What size tire can I fit on a stock 2019 SR5 4x4
Discussion in 'Wheels & Tires' started by BPZ, Oct 18, 2020.
  1. Oct 18, 2020 at 7:52 AM
    BPZ
    BPZ [OP] Member
    08 Offroad
    3" suspension lift, 3" body lift.
    Thinking about getting my son some tires for his Tacoma- Can someone tell me the largest size I can fit on his stock 2019 SR5 4x4 without lifting or trimming? He has 16" wheels and Im looking at AT tires- maybe Toyo. He lives in Oregon so wet performance and little mud occasionally. Much appreciated.
  2. Oct 18, 2020 at 10:41 AM
    MissoulaGriz
    MissoulaGriz Well-Known Member
    Missoula
    ‘19 SR5 DCSB Super White
    Probably 265/75 16. I’ve got that size in the Toyo AT3 on my ‘19 SR5 and they’re perfect. Stock rig and no rub.
  3. Oct 18, 2020 at 11:38 AM
    Silverlogic
    Silverlogic Well-Known Member
    Tyler
    San Diego, California
    2018 Silver DCSB TRDOR
    Largest diameter you can fit stock is 255/85R16, but it's a skinny profile.
    Largest "balanced" profile is 265/75R16
  4. Oct 18, 2020 at 6:16 PM
    BPZ
    BPZ [OP] Member
    08 Offroad
    Thanks! I will check out some 265/75r16's.
  5. Oct 19, 2020 at 7:38 AM
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    265/75/16 will work okay on the stock SR5 wheels? thinking of getting a set but also I plan a 2" lift with 5100s in the future. don't want it to look funny or hurt abilities to tow my small camper.
  6. Oct 19, 2020 at 8:10 AM
    MissoulaGriz
    Missoula
    They work great on my stock wheel set up.
    Taco_mike73[QUOTED] likes this.
  7. Oct 19, 2020 at 8:28 AM
    Taco_mike73
    York, PA
    They do look good. The white letters will really stand out on my dark grey SR5 wheels.
    MissoulaGriz[QUOTED] likes this.
  8. Oct 19, 2020 at 8:33 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    p265/70/16
  9. Oct 19, 2020 at 8:36 AM
    Taco_mike73
    York, PA
    why this over 265/75? isn't 265/70/16 a stock size for the TRD OR?
  10. Oct 19, 2020 at 8:37 AM
    BillsSR5
    bill
    2014 SR5
    if he has a 4 cylinder based on tire weight 265/70/16 is as big and heavy as you want to go, they come with 245/75/16 from factory
  11. Oct 19, 2020 at 8:40 AM
    Taco_mike73
    York, PA
    Ahh... I see for a v6 would that matter so much?
  12. Oct 19, 2020 at 8:42 AM
    BillsSR5
    bill
    2014 SR5
    the tire size from factory are designed to run optimumly with the engine/driveline/towing/braking etc etc etc
  13. Oct 19, 2020 at 8:46 AM
    Taco_mike73
    York, PA
    I been looking at the difference between p245/75 and p265/75. the 245s weight around 37 pounds and 265s about 41. 4 pounds more per. Do you think that's a big difference that will be drastically noticed with a v6?
  14. Oct 19, 2020 at 8:51 AM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Big/drastic no. But the feeling is subjective and there are already a shait-ton of Tacoma drivers that have a hissy fit when the transmission downshifts.
    It's not just the added weight as you are also slightly changing the gearing when you change the wheel diameter. Doubt it'll be an issue unless you already get pissy about the trucks interstate speed shifting.
  15. Oct 19, 2020 at 8:53 AM
    BillsSR5
    bill
    2014 SR5
    stock p245 all season around 32 pounds, this is the baseline weight you should try to maintain, pushing more heavier larger AT tire makes the truck work harder using more gas and lessening the performance factors of it
  16. Oct 19, 2020 at 8:54 AM
    Taco_mike73
    York, PA
    so far no I don't get pissy about shifting. I do have a 2000 pound popup to tow that I haven't got to take anywhere since buying the truck. So i don't have an idea of how it will handle it, I assume good enough being not so heavy and low wind load.
  17. Oct 19, 2020 at 8:56 AM
    Taco_mike73
    York, PA
    I was comparing AT tires, not the Highway ones that were stock :(
    BillsSR5[QUOTED] likes this.
  18. Oct 20, 2020 at 7:45 AM
    Jay buck
    Jay buck New Member
    Jay
    2019 SR5
    None
    I am new here and also was wondering the same thing. I have a 2019 sr5 in need of new sneakers and am kicking around getting a 265/75/16 but am concerned with rubbing. I really have a concern with cutting / trimming. Most of my driving is on road with the occasional dirt road on some woods but no real off roading. My mechanic tells me to go 255/70/16. Any thoughts?
  19. Oct 20, 2020 at 7:46 AM
    BillsSR5
    bill
    2014 SR5
    go with the stock size for whatever type of tire you decide
  20. Oct 20, 2020 at 8:10 AM
    Gen3TacomaOBX
    S
    I hate to be "that guy" but there are many threads on this topic with lots of experiences. Use the search input at the top of the page.
