figured I could saw a little by just string this one size (but I'm sure I'll own a full set by the end of tonight)
  2. Sep 27, 2011 at 3:07 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can get a whole set from Home Depot, Lowes, etc. for under 10 bucks...I dont remember the size off hand though.
  3. Sep 27, 2011 at 3:23 PM
    JustinL
    Justin
    Berlin, CT
    2012 Conversion
    Good idea Chris. Told you I'd end up with a set!
    Christian thank you for the PDF as well. This is a prime example of TW kicking ass!
