What size sockets and wrenches for working on a Tacoma?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Trapperr, Mar 27, 2016.
  1. Mar 27, 2016 at 12:48 PM
    Trapperr
    Trapperr [OP] Well-Known Member
    Reno, NV
    2002 Tacoma Double Cab 4x4 3.4l V6
    I'm currently piecing together some tools to keep in the tacoma for any road/trail side repairs I might have to make. Since this list could be insanely long, I'll stick to sockets and box/open end wrenches. Here's what my mobil tool box has...
    -3/8" drive socket wrench
    -3/8" 3" extension
    -3/8" 6" extension
    -3/8" shallow sockets in: 10mm, 12mm, 13mm, 14mm, 17mm, 19mm
    -3/8" deep sockets in: 10mm, 12mm, 13mm, 14mm, 17mm, 19mm, spark plug socket
    -1/2" breaker bar
    -1/2"-3/8" adapter socket
    -1/2" sockets in: 19mm (lug nuts), 34mm (axle nut)
    -Open/box end wrenches: 10mm, 12mm, 13mm, 14mm, 17mm, 19mm, 22mm
    Did I cover all the fastener sizes with what I currently have? Any other size bolt heads on these trucks that I'd have to unfasten if broke down? I know that's a very vague question.
  2. Mar 27, 2016 at 2:36 PM
    MrRiverMan
    MrRiverMan Compulsive tinkerer
    WNC
    2002 Taco 2.7 4x4 auto, 96 Taco 2.7 4x4 manual, previously 2003 Taco 4x4 auto, 2000 Taco 2.7 4x4 manual, 1994 22RE 4x4 manual, and 1996 T100 4x4 auto
    Are the transmission and t-case plugs 22s? I think there's at least one 24mm on the 3.4 if it has an oil cooler. It also seems I've run across a few 8mm bolts, and you need the SAE sockets to open hose clamps (1/4" maybe?) - there are clamps on radiator hoses and the fuel filler neck hoses. I also like to carry line wrenches in 10mm and 14mm for brake lines and fuel lines.
  3. Mar 27, 2016 at 2:38 PM
    Speedytech7
    924 W Garland Ave, Spokane, WA 99205
    It's less Tacoma and more mod
    You'll want a 24mm for drain and fill plugs. I keep an adjustable wrench for those just in case unexpected bolts too. You'll want a 24mm socket as well because you cannot reach the rear axle drain bolt with a box wrench. I have a truck tool case as well, and I filled it with harbor freight stuff to avoid being devastated if someone were to steal it. Don't wanna lose my Snappys to a theif, but you can find the sockets that are larger in a onesy twosy selection from them or get them from AutoZone for cheap as well. Just something to keep in mind, no one wants to lose their good tools. I may take some pics of whats in mine since it needs to be reorganized.
  4. Mar 27, 2016 at 2:58 PM
    Trapperr
    Reno, NV
    Thanks for the replies! Yes, I'll toss in a 24mm socket as well. My box contains mostly duplicate craftsman and a few cheap oriellys sockets. Harbor freight for the box end wrenches.
  5. Mar 27, 2016 at 3:43 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I can never figure this out Why do people put there low quality tools in vehicles ??
    If I have a failure that can be repaired I want the best tools I own to work on it.
    If it can`t be fixed it gets a ride home.
    Unless you know that the last owner was decent and didn`t remove and install all the hardware with sae tools that were close enough one of the best things to have is The Irwin Sockets for rounded hardware.
  6. Mar 27, 2016 at 3:50 PM
    Speedytech7
    I bring my high quality stuff if I'm going on a road trip or wheeling trip, I leave the HF stuff in all the time. Not worth losing my good expensive tools when I could have the truck towed with my AAA if the HF stuff gives out. I have doubles of things that are likely to break like ratchets and pliers. For the most part if I'm busting off HF tools it likely wasn't a repair to be done on the side of the road. That's why I bring the good stuff for big trips.
    StuckinOhio likes this.
  7. Mar 27, 2016 at 3:53 PM
    DrFunker
    DrFunker Well-Known Member
    Check out @Crom 's write up on this. Will look for it and post up.
    Speedytech7 likes this.
  8. Mar 27, 2016 at 3:55 PM
    DrFunker
  9. Mar 27, 2016 at 3:56 PM
    Speedytech7
    DrFunker[QUOTED] likes this.
  10. Mar 27, 2016 at 6:30 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
  11. Mar 27, 2016 at 6:32 PM
    Speedytech7
    That's a lot like my good set, but I have stubby and thin service style ones worked in there at popular sizes like 10,12,13,14,17
  12. Mar 28, 2016 at 11:40 AM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    Hmm, I dont know if he has enough 10mm there.
    But yeah 10mm seems to be the divinely ordained staple of Japanese cars.
  13. Mar 28, 2016 at 12:10 PM
    CD20H
    CD20H Well-Known Member
    Ben
    North Texas
    2004 Double Cab TRD 4x4 Limited
    Magnuson Kompressor, OME lift kit, JBA Headers, junky Sony radio.
    I have one of the largest tool kits that Craftsman makes that fits in a blowmold carrier. Buy a kit and always keep it in the truck.
  14. Apr 2, 2016 at 11:39 AM
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    This and 14mm.
  15. Apr 2, 2016 at 12:15 PM
    Tacofire98
    Tacofire98 Well-Known Member
    Jake
    Castle Rock
    01 TRD
    I believe lug nuts are 21mm, might throw that in too
  16. Jan 30, 2020 at 7:55 PM
    Dufus
    Dufus Well-Known Member
    Located in Colorado
    99 Taco 3.4L manual 4x4 SR5 - Imperial Jade Mica
    Mods: bent frame and sun weathered roof paint.
    Bringing up old stuff here again...can anyone confirm this? OP says his are 19mm, do they vary by year/trim?
    Also, I'm gonna throw in that you may want a 17mm crowfoot (for a meager one time use as a regular Joe) for the fuel rail banjo bolts (torque: 25 ft. lbf), if any crickets are still about reading this.
    License2Ill likes this.
  17. Jan 31, 2020 at 1:45 AM
    Wyoming09
    New Tripoli Pa
    Super Springs
    Now I have never seen a 5 lug Tacoma close up but all the lug nuts I have take the 21mm socket even the ones on the Celica`s before they went front wheel drive
  18. Jan 31, 2020 at 7:12 AM
    Dufus
    Located in Colorado
    I checked mine last night. 21mm
  19. Jan 31, 2020 at 8:11 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Did anyone mention 10mm :rofl:
    One 10mm swivel in 1/4" drive
    One 10mm deep in 1/4" drive
    One 10mm shallow in 3/8" drive
    All 6 point socket
  20. Jan 31, 2020 at 8:35 AM
    paetersen
    paetersen Well-Known Member
    My tool kit for roadside breakdowns is pretty small:
