What size steel stock for flatbed
Discussion in '1st Gen. Tacomas (1995-2004)' started by GregA.M., May 8, 2014.
  1. May 8, 2014 at 3:08 PM
    GregA.M.
    GregA.M. [OP] New Member
    Greg
    Bel Air, Md.
    01 XCab SR5
    Hello everyone this is my first thread so bear with me, I have been looking around for a bit but I can't seem to find the answer I'm looking for. I would like to think of myself as pretty mechanical, but never sourced my own raw materials. I am looking to build a flat bed out of 2x2 and 2x4 steel tubing but I can not find what wall thickness will meet the requirements. I know could over build but I would rather not be carrying around a few hundred pounds that I do not need. I do not use the bed to carry a ton of bricks of anything heavy like that. The max would most likely be a full load of firewood and camping gear back some narrow wooded trails. Here are some drawings to give a basic idea what I'm after, also any advice on design is greatly appreciated.
    Greg
  2. May 8, 2014 at 3:12 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    what do you plan on putting in that bed?
  3. May 8, 2014 at 3:24 PM
    GregA.M.
    Greg
    Bel Air, Md.
    01 XCab SR5
    Most of the time nothing, but I like to load to load you firewood, camping, and fishing gear and go for long weekends back in the woods.
    Also, Paranoid do you happen to own an STI? Just happened to notice the picture of you avatar.
  4. May 8, 2014 at 4:04 PM
    nswsparky
    nswsparky Well-Known Member
    Chad
    Minnesota
    '03 TRD, SAS, ARB's F/R, Atlas 4 speed
    D44, SAS, 3 link coilovers, ARB's, Ford 8.8, Atlas 4 speed, cutting brakes.
    I think 1/8 would be more than enough for a flatbed in a 2x2 especially with how many cross braces you are doing.
  5. May 8, 2014 at 4:07 PM
    Oowen
    Oowen Well-Known Member
    Owen
    Reno, NV
    '24 F-150
    I am doing the exact same thing right now. I am using .120 wall rectangular stock for most of it, the bed I am using pressure treated wood to keep weight down.
  6. May 8, 2014 at 4:14 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    i agree^..
    when i was building my tire rack thing (now removed..) i looked at the wall thickness of both 1/8" and 3/16". The 3/16" is a lot thicker than one would think.
    It will still be heavier than a normal bed though even with 1/8". I would probably not go much under 1/8" though.
    This is also a good idea as it will cut down on a bit of weight if you use wood for the deck part of it. I think your design looks decent. Its pretty standard though and if i were you i would just do a few google searches for flatbeded tacoma or something then you can see how other people made theirs and get a few ideas :)
  7. May 8, 2014 at 4:41 PM
    glassdoc
    glassdoc Well-Known Member
    Spring City, PA 19475
    04 DubCab 260,000 miles
    Stubbs Sliders, 2.5" lift, Ken-Mtn Bumpers, Leather Seats, AM/FM/CD/DVD & CB, IP Trans-Upgrade, (2) Trans Coolers, Synthetics Thru-out
    Had the Amish build mine. They used 1/4" aluminum on all the frame work. The side panels are 1/8" and tailgate is 1/8 inch. Tailgate should be able to hold between 400-500 pounds. All led lights including back-up/reverse. Factory shortbed weighs 426 pounds. Aluminum bed weighs 178 pounds..
    After some polishing.
    Only had it now for less than a month, so still "under construction" so to speak. If the rain will stop for a few weekends I might could get it done..
  8. May 8, 2014 at 8:34 PM
    paranoid56
    San Diego
    14 double cab taco
    i would say 120 wall and you should be fine. its still going to weigh a ton :D
    and yea, thats my old sti. just recently sold it :( (never drove it and seemed odd to have 4 cars lol)
  9. May 9, 2014 at 12:14 PM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    How hard were those LED strips to wire up? I am thinking about yanking out the stock brake lights and using something like that since i keep breaking them.
  10. May 9, 2014 at 4:41 PM
    glassdoc
    Well, there is a lot of the wires in the factory bundle back there that you don't use. (6 or 7). The red led lights were suppose to be brake, tail and turn. But... What I paid for and what I got turned out to be 2 different items. These are brake and tail only. Think there were 4 wires out of each one. 2 grounds and the hot for brake and the hot for tail. Not hard to wire, just have to find the right wires coming from the factory plug. Lucky for me, the plug wasn't an issue as the Amish guys cut if off.. LOL So, my trusty $6 circuit tester and about an hour an a half..
  11. May 9, 2014 at 11:23 PM
    4wheelpeel
    4wheelpeel Active Member
    graham wa
    01 reg cab 4x4
    that is a sweeeeeet aluminum bed, i love it :headbang:
  12. May 15, 2014 at 12:15 PM
    dogtracks
    dogtracks New Member
    I love your aluminum bed. The side rails and tailgate are a great idea. I came across a used aluminum body and was able to make some minor modifications to make it fit nicely. Now I can carry 17 dogs in comfort and three dog sleds.
    What I'm looking for now are underbody boxes to fill the voids. Anyone have any ideas?
  13. May 15, 2014 at 4:39 PM
    glassdoc
    Thanks. I believe I will like it too once I get it the way I want it.. As for under body boxes. If you call the guys (on mudflap) that built my bed. I'm sure with measurements pictures etc. They can build just about anything.
